- PC V install question
- Alternator
- Need help retrieving codes on 03 rk
- Frustating Electical Issue, Help Appreciated
- turn signal works but wont blink?
- Turn Indicator Bulb Won't Turn Off
- adding O2 sensors
- Overheated coil, misfire rear cylinder - help!
- ThunderMax for '08-up Touring, What's up?
- looking for a tts map
- need pcIIIusb help
- Need Help
- Wire heat shield
- fuel range function MIA
- PC III problems
- HELP! Electrical issues...lighting
- '04 Road King Exhaust/EFI Question
- Local Dealers will not do the Stage 1 download?
- Need Map 105HK028.XXX.MT2 for the SE Race Tuner
- Pc3
- EFI Engine Heat Management on 2006 Heritage?
- Tmax/TTS
- Best Battery ??????
- TTS for Stage 1
- 07 screamin eagle has a intermittent miss
- Battery/Charge Question
- Bike Hesitates, sputters, and coughs as accelerating
- VRod Stalls
- Bike is stalling when turning and riding
- '98 Fat boy electrical problems.
- Posting for a friend
- 94 sportster 1200 xl no spark kindo of long need help!!
- 73 Ironhead won't start everytime
- V&H fuelpak insight
- ECM Dielectic Grease
- Battery toast?
- 911 - fried o2 sensor, need help!
- Thundermax rocks!
- Tips Advice on Installation PCV and SE AIR
- @*%$ Starter/Electrical
- Can TTS edit the ABS "mapping"?
- SERT Guru's question
- Old Style SERT - When does it marry?
- Unusual Question about HD Electrical Systems
- Speedo Out of Whack
- Can TTS change speedo for bigger tires?
- help me please ,im having spark issues
- Can a 2009 96 be changed over to a Carb ?
- Head Light discoloration
- KEY Indicator light came on briefly
- Engine light now bike won't start
- Bike won't start and bad clutch
- PC3 help
- Tail Light Problem - Water in casing
- SERT fix or do I need hd dealership fix?
- Custom Tailights/Turn Signal Help!
- Battery Killer?
- ECU or Wiring harness
- Oil and gen. lights
- Monster Ovals. Proper dyno probe insertion ?
- Ignition module gone??
- Idle too low
- Indicator Light Problem - Don't Blink
- RoadGlide Problem
- Head light problem
- pc3 map 05 vs 04
- 2006 Harley-Davidson FLHTCUSE Screamin' Eagle Ultra
- EITMS Idle Heat Management - Stall [Any TTS/Tuning Solutions?]
- Power Commander 5 Map
- How to disable auto cut signal light
- head-quarters electronic ignition 21835
- Synchronize VE with closed loop BIAS table changed?
- Major electrical problem!!!!!!!!!!!!!!
- Dynojet Blowing Ignition Fuse
- Running Lights Question
- Turn signal issues after heavy rain 04 RK
- Forgot the load equalizer
- 09 Iron electrical problem
- Does the ECM reset?
- Turn Signal Brake Module doesnt work
- Trailer lights
- EFI Manifold Mounting Question
- Help! With a weird problem
- Pc iii usb
- Chirpless alarm
- pc3 map change
- LED upgrade troubleshooting help needed
- Dyno and AFR setting
- sert or sest part numbers
- Fuel Mgmt or Not?
- What does an O2 eliminator?
- 8* or 25*
- Need sest map
- ditching EFI..
- o2 sensor question
- SE Pro Super Tuner Problems
- 96 efi rough idle
- No spark evo
- Super Tuner ECM error
- Cruise control not engaging
- Fuel Pump/Electrical issue
- Stalling, Low Idle, and High Idle
- No Crank!
- Correct voltage?
- Pinging?
- Spitting and sputtering
- All Electrical flickered, stop, later started up, now nothing
- power commander and popping
- 2002 roadking classsic fuel injected ant info
- TSSM to TSM swap part number
- 04 wide glide intermittent engine stall!!!
- Help, Looking for PCIII map.
- EVO EFI PCIII Help
- Ignition wiring...is this right?
- Coil wire to ignition switch...???
- Advice needed.....
- Passing Lamp Mystery
- Right turn signal light won't work
- '08 Fuel Gauge in an '07 FXSTB
- Where's the best place to get auxillary power?
