- Electrcal issues
- Do I even need to smart tune my VE table?
- Shuts off when hot won't start till cools off
- heritagsofttail taillights
- What am I missing?
- Throttle Roll Back sensor
- Elec/gauge/charging - prob
- steady throttle hot engine miss
- screaming eagle race tuner
- engine oil in carb.
- In Front of Walmart & Bike Won't Re-Start
- Cranks but wont start
- Cannot retrieve engine codes...help please
- 98 Sportster NOT Charging but Stator and Reg test fine?
- 87 FXR ignition problem
- Error code p0263
- FXDFSE2 starting issue
- XL1200N Battery Drain
- Interchangeable wire harnesses
- Won't start, head light out, indicator lights out
- Tuning - Need Help!
- check engine / battery light electrical problems
- Intermittent starting problem
- Bike won't start!!
- 01 Electra speedo
- 1986 HD 883 Hugger w. a 1200 kit
- Super tuner pro
- Ultima Electronic Wiring System #18-533
- Wrong CKP, but will it still work?
- Lemme ask this a dif way.
- Starting Issues
- fxdb street bob electrical fuel problem
- Back Up
- TTS table adj question
- 2001 ultra classic turn signals and cruise
- Checked Diagnostics codes, needing help to fix the problem. Please
- Check Diagnostics codes, needing help to fix the problem. Please
- Is my ECM Shot?
- Fuel pack Idle
- which ignitions are best?
- FLHTP Horn wiring
- Stock EVO carb question
- Ultra dies when slowing down
- ? rev x-tend on pcv
- 75 Sportster want start....
- Speedo acting nuts
- 04 Softail TC88 won't start
- Fried Stators
- Kolorado Kenny's FLTCU Cam Sensor
- Irregular voltage readings
- Need a little help. charging issue.
- Starting wiring
- ignition problem
- Starter Solenoid won't fully engage
- V&H Throttle Pak
- short on my 04 Haritage classic
- swithing one security from 1 bike to another
- Code ?
- "ide stand" code
- dobeck TFI group discount
- Won't start, "SIDE STAND" message
- brake light issues
- dyna 2000/tc88-2P knob help
- Questions about Thundermax
- Sensors?
- 'ticking' valve or worse?
- Stock ecm 07 FXDC
- voltage regulator?
- ECU shut down
- V&H Fuel Pak Question
- 2006 FXST/I idling/running issues....help!
- WTH? Electrical, power loss, ?? 1987 fltc/I Tour Glide Classic
- 2006 Road King
- Right turn signal issue?
- 2000 Sportster 1200 flasher issue
- Turn Signal Module
- IED to XIED..worth the work?
- Battery or Alternator
- Thunderheader/Electronic Question
- 98 superglide electrical issue
- Coil, and module help
- difficult start when hot, EFI
- 05 Heritage Softail Tuner and bung question
- 2002 Fatboy - no click - no crank - no start
- 1995 Road King help
- Shorai Battery
- 2002 FLHTCU Sputters
- Is my PCIIIUSB broken?
- Best Coil TC for 88B
- 99 fxdx - #41 engine code
- Key Fob issue
- Battery?
- no fuel pump
- I need some help with electrical
- Fail to start!
- Diagnostic Test Lamp
- P118 engine code
- 07 deluxe occasional quits going down road
- Road King Sputtering
- Code p118 et sensor high/open
- poor fuel economy
- 1996 Sportster rear signal relocate
- "Internal Contact Switch" for '94 Softail
- died and wont start
- Sepst Software Smart Tune
- Need Some Quick Help
- laid 95 bike down and now it wont start
- Bad regulater
- 07 Dyna died while riding and now won't start
- 2011 Blackline problem
- Anybody have any experience with these folks?
- Need Troubleshooting Help
- ironhead problem
- 2006 dyna spits,sputters,backfires, fouls plug
- 02 Deuce, carb, Hard start
- replacing turn signals on 92 sportster...
- Adding cam to TTS tuned bike
- Left signal flashes rapidly and security icon lights up when ignition is turned on
- 07 Lowrider Taillight Harness Part #?
- 06 Ultra Electrical Question
- Battery wont stay charged overnight
- 97 FLHT No spark and fuel pump doesnt turn on
- Check engine lite
- bike still dead
- Headlight Issue, help needed...
- 2000 Ultra Hestitating at Low RPM
- intermitent starting issue
- Left turn signal stopped working...
