PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. ecm reflash
  2. O RING for Quick Disconnect on Gas Tank
  3. Light Issue for 2003 Road King
  4. Electrical shock from handlebar
  5. 94 fxdl 1340 cv to tc 88 cv
  6. PC 111 Questions
  7. Will speedo 74717-10 fit a 2007 Softail?
  8. 2012 FXDB (Street Bob) System Fuse Location?
  9. 12V dead short on 2012 StreetBob
  10. Help with a Cali bike
  11. Which wire????
  12. Super tuner pro...
  13. Stuck help
  14. Tuner in Wi.
  15. No power, no nothing, no idea.
  16. Bad Voltage Regulator?
  17. Bagger on a Buget-A frame and a dream in OKC
  18. 98 Evo Starter engages but will not start
  19. Fat boy 2012 smart security manual disarming
  20. LCD odometer problems
  21. Snap On Terminal Tool
  22. high idle 08 touring
  23. Se pro tuner help!
  24. charging or not
  25. Super Tuner Pro Help?
  26. 1998 flhtcui spuddering
  27. Speed Sensor? Speedometer?
  28. 08 nightster over revving
  29. Power Vision wide band kit
  30. Help!! electrical problem
  31. 2014 Ultra battery start problems
  32. Sticky injectors
  33. Fuel moto 107 and tts
  34. tts map ?
  35. Battery? You decide...
  36. Electronic Control Module
  37. Cloth spark plug wires for 07 Softail Deluxe
  38. You get the feeling the MOCO don't love us......
  39. Battery Extender
  40. Electical system fire
  41. Cruise control 1990 Tour Glide Ultra Classic
  42. reflash or tuner
  43. PCV map explanation
  44. Ignition off amp draw
  45. Testing intake air sensor
  46. Late evo starter not pushing all the way out.
  47. 05 FXDLI cranks but wont fire up.
  48. Wiring for 2007 and up Speed Sensor
  49. '86 Sporty Wiring
  50. Finding the right map file
  51. 2011 FLHTCU rotating throttle back past idle position?
  52. FLHTCU Switched Accessory Circuit
  53. Throttle is sticking
  54. wiring ACRs
  55. Bike Completely Shuts off when Riding
  56. HD SESPT (Street Performance Tuner) Only
  57. Stock VE table for 2011 sportster
  58. Kuryakyn LED Run-Turn-Brake Spoiler
  59. 1981 FLT Electronic Ignition
  60. GPS turns off when starting 2007 FLHTCU
  61. Smart tune VE table question
  62. Dyna PCIII & Cobra FI2000
  63. perfromance programmers
  64. Can't connect TTS to bike
  65. Which Fuel Controller
  66. 2014 harley garage opener
  67. Gap for NGK Iridium Spark Plugs
  68. Barrel key ignition lock
  69. PCV download works?
  70. 2011 RKC trouble starting - real trouble
  71. Need Help: Air Horn Stopped Working
  72. 2002 Fatboy w/security system eats up Batteries.
  73. Power when ignition is on for alarm!
  74. pc v
  75. SEPST tuning for a nubee
  76. Fuelmoto efi tuner on 06 street bob
  77. Knocks
  78. Tach question help
  79. Self adjusting ignition tuner
  80. Super Power Tuner or Performance Street Tuner
  81. Pro Super Tuner or Street Tuner
  82. Tuner/fuel management
  83. Needing a dyno tune...
  84. SERT & ECM question
  85. Why "Reset Adaptive air fuel" everytime
  86. Turn signals ok but 4-way hazards inoperable
  87. Street Glide Hard Start
  88. poor idle when hot... with solution...
  89. Bike wont start with VCI connected
  90. 2012 roadglide new TSM?
  91. Aux Light Bar Gremlin
  92. Just tuned my friends bike using the SEPST
  93. TTS or SEPST
  94. power Vision auto tune
  95. Stage 1 Download with Fuelpak?
  96. Normal or needs a tune?
  97. Dyno guy?
  98. 93 fxr brake light is staying on
  99. Pwer Vison with Autotune
  100. Help with V&H Big Radius 2 into 1 map
  101. S&S Adjustable pushrods question
  102. Pre-ignition clicks and odometer LCD weirdness
  103. Lean rear cylinder
  104. Alarm will not engage....
  105. pc3 usb tune
  106. Need Info Please
  107. Battery tender (unplug from the wall?)
  108. Advice needed
  109. Deltran Battery Tender Alligator Clamps (to jump start)
  110. Throttle cable adjustments on 02 FLRT, the manual is lacking major! My first FI bike!
  111. SE Pro Super Tuner - No Communication
  112. cruise control 06 RK
  113. Nice AFR/LAMBDA table please
  114. Sticky Throttle
  115. No Left Rear Signal
  116. HD warranty
  117. Power Vision Auto Tune Pro VS. Dyno Tune
  118. 2008 Streetglide dies at idle
  119. 107 w/o the bottom end?
  120. 107 w/o the bottom end?
  121. 2005 FXD Super Glide Won't Start - Bad Starter?
