PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Prob tuning the Dyna 2000i ignition module
  2. Odometer/Tripmeter Button Not Working
  3. Blowing Accessory Fuse all of a sudden
  4. Didn't read manual good enough!
  5. 89 ultra no start no power anywhere
  6. battery tender while battery connected
  7. Tach Wiring
  8. Indicator light on
  9. Power Commander trouble
  10. Pciii usb
  11. What isthe spare headlight connector for?
  12. good tuner in mid tn area
  13. Softail no start
  14. PCIII USB setup
  15. 1990 fxstc not charging need info
  16. after V - tune session lost power
  17. Saving a Calibration
  18. What was that smell?
  19. sert pro
  20. PCIII USB Installed
  21. TMax w/ Autotune question/concern
  22. Can cold idle be lowered ?
  23. ECM and MAP questions
  24. HID Lights
  25. Rear turn signals/running lights
  26. SEST Instructions "TTS Style"
  27. Does anyone know...
  28. stator trouble
  29. Trouble Code Set 01 RKC
  30. Radio swap causing BUS-ER
  31. Need wiring diagram of speedo
  32. Need Help
  33. 2006 american ironhorse texas chopper driveabilty running problem
  34. Changing the security pin
  35. Did I mess up?
  36. Cam Question
  37. Whats my plugs tellin you
  38. Tuner for 1996 Road King inj.
  39. led lights wiring problem
  40. Help!!!
  41. PC-V and Dobeck TFI together?
  42. Relay problems
  43. TTS ans Setting CLB's
  44. Starter Problems - 07 Street Bob
  45. Daytona Twintec III tuning
  46. Suggested Reading?????????
  47. Doc banned again?
  48. Accel coil leaking
  49. Led running/turn lights
  50. 09 1200XL Sporty , spits and sputters
  51. 97 fxstc
  52. re-setting rev limiter
  53. billet headlight nightmare!!
  54. Starting map for stage 1
  55. Bike occasionally stumbles and dies. FI?
  56. PC-v,SE HB and Rush 1.75s
  57. Gas gage...yeah i know but...
  58. non starting nighttrain
  59. tts vtune ?
  60. Could Use Some Diagnostic Help Please
  61. Cylinder head temps
  62. pc3 backfires cuts out
  63. SEST update problem!
  64. TTS throttle blade adjustment
  65. Battery goes dead in 2 weeks
  66. Tts data record
  67. SERT Map 96ci Dyna
  68. EFI tuner questions.
  69. Electrical System problem/question
  70. DTC's
  71. 05 xl1200r
  72. Battery not charging
  73. 32109-18a insallation on Crossbones
  74. Installing SERT on Crossbones
  75. Throttle reset prblm
  76. 05 TTS Mastertune ?
  77. Charging system
  78. EFI tuning Nightrider style?
  79. speedo dies, warning lights on...! uh oh...
  80. SERT Problem
  81. 09 FXDC wiring diagram?
  82. coverting a carbed unit to FI
  83. Shovel starter won't disengage
  84. Power Commander III vs. Power Commander V
  85. Used speedometer mileage recalibration anyone do this ?????
  86. ThunderMax Users, Question
  87. EFI multicore cable - help
  88. 2001 Fatboy horn wiring
  89. TTS v-tune and cold weather
  90. Thundermax with Lots of Decel Popping
  91. 1978 Harley Sportster complet Electrical kit
  92. Uncommanded rpm increase
  93. Rough Idle w/ code PO152 and PN 32915-07 showing
  94. Resetting PCIIIr tables
  95. Installing HD Security TSSM with a Twin-Tec TCFI-IID
  96. Looking for some help deciding on a PC-V
  97. stock electronic ignition vs SE ignition
  98. Running Rich And Lean
  99. Newbei Help Needed
  100. Code 11 and lights dim
  101. Low beam but no high beam on Road King
  102. 02 fatboy electrical problem?
  103. PC lllr help needed!
  104. O2 sensors, one black, one white - OK?
  105. TTS Master Tune ?
  106. Power Commander V
  107. TTS master tune vs.Screaming Eagle Super Tuner
  108. warning lights lit
  109. Help with PC3 v Fuelpak
  110. when changing spark clubs do you use lock tite
  111. EFI to Carb
  112. Tmax and download
  113. LED Turnsignal - HELP!!!!
  114. Has anyone installed a PC-V on an 883L?
  115. PC-v,SE HB and Rush 1.75s
  116. 2002 FatBoy Fuel Inj
  117. 50mm throttle body
  118. Kuryakan Lizard lights
  119. No spark/start have fuel problem
  120. Did HD change the TSM/TSSM marry ?
  121. 08 Dyna Cams Install
  122. Tuner needed-North Alabama
  123. 2006 Dyna idle problem
  124. Run Turn Tail Question / Load Equlizer for all four blinkers
  125. twin tec lll on 07-09 softails
  126. TTS Communication problem....
  127. 883 to 1200 ECM update
  128. 07 RK w 5000 miles heard a small pop, lost electrical
  129. Timing?
  130. remaping question?