- Running problems
- Thundermax TBW Map update question
- Near stall, misfire
- Headlamp & Gauges Outage
- Engine Issues
- 2002 EFI Heritage sputter and backfire
- after warm up
- o2 ultra rear cyclinder flooding
- 2011 883n brake light
- headlights and tail lights stopped working
- 2003 Ultra Classic- Major Electrical!
- Tune Help, Stumble and Stall at Idle High Temp
- HD883 03 Sportster
- headlight switch
- Problems starting
- Mm related?
- Is the ECM year and model specific?
- Super Tuner Map needed Stage 2
- Removing front directional
- 2010 Dyna 3 wire brake/taillights
- Rcx-celerator question
- 1972 xlch
- electrical for 75 sportster
- power vision question
- 99 FXDX not starting
- Gas Mileage strangely increased then decreased without warning
- Voltage observations
- Battery Discharge
- Twin Tec TC 88 USB interface cable ?
- Efi problem....
- Dyno Tuned
- backfireing
- Closed Loop Bias question
- 06 Night Train fuel injection
- map for 07 deluxe with 48 cams
- Buying bike thats been programmed
- Mini Tach Problems
- Throttle Body for HP gains? Really?
- WIRING GURU: question for 2009 Fatboy
- Sputters and back firing
- HELP! My baby is trailered. :(
- Lost Keys
- No Speedometer/Trip Counter
- ECM learn password help
- No Brake Lights when Headlights on? Help...
- 2007 ultra classic fuse keeps blowing acc fuse
- EFI question
- throttle position
- key switch turned off but head/ tail lights still on ?
- Is There A Map From MoCo For This Setup?
- Can anyone identify this setup?
- Alarm on bike RK 2003
- Sportster stator vs regulator
- Power Commaander V and Warranty?
- 2012 Electrical Problems?
- Looking for Tuner in NorCal
- Se pro super tuner question
- Need help wiring up a Heated seat to my 2005 Ultra Clasic
- 1986 FXRS misfiring/backfiring under throttle
- 2003 Fatboy EFI Coil
- 2002 fatboy fi starting problem
- Electrical melt down
- check enhine light after replacing starter
- sceamin eagle super race tuner
- Lost speedo, tach, horn, and rear lighting
- 2002 FLHRCI - engine code 23 - front injector open/low
- Softail Carbureted Main Wiring Harness Question
- Flasher Location
- daytona twin tec question
- Dies and restarts after a few minutes,Help
- 1982 FXS starter won't turn over engine
- FLHT ignition problems
- Injector info
- Maxflow air filter - retune?
- Who has V&H Throttlepak in stock?
- 78 FLH Front passing light and directional issue
- Headlight Bright Indicator
- Throttle Grip Sensor
- Running Light Fuse
- Help 2004 Dyna stage one
- test help
- Please help with PV
- starter issues
- self tuning PC III for cam upgrade
- 04 road glide loosing fuel pump
- Super Tune + Screamin' Eagle Slip On's and .... Air Filter?
- 2005 American Ironhorse Texas Chopper Ignition Issues???
- Power needs..
- Can I Replace My Old Tour Pak Lites With LED'S
- Decel Pop/Tuning PCV Question
- ECM issue? Not getting 12V at Term. 30 on System Relay
- HD Techs stumped?
- Removed fuel tank on 2011 FXDWG now won't start
- Nightster Charging issue
- PC V & TACHOMETER maxing out @ 5000 rpm
- Right turn signals
- Turn Signal Problem
- Help with TSM code
- 2005 sporty custom blowing no 2 fuse
- Issue with starter 99' Softail Custom
- RPM Spike/Engine Shut Off Issue
- Need help in building a LED lighting bike
- circuit breaker nightmare
- Does powervision learn?
- 09 Headlamp Problem
- Blinkers shut off by themselves........
- 1996 FXSTS Speed Sensor Location
- Electrical Issue - 2009 Road King
- Weird Fuel Mileage Issue
- PCV map recommendation?
- 2012 Ultra Classic mods, which comes first
- TC88 electrical fault
- wont start
- 26G Ignition Question
- Troubleshooting Voltage Regulator & altenator
- mikeyel
- Light Issues
- 07' ultra won't start
- Tachometer on 2000 HD883 stopped working
- PCV and AutoTuner question
- '03 Deuce - Starting circuit? charging circuit? issues
