PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Aftermarket Cruise Control?
  2. (98 road king shuting down
  3. Need help to uninstall smart siren 2
  4. Fast idle
  5. What is this connector/sensor?
  6. Help 06 Night Train only one cylinder firing
  7. PC III install comments
  8. Front cylinder misfiring ... REPAIRED!!!!
  9. tssm
  10. How can I modify the turn signal conversion kit
  11. High Idle should I reflash with my SERT
  12. Delete
  13. '07 Heritage - connect 12v aux. pwr socket?
  14. Flush LED fuel gauge problem
  15. Fuel Injection
  16. Race tuner
  17. SPEEDO
  18. Where is my race tuner
  19. 03 fatboy speedo turn signals
  20. TMAX with autotune ?
  21. No spark
  22. Chrome Switch Housing
  23. Help LED LIGHT WIRING ISSUES
  24. SE Heavy Breather vs Hyper Charger
  25. Power Commander Newbie
  26. sputter
  27. T-Max Stutter on warm up
  28. Electrical Mystery. Need some help.
  29. pcIII and starting bike
  30. 07 iIGNITION FUSE BLOWS
  31. CPS Code /DynaJet Power Commander
  32. turn siginal problems
  33. fatboy stalls after starting - low RPM
  34. Was down load needed ?
  35. Intermittent starting problem '07 Street Glide
  36. I should of posted this here.....
  37. SERT on 08 Bob?
  38. SE Tuner vs Power Comander III
  39. THUNDERMAX AUTOTUNE PROBLEMS
  40. Speedometer problems
  41. How many times are we going to pay for a Dyno!
  42. Tmax Experts
  43. Taking bike back to tuner - need tips
  44. PC3 USB Map Request
  45. Ignition Timing
  46. Power Commander III and tach
  47. Strange electrical problem
  48. Speed Sensitive Electrical Problems
  49. what does a fuel pak do?
  50. How to repair wiring harness?
  51. 03 Ultra Classic with no spark
  52. V&H Fuelpak or PCIII which is better?
  53. flasher
  54. Dual Negative Leads Off the Battery
  55. New Harley owner has questions
  56. Fuel question
  57. Wide Band 02.....
  58. Check engine Light coming off and on
  59. pc 111 error
  60. 98" GMR
  61. Intermittent Horn Question
  62. What maps come as stock with new SE super tuner?
  63. Voltmeter Fluctuating!!
  64. TSM/TSSM query
  65. Nightrider O2 EDs
  66. Electrical gremlin?
  67. popping on decel
  68. powercomander
  69. Decel pop
  70. Changing turn signal switch
  71. fuel map reccomendations for a jims131" and a 58 mm throttle body
  72. fuel injection good or bad
  73. EFI Fuel Leak
  74. Do I require another Dyno?
  75. RPM with stock 08 1584, how low can I go ?
  76. ignition fuse keeps blowing
  77. charging problems?
  78. Better Spark Plug
  79. XIED Engine Temps
  80. HELP Intermitt. cutting out '96 FLH EFI
  81. Sportster Turn Signal Alignment Problem
  82. engine and security light come on after...
  83. ecm and pc3 help
  84. Had bike dynoed
  85. does anyone have the RSD tracker 2-1 pipes K&N Filter with the PC III installed
  86. Power Commander Map Suggestions 06 Streetglide
  87. 08 TBW Ape hanger install
  88. Front Brake Light Switch Problem
  89. Fuel Injection Problem
  90. ion sense
  91. 08 RK Classic throwin codes!!!!! HELP!!!
  92. Evo sometimes wont fire untill start button is released
  93. XIEDS trouble codes fixed I think
  94. 2006 starter problem
  95. Error Code 61122
  96. PC III-ECM removal? Can't get the bolts out
  97. 08 SERT & Dyno Advice?
  98. NightTrain owner stumped!
  99. 01 ultra cruise control problem
  100. 97 ultra rich condition
  101. TSSM don't "Chirp" HELP!
  102. PC III & O2 Eliminators
  103. Passing lamp bulb H3 short life
  104. 1981 sporty misfire
  105. Engine warning light
  106. TMax is History
  107. new guy with problems
  108. Head Light Problem
  109. Ditributor
  110. PCIII- Accelerator Pump Utility
  111. SERT and cable adapter RANT.....HELP!
  112. No speedo, brake lights or turn signals
  113. have pc3usb and idle rpm question
  114. EFI Question
  115. SERT map question 2006 Dyna
  116. 2008 FLHR wiring diagram
  117. ECM upload for 2007 Fatboy
  118. T-Max New Install
  119. Microsoft Virtual PC 2007 & SERT
  120. Big problem NO START
  121. Bad spark?
  122. Custom Build Wiring Problem
  123. 100 watt Xenon headlamp...
  124. PC III question
  125. Spark Plug Readings - 1999RKC, 10k miles
  126. Tmax - Setting final drive ratio
  127. Security lamp (red key) came on and stays on...help
  128. difference in voltage regulators
  129. hot coil
  130. Weak spark
  131. 2004 wide glide auxiliary lamp kit help..