  122. Auxiliary lights & Turn Signals
  123. Central Florida Dyno Tuner
  124. Idles but stalls under load. need help
  125. Reasonable labor time?
  126. Help with rear led lights please
  127. Charging issues - diagnostic help
  128. bought a wreck 2012 roadglide
  129. SERT Software
  130. 09 street glide
  131. How to Disable the stock Alarm forever?
  132. Is his system fried?
  133. dialing the pv in
  134. Fuel guage to sender question
  135. PCIII Mapping
  136. Timing Drift
  137. Engine shut off problem
  138. Battery tender wiring harness draining battery
  139. Charging 2 Battery's
  140. PV Map creation
  141. Headlight and turn signal issues.
  142. What is trying to quit now?
  143. 1987 Sportster wiring help please :)
  144. Speedometer issue - intermittent failure
  145. Dyno Tuned in Ohio
  146. Mounting Power Vision?
  147. Wiring comparison
  148. a newbee question about SESPT
  149. trouble code u1016
  150. 2003 FatBoy, no electrical power
  151. Dynojet Power Vision?
  152. No fire and no codes on my 2001 dyna
  153. P0373 code
  154. Using SERT with Windows 8?
  155. Dealership says I'm crazy if I don't buy the SE Tuner
  156. Please some help needed for Rear cylinder no fire code
  157. se super tuner probs
  158. Thundermax ECM Thread
  159. Fullsac Backfire
  160. Want Quick Starts
  161. Odometer not working
  162. Cycle Electric, Inc disappointment
  163. Electrical Gremlins....What a PITA! !!
  164. Auto Tune vs. Canned Map
  165. Starts and runs fine, but clicks twice on pre-ignition
  166. Cruise Control 242
  167. 05' FLHRCI, PC III and Me
  168. PCv Map to PV '09 TBW???
  169. No power
  170. charging issues
  171. Battery won't hold charge
  172. Help finding electrical gremlins (06 Dyna)
  173. Stator Putting Out 102V
  174. Rewiring an 82 FXB
  175. 06 Dyna seems to be lean with PCIII
  176. Coil
  177. Power Commander V Drama
  178. Help with my 08 road king classic
  179. Fuel pak help
  180. AutoTune disables ABS on my 2013 Street Bob
  181. To ping or not to ping
  182. Turn Signals
  183. What is this click?
  184. Security Light/Dead Battery
  185. How to flash ECM?
  186. Auto Tuning
  187. 1988 Softail wiring issue......
  188. 09 Touring stalls intermittently/PC5/autotune
  189. Ignition trouble
  190. where to find an ignition modle
  191. SEPro tuned getting po134 and po154 DCT
  192. 2009 Road Glide Starting Issue
  193. what does this wires do
  194. Coil connector type
  195. Acceleration enrichment and spark knock
  196. Newb question: Headlight not working
  197. 06 Electra-Glide when hot doesn't want to idle
  198. Spark knock/ping questions
  199. check engine light comes on and then off again
  200. Keyed ignition illimination
  201. 2000 Road King Classic EFI 'engine' light
  202. Stumped....
  203. 96 flhpi idles fine, accelerates ok, misfiring at steady rpm ?
  204. Clicking Sound....No Start
  205. Vision on 2014 Breakout - Tuning question
  206. 2002 FLHRI wont run right
  207. 2012 Tri-Glide down..Harley can't find the problem..any suggestions?
  208. 96" PV Map Request (Burning a Lot of Gas)
  209. Is This At ALL Possible With This Module
  210. Altima 18-530 electronic harness
  211. Dynojet Direct Email address?
  212. Code P0572
  213. rough idle and backfire thru intake
  214. Help! 2000 Ultraglide starts then quits
  215. dobeck tfi
  216. fuel controller on m and m efi
  217. Vision question
  218. signal stabilizer
  219. Resetting a SEPST...possible for us?
  220. wierd engine noise got worse after oil change
  221. 95 fatboy wont start
  222. 02 FLHRI , missing
  223. What's that whining sound?
  224. diagnostic codes
  225. Fuel tank replacement problems
  226. Brake lights
  227. Battery lasted two years nine months.
  228. Do i need another module ?
  229. Error with DIGITAL GAUGE MIRRORS
  230. Troubleshooting help for 97 Softail
  231. Fuel pump issues
  232. HELP !! Bike cuts out intermittent
  233. Dash lights, turn signals, speed odometer stopped working while riding to work
  234. Need some wiring advice... 82 Shovel
  235. PV Basic AutoTune changes NBF:O & NBR:O
  236. Optimum spark advance Vs. Heat
  237. 2002 UltraClassic Electrical Issue
  238. Engine Dying
  239. Ultima Electronics
  240. Bike wont start
  241. Ignition Question 85 XLX 61
  242. '03 Ultra chugs/misses at low speed/RPM
  243. Installed new twin slash V & H pipes and SERT
  244. excessive vibration
  245. What to do....looking for Tuner suggesstions
  246. 08 e-glide, voltage reg. Wires
  247. Updating Heritage
  248. top brands of wire harnesses for mod Harley
  249. V-Rod gauge cluster on a Road King
  250. 62349-04F O-Ring
