PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Dyno Jet PCV vs Thundermax or Power Vision
  2. Dyno Jet PCV vs Thundermax or Power Vision
  3. Can an ECM be reset to factory default settimgs?
  4. Ignition Pick-Up Drippers...Anyone?
  5. Dealer REALLY trying to sell me on SE tuner.
  6. Throttling problem - 1996 Sportster
  7. Possible TPS?
  8. Xieds on a stage 1?
  9. starter, battery ?
  10. Thanks TTS staff for a quick turnaround adding extra license
  11. PCV Auto Tune
  12. 98/99 RK Fuel Pump Location?
  13. 2010 se ultra
  14. What tuner to go with help.
  15. Help!!! Info on throttle bodies - late model.
  16. Accel Stealth coil anyone using it yet
  17. Ignition Timing Map for Thunder Heart Stand Alone Ignition
  18. Stock ECM or stage 1 with V&H fuelpack
  19. cobra power pro problem
  20. SERT v4.77 software wanted
  21. relocate blackline ignition.
  22. Decel pop
  23. Desperate Canadian Member Looking for Competent Dyno Tuner
  24. Power Vision Tuning Process w/ Stock O2 Sensors
  25. ECM vs Thundermax Autotuner.
  26. quit again
  27. data logging?
  28. Powervision map for Fullsac X pipe
  29. Question About Heat On Late Model Touring Bikes
  30. Name this wire/connector
  31. power vision tuner
  32. 883n iron sportster 2014 powervision map
  33. 2012 Heritage comp.
  34. Need FuelMoto help...
  35. Power commander 5 + a dyno tune for $500
  36. will the power commander fit
  37. What starter to buy and where
  38. DK Customs Fuel Managment question
  39. idle problem
  40. 03 Road King fuel pump replacement
  41. A Question For Those TTS Mastertune Users
  42. Urgent advice needed: bike won't start after draining tank and undoing bottom nut
  43. 103 TW6-6 thin HD gsks dyno'd
  44. Pipes discolored after dyno tune...why?
  45. 1999 Night Train Solenoid Clicking
  46. clacking throttle plate ?
  47. Gasoline Question
  48. PC-V Maps
  49. FP3...is this even possible?
  50. Question About A Friend's 2012 Road Glide
  51. Tune software
  52. Timing question
  53. Stage 1 - Spark Plugs
  54. 2007 SG Popping on deceleration
  55. new tunner
  56. harley dealer dont use power commander
  57. Bike won't start after...
  58. Fuel tuner for a 2008 Softail Rocker?
  59. "Start up" frustrations
  60. EVO non-adjustable timing plate???
  61. 98' Evo Fuel Injection problem...throttle stuck wide open.
  62. dyno tune necessary?
  63. 2011 hot / spark knocking / Dog !!
  64. where to buy plug to make 02 eliminator
  65. FP3 Pairing problem
  66. Tuner advice or up sell?
  67. 99 flhtcui idle issue... please help!!
  68. Tuning for mileage
  69. Looking for a Dyno Tuner
  70. Help With Power Vision Tune for 2 into 1 System
  71. Bad tuner?
  72. head light will not turn off with ignition off
  73. speedometer/tachometer erratic needle jumping
  74. Tube that leads out of the tank????
  75. Dreading Filling Up....No Hot Starts
  76. can i make o2 eliminator
  77. problem with ignition
  78. SE Pro Super Tuner smart tune?
  79. Low speed miss
  80. Maximum performance for stage 1 2011 96 Dyna
  81. I need some serious help.. PC3 guru wanted.
  82. do i have to map my dynajet tuner
  83. 2011 SG Veid settings, decel pop
  84. restarting problem
  85. Thundermax - Hard start but great when warm?
  86. Engine seems to run only on back cylinder
  87. fuelpak 3 installed, now my bike won't start.
  88. So frustrating!!! Trying to tune
  89. kit to move ignition on dynas
  90. EVO rear spark plug no fire
  91. Need tuner advice
  92. Help! 1997 evo fi problems!!!!!
  93. 883 intermittent no spark
  94. magneti-marelli dual runner TB ?
  95. A strange problem
  96. What canned map to use. Help!
  97. Back to stock tune
  98. MAP updates for old SERT?
  99. does new ignition control module for 2005 dyna fxd need to be synchronized?
  100. Traveling, need advise.
  101. Tts
  102. newbie -power commander V
  103. PCV Map request
  104. Air Breather Question
  105. Softail codes
  106. Dyna Wide Glide Calibration (TTS) ?
  107. Engine Shut Off Issue
  108. VTune after cam install
  109. SE Tuner Help,
  110. Dyno Tune Squiggly Lines...why?
  111. Tune for 103", se 204, true duals power vision
  112. Cannot load Drivers - WIN 7
  113. super tuner
  114. PCV Question about O2 sensors/optimizers
  115. new to SEST pro and ready to start playing
  116. TPS on 04 Ultra
  117. TTS on a Surface
  118. Help---Bike Suddenly Dies?
  119. Rough idle
  120. PCv
  121. Street bob map request
  122. How many of you are running completely open loop.
  123. Recommended reading for tuning?
  124. which map for dragulas on fp3?