- New vs. used ECM
- SERT Dyno Tuner help N.W. Ohio/S.E. Michigan
- Loud Popping/Backfire when Starting
- SERT/SEST Tuning Help Requested
- Best Option?
- Led fuel gauge
- O2 IEDs + Fueler
- intermittent MIL on startup.
- New '09 Rocker C, Big Radius Pipes, Air Cleaner, and SE Race Tuner
- Does the SERT learn?
- wiring additional lights in the back
- 781/2 fxs ignition switch
- Turn signal problem
- PC III question
- o4 wideglide just dies
- Kury LED license plate bolts...
- RSD Venturi Air Intake - Softail
- Cruise control will not engage
- Impact of changing out slip-ons.
- Fuel consumption drop
- USB cables... ???
- I'm baffled
- SERT and TBW question...
- New Harley Rider - Battery Question
- Cold Start Problems
- Connector confusion
- SERT map and adjustments, DIY info needed
- Will it Run?
- replaced ignition coil and still shuts off after it warms up?!?!?
- Positive Battery Cable Gets Hot!
- studder and sputter
- PC-V Maps and Super Sert
- Spark Plug Replacement - HD Screaming Eagle
- 08-up Black Fuel gauge ???
- Hand Control Switches 96-06 and 97-up ???
- ultra wiring
- 08 streetglide
- F the PCIII
- 2008 Softail Custom with failed brake lights...Help!!!!
- how do i check my code on 07 fatboy with thundermax?
- bike popping at steady throttle?
- Ignition question
- Battery Issues
- fuel pressure light comes on while engine is running
- Daytona twin tec
- wiring..
- Blinker staying on
- Low end torque
- Regulator Wiring
- Fuel Guage not working
- 3 years with FI
- lost spark
- Tuning Questions (sert)
- Getting HD download versus Fuelpak and PC3
- Need help find this connector for a light install
- Ignition Timing
- power comander question
- Power Commander IIEX v. III?
- looking for tunner
- Mechanic says "don't worry about fuel management system"
- Show me how to get AUX power (pics)
- Can't disarm alarm
- Current Trouble Code
- Electrical issue on 06 sg thanks
- Detonation or not
- Am I going to blow up my bike if.....
- Converting Spike air filter for carb to EFI???
- Stage 4 Map
- Anyone tried RideMaxx tuner?
- ECM Pinout/ serial protocol
- Looking for a SERT (not SEST) map
- Coil Relocation for Softail Question
- Which is the best Tuner and Why?
- Low Batt/High Volt Codes
- left side turn signals not working
- 2 wires in 1 amp pin
- Unlocked TTS for workshops
- PCV mounting location
- EFI to CARB
- ECM swap: is it OK?
- What is this?
- pcIII tuner needed near Columbus Ohio & BCT baffles
- 01 road king
- moly content grease and electrical connections?
- Engine light and sucurity light??
- twin tuner or power commander
- 68 sportster won't start
- Rear Turn Signal Connector Removal???
- throttle reset
- Im Lost with the wires!
- Headlight harnes wiring diagram
- t-max problem
- Nightster does not start after wash
- Bravo Zulu
- speedo
- Click, click, click-not starting -bad switch ?? 1996 FLHTCI
- programmer with new pipes/filter
- Error Code ?
- Tuner
- Vance & Hines FuelPak on a Rocker
- Morris Magneto T-5
- Code issue cvo 08 springer
- Lights - Fuse
- 2009 Street Glide surging problem
- Vexing Starter
- Stage 1 reflash specifications?
- What happened to my post???
- wiring 06 ultra, running lights
- Ignition timing
- I Recommend the V&H Fuel Pack
- Complete electrical loss
- Throttle cable install w/o lifting tank?
- Need a map please PCIII
- IAT sensor ?
- engine fault light
- Who owns the SERT MAP ?
- 2003 dyna coil test
- Headlight wiring
- Hello. I have a voltage regulator question...
- pos pcIII
- Cam's and the PC-V.....
- Mystery Misfire... fun, fun, fun... NOT!!!
- Odometer Reliability
- V & H Fuel Pak Fitment
- Bike shuts off while riding, need help!
- pc3 v&h br 2:2 se heavy breather 07 fxst anyone got a map