  132. How many of you running TMax?
  133. Question about Stage 1 Fuel management
  134. A Real PuzzlerSecuritiy, Cruise, 6th???
  135. How to set timing?
  136. P1356 Rear Cylinder NO combustion EFI code
  137. 1992 FLHS Electrical Problem
  138. 06 Wide Glide Engine Light/Turn Signals
  139. kn or se air filter for 2006 dyna superglide
  140. Help with Thundermax please.
  141. Anyone have a map for 06 dyna, PCIII and Bassani 2 in 1 Road Rage???
  142. S&S Fuel Injection
  143. Wiring Diagram Question (Wiring Block)
  144. 2008 Harley TPS and PCIII issues
  145. Got my SE Super Tuner today
  146. Turn Signal Help
  147. Tmax with autotune vs. TTS tuner for 08's?
  148. 2007 FLHR Diagnostic Code ?
  149. Weird turn signal behavior
  150. T-Max problems
  151. TMAX decel popping
  152. Is the stage 1 download needed with air filter change?
  153. Help - Rear Cylinder not firing
  154. Part number for Stage 1
  155. How to enable EITMS with SERT?
  156. air/fuel ratio after stage 1 download
  157. PC3 install? on 08 touring
  158. ThunderMax remap??
  159. SERT 08 DYNA
  160. Does Anyone Know The Answer To This ECM Question?
  161. High idle when I stop
  162. A new "twist" on TMAX pinging!!
  163. Magnetti Marelli trouble codes
  164. iginition
  165. Power Commander Question
  166. fuel injection questions?
  167. Need a code explained
  168. 97 FXDS
  169. Cutting out and Popping
  170. thundermax stumble at 60 to 70
  171. 1998 Road King Battery Swap Bike will not turn over
  172. What kind of HP/TQ increases over stock with a Stage 1 upgrade can I expect.....
  173. does anybody use fuel injector cleaners
  174. new battery worked for one week!
  175. Installed my Tmax yesterday, Now what?
  176. canned map 100 OR 101 SUPER TUNER
  177. SE PRO SUPER TUNER VIDEO DVD
  178. Panacea LED lighting HELLLLP!
  179. Need help- Fuel injected ultra classic
  180. 08 Street Glide need Dyno
  181. New mods, please help
  182. elecrtrical
  183. seems i got what i wanted
  184. First post - Brake light not working. Need Help.
  185. Please, Thundermax Support (hight Idle)
  186. hand control problem after installing fat drag bars with internal wire
  187. 01 fat boy FI cutting out need help
  188. Help for Twinscan II+
  189. Low speed surging on 06 Dyna?
  190. XEID's waiting time??
  191. Help -Alarm light stays on.
  192. PCIII uSB Map M807-125
  193. Help!! Mounting PCIII on 08 Ultra w/ABS
  194. Anyone get the correct Super SERT instructional CD?
  195. 02 fatboy electrical prob
  196. SERT Base MAP
  197. Cobra tuner settings..
  198. Really dumb SERT question
  199. pc III map
  200. Need a good shop in NE Philly
  201. TMAT and turn signals, need help!!!
  202. No Map from PCIII
  203. Super Race Tuner
  204. Poor mileage after tune
  205. Super-SERT-data recording help
  206. tmax help!!!
  207. GET MY GUN !!!
  208. quality tuner in connecticut
  209. Nightrider XIED Installed on my 07 FXSTC
  210. Fuel Guage - What Will It Read Today?
  211. Ultra Passing Lamp Conversion
  212. short in wiring, need guidance
  213. 07 fxstc very strange problem
  214. I'm Confused, need help on which efi controller
  215. SERT adjustment for better throttle response just off idle
  216. Help! PCIII adjustments needed!
  217. Thinking about WOODS TW6>will stage2 download work?
  218. Stage 1 with just xied's for an 08?
  219. Bike not starting after riding in the rain on a 07 xl1200 low
  220. daytona Twin Tec TCFI 3 + WEGO 3D help needed
  221. New version of Super Tuner or new product to be soon available ?
  222. Help!! Mounting PCIII on 08 Ultra with ABS
  223. Fatboy on Fire....Help!!!!!
  224. Poss PCIII error?
  225. In desperate need for 124" MAP
  226. need help!! PC III install
  227. Weird Gremlin
  228. 12V Aux Power
  229. help tuner screwed up
  230. ping at 2100-2200 rpms only...
  231. Add on EFI module failure-anyone??
  232. 95 Sportster Electirical Help
  233. Help Bike not charging
  234. cobra fi 2000r tuner
  235. Throttle pull / idle cable
  236. RKC 2008, accessory plug..
  237. 1993 flhtcu circuit breaker
  238. PCIII and idling too high
  239. 94 Ultra Charging problems ?????????
  240. pinging problem
  241. keep blowing run turn brake modules
  242. 2008 Ultra PCIII Mounting Problem??
  243. Looking for a PCIII map for Stock TC88 & E10..
  244. Daytona Twin scan + wego help
  245. help! need battery 7:00 sunday nite
  246. What's the difference between ?????
  247. how to get more power with pc3usb?
  248. Communication Error...
  249. 32107-01L Tuner vs. New 32109-08 tuner
  250. broke down...need advice