  125. 01 road king tank leak
  126. Learning
  127. Stage 1 103 Softail VE Tables - Post yours and help me learn
  128. sputters
  129. Need help with throttle cables after Heritage bar install
  130. Full exhaust and AC. Vieds and download?
  131. PC-V Map Needed
  132. Decel enleanment??
  133. 2013 V Rod theft recovery
  134. Starting issues w/ security system
  135. Dead screen on P.V. tuner
  136. electrical problem or tuner problem
  137. how to use PCV to adjust idle heat?
  138. Question about spark knock
  139. 2012 Road King problems.
  140. dead on arrival
  141. Won't run under a load
  142. beep when I turn the ingintion switch
  143. Changed pipes now won't start
  144. Flash Tune ECM without a Married Tuner?
  145. Worth it?
  146. Super tuner pro download problem!
  147. Spark plugs burning different
  148. X14IED issue/alternatives?
  149. 2007 FLHX Wouldn't Fire, Now It Won't Even Turn Over
  150. Error P1351 and P1352
  151. Wide Band Bung Placement
  152. PC-V Map
  153. ThunderMax wich map
  154. 88" andrews 21, fresh tune, knocking at full throttle
  155. Ignition switch tumblers
  156. Daytona Twin Tec TC88 Help
  157. Spark plug hole to large for inserts, need help!
  158. Need PCV map - EG W/21n cams
  159. Shadow Dash for TTS
  160. High RPM issue
  161. 09 Ultra, 255 cams, stage II, V-XIEDs= Satisfied
  162. ECM Constants TTS
  163. Fuel line repair made a little easier - 2000 & earlier
  164. Can a "Stock.MTE File" be " recreated" ?
  165. spark knock....
  166. After Stage 1..Stalling@ dead stop
  167. Life Expectancy of Crank Positioning Sensor
  168. 120 Ultima Sputter
  169. PCV Map for 2008 with Stage 1
  170. Sportster 883, Vance & Hines short shots, Fuelpak, K&N - FLAT SPOT PROBLEM
  171. popping exhaust & powercommand 5
  172. '03 fxdl air filter
  173. dynojet Power Commander 3 problem?
  174. Direct Link Full Flash Tune
  175. Running Tuners on MAC
  176. Need a map for cams
  177. Low speed stutter
  178. 95'' Harley reman
  179. Will not start!
  180. Problems with PCV
  181. 95" Ignition Timing / Tuning
  182. engine temp question
  183. Ecm
  184. EFI issue and Tank sealer peeling off
  185. Turn Signal on an 1995 Road King
  186. 08 Nightster fuel tank removal
  187. EFI/Ignition Race Tuned?
  188. Newbie Question Regarding ECU
  189. Tacho/speedo problem
  190. Magnetti Morelli replacement options?
  191. Magnetti Morelli replacement options?
  192. Ready for a Tuner; Advice Needed
  193. idle control valve cycling when ignition is off
  194. SE Pro No Calibrations found??
  195. help with 2012 wide glide tune
  196. Fuel tank internals question
  197. S/E stage 1 to Big Sucker
  198. Speedometer 70900274 problem
  199. 11 Fatbob dropping cylinder.. weird
  200. Coil Wiring HELP!
  201. Ignition wires
  202. scared to get into my dyno tune!
  203. Help!-- I'm getting frustrated!
  204. 110 race fuel
  205. PC V & elevation
  206. Help with compufire 3 phase 40 amp install
  207. Rotor cup rotational direction, 1200S
  208. Carbon deposit
  209. P1511 code/HPI TB
  210. 2014 touring Tmax with auto tune reviews
  211. FatBoy Tuning with new exhaust help
  212. blowing my efi and ecm fuse
  213. 2012 Limited crapping out
  214. Getting frustrated
  215. ironhead starter installation
  216. Pinging at prrt throttle, Stage One 80"
  217. FI throttle spring tension.
  218. Powervision, Autotune, closed loop?
  219. Thundermax map suggestions?
  220. Sportster fuel pump on dyna street bob
  221. 07 Road King tank pressure?
  222. No spark
  223. 06 Road King Shutting Off
  224. Bike won't start using engine on and run on
  225. Sell me on Thundermax...
  226. Just loaded 1st PV map w/xied still on!!!! Duh, bad?
  227. Throttle pak
  228. 06 fuel injection line leak.
  229. FLHP and cruise control
  230. Pulling the trigger on EFI Tuner
  231. Evo Starter Issue
  232. Confussed and tired.
  233. cam swap ,power loss
  234. cam swap ,power loss
  235. changing the fuel filter in my 2010 Softail Convertible
  236. NoVolts
  237. Welp now it won’t start at all now...
  238. Having hard time to start FXDB 2012
  239. 250 dyno
  240. Maybe controversial but makes sense for stage 1
  241. pull last program from vci module
  242. Step by Step using SERT
  243. 2002 CVO Road KIng misses and Harley Davidson does not know why!
  244. PC3 USB tune or find map?
  245. Cam updater steps for TTS
  246. Spark plug reading with EFI
  247. Screaming Eagle EFI Race Tuner Kit
  248. ThunderMax Alternatives??
  249. HD Stage 1 download...But not the usual question
  250. Running 2 coils on my 2002 softail