  131. robpreston
  132. Which Tuner? 08 XL883C
  133. RUN,BRAKE,TURN SIGNAL MODULE KIT (69462-06a) Help
  134. Lights and Speedo...
  135. SE Stage 1 Air Cleaner install problems
  136. Help - Dyna 200i-P installation
  137. Dealer lost my SERT!!
  138. MAP download needed!!
  139. Gauge Wiring
  140. Battery Replacement
  141. Men's Road Warrior 3-in-1 Cotton Canvas Jacket 4XL
  142. EFI question: manifold absolute pressure
  143. What am I doing wrong?
  144. wiring new ingnition..need some help
  145. crane hi-4 headache
  146. Speedometer repair service?
  147. Shorting problems....
  148. race tuner maps
  149. Voltage Reading
  150. 1990 FLHTC Ignition key switch removal ?
  151. Need a map to hold me over (PCIII)
  152. Battery cranking amps
  153. Timing
  154. Wire Extention Help
  155. Ignition/Starting problem with Dyna
  156. Stator connector full of motor oil.
  157. SERT professional
  158. Cobra FI2000R v. FI2000 O2
  159. Starting problems
  160. new ign and security sys.
  161. pc3 set up for 95 inch with stage 2 ecm
  162. Dobeck TFI 1440st-gen
  163. Bullet signal wiring
  164. Tail Light Question
  165. PCIII, Nightster, Custom Exhaust
  166. question on map for Fatcat 2into1
  167. Thundermax - Decel Pop - Basic Settings
  168. Symptoms always changing
  169. It runs, sometimes
  170. Blown Fuse... strange
  171. Turn Signal Connection
  172. Searched and read till I'm red-eye'd....
  173. pc3 and trouble codes
  174. odometer tampering
  175. Breakout box
  176. Security system problem 04 FLHTCUI
  177. Electrical Diagram for CB mic
  178. LED headlight/tailight?
  179. 94 EG Ign Coil
  180. need a map please
  181. Tach needle bounce
  182. TMax O2 Sensors
  183. ACR on TTS?
  184. 4-ways flash rapidly on start up
  185. Speedometer Wire Relocation?
  186. Is a Fuel Mgt. or Remap really needed ??
  187. Any electrical gurus out there?
  188. Button on Throttlle clamp
  189. HELP - SERT Trouble
  190. wiring help
  191. --Spark Plug Wires--
  192. tuner
  193. SERT maps
  194. Do I need larger injectors?
  195. Throttle Body????????
  196. power commander
  197. How much more power...
  198. Break In Map
  199. Fuse Blows Everytime
  200. tts original map size
  201. "Feature" warning in PCV Auto-Tune software
  202. map for 2009 touring HDI
  203. What would happen if you disconnect the o2 sensors?
  204. Are there two maps one for open loop mode and one for closed loop mode?
  205. Power Comander 3 USB
  206. Weirdest Breakdown in 43 years and 363 days of riding.
  207. AGM battery Question
  208. Power Commander
  209. Any body tried the Harley high performance 1.4 kw starter (31621-06)?
  210. rear tail light volord codes?
  211. Stoichiometric Questions
  212. Serious Issues.
  213. New mods installed!
  214. 05 flhtcui sert / map
  215. Cold Start
  216. Fuel Injection
  217. Preferred Order to Install New Exhaust, PCV, AC
  218. Gauge Relocation
  219. idle rpm control
  220. FXST Rear Turn Signal relocation kit problems..wires too short after relocating..help
  221. Power Commander III USB
  222. Red key light on - '09 Street Bob with 2 recent mods
  223. Speedometer stops woking at 1500 rpm
  224. One more code ?....P0374 CKP Sensor Synch Error EFI
  225. Need help - primary cover nuts wrecked
  226. Thundermax O2 sensors not detected
  227. Thundermax - still have some decel popping
  228. Help needed with Pingel kill module...
  229. scremin eagle race tuner or vance& hines fuel pak
  230. battery draw
  231. New Tach?? HELP!
  232. Fuel Pump not getting power from ECM
  233. Installed PC V, Bike won't start. Ideas?
  234. Front turn signal removing
  235. What does this code mean?...P1353 Front Cylinder No Combustion EFI
  236. Blown fuses
  237. thundermax -ego diagnostics?!
  238. anybody using training dvd for se pro super tuner?
  239. Sert on a Mac???
  240. SERT - 08 fxdf starting over with map
  241. Briggs & Stratton Ignition (Non-Harley related)
  242. Diagnostic data test connector?
  243. Rear tail lights
  244. Big Radius, Heavy Breather, SERT???
  245. Linking to T/Max with "VISTA FROM HELL!!"
  246. Need help wiring horn cover
  247. Recharge Battery W/ Battery Tender
  248. backfire 2008 FXDL V&H 2-1 Stage 1 Air SERT
  249. Baron Tach
  250. All gauges out, won't self-diagnose
