PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. 14 48 started idled then died. Wtf
  2. Ironhead won't start, no cranking.
  3. 2007 Road Glide help / fuel pump bracket
  4. Harley quit
  5. Take a look at these plugs
  6. Clicking Sound on and off
  7. 1995 80cu.in. EVO, ECM compatibility
  8. Multiple fault codes, possibly bad ECM?
  9. HELP!! 044aao003 or 009fz002-001
  10. Help in Bakersfield CA, PC-V and idle_oops
  11. lean question
  12. AFR Plus Gen 4
  13. 94 Sportster Misfire/Ignition problem...Cam Sensor? ECM?
  14. Won't return to idle after WOT event.
  15. B2119 fuel pump overload
  16. Sportster issue PO562
  17. 2007 xl883l rough idle
  18. 07 Road King Hard Start
  19. Gas leaking on a 02 softail
  20. DTC codes
  21. narrow band location
  22. 1993 FXRS no power
  23. Nightster/Sportster, Vance & Hines Side Shots, and Wideband O2 sensor fitment (or not)
  24. Question about tps
  25. Fuel pump whine run on
  26. Won't Rev up.
  27. 2001 FLTRISE2 miss fires HELP
  28. Fuel Pump issue on 2007 sportster
  29. Replace one injector or both?
  30. 1983 sportster not firing
  31. Question about Power Vision Guages
  32. Help a Beginner
  33. Help Please! 2000 Harley Davidson XL1200S
  34. 2011 Sportster Will Not Start
  35. Best high octane fuel low ethanol
  36. Dyno in ct
  37. 2010 Forty Eight Not Starting - Not Getting Fuel - Help
  38. IAT code
  39. Screamin Eagle Air Filter
  40. Target tune
  41. Need help finding a cool for my iron head
  42. 2005 road king sputtering
  43. Help with ECM
  44. tachometer speedometer lights are not working now bike won't start
  45. Road King '06 won't crank
  46. Target tune install pics; Touring bike
  47. Ignition switch
  48. Coil
  49. 93 Sportster having troubles starting
  50. No keys
  51. Cam Positioning Sensor Bypass
  52. 1984 FXST EVO 80 and ignition timing...
  53. HD 32400-80 Ignition Sensor
  54. Sportster won't start
  55. Won't start after body work
  56. 2003 FLSTFI Injectors not engaging
  57. 2012 Dyna Wide Glide won't start
  58. Just a P0134 code
  59. New ECM will not flash. Help!
  60. Few Questions same topic, Fuel related...
  61. ACR's not sure if they are working
  62. Cost to replace an ECM
  63. Rear O2 sensor FC
  64. Screamin Eagle Ignition module for TC88 in EVO frame.
  65. 2001 flht
  66. Blown ECM fuses and voltage on ECM when fuse pulled
  67. Tuner
  68. 2005 Sportster chopper wiring
  69. Tachometer Voltage at Pin #3 on Speedometer - 2011 RKC
  70. electronic timing issue
  71. Rich and Lean
  72. Fuel Moto E-Series Slip ons - non fuel moto purchased Dyno Jet PowerVision
  73. Did I make a mistake?
  74. 2009-13 Touring models, 103 vs 96...
  75. ACRs
  76. MAP sensor cleaning
  77. fast hesitation
  78. Ignition switch accessory position
  79. My new FXSTDI has a carb!
  80. Sportster hard to start and stalls while riding
  81. O2 sensors on bike without originals?
  82. 1998 ultra runaway idle
  83. help trouble shooting ignition problem
  84. Need experienced wisdom!
  85. Power vision screen not working after rain
  86. Single or dual fire ignition
  87. 99 Road King ignition module
  88. Questions on ECM replacement...
  89. 2nd Bad Stator
  90. Harley SPORTSTER 2007, Lost Power + Backfire + Engine Stalls when push throttle HELP!!
  91. 8 degree vs 25 degree injectors
  92. Mystery problem with 98 Roadking solved
  93. Bike won't start after a wash?
  94. 95 RK no spark help?
  95. High altitude high temps
  96. Knightster wont start
  97. cylinder offset
  98. Throttle hesitation
  99. Compu Fire 2000 Sporty
  100. ACR connector
  101. HI-4N Ignition S&S Timing
  102. starter bad??
  103. Check Engine lamp persists - Code P0113, Delphi EFI system...
  104. Intermitant hesitation
  105. intermittent backfire 2002 95cu in
  106. 2005 FXDLI won't start
  107. Starter / Fuel Pump Issue - 2000 Road King Classic
  108. Is the ignition on a carborated sportster the same as fuel injected?
  109. 2012 Street Glide dies
  110. Really hot 110 with seemingly good tune.
  111. Starter just clicks battery charged? Help
  112. Intank Fuel Lines Leaking
  113. Has spark, fuel pump comes on. Won't start 2006 Street Bob
  114. 2010 FLHTCUi Loses power
  115. Softail EFI fuel pump plate cover 75132-01D
  116. Tuning school for PowerVision?
  117. Looking for help
  118. P1356 No Combustion rear cylinder
  119. 2016 tri glide misfires & rich
  120. new ecu
  121. running on 1???
  122. From LV Nevada
  123. no start
  124. Anyone using the FP3 with a Nexus 5x?
  125. Coil replacement 2008 Ultra Classic
  126. Problems with Daytona Twin Tec?
  127. 13 cvo breakout crankcase vent bypass ?
  128. Fuel leaking 96 EGUC
  129. no start condition after sitting for awhile
  130. Ecm programming problem.
  131. Weird problem I can't figure out
  132. 1999 Road King EFI Help
  133. Backfire through intake
  134. FP3 and CFR's
  135. Bleed air out of fuel line
  136. starter/jackshaft issue
  137. 2008 Fat Bob needs help!
  138. Throttle Posistion sensor
  139. Broken Throttle Cable - 2007 -
  140. Back cylinder not firing
  141. SE air cleaner - oiled last cleaning (DOH!)
  142. 2011 sportster rear injector not fueling ?
  143. Thunder Heart and Mikuni HSR45
  144. 99 Sportster Crank crank Boom
  145. Power Vision broken screen, replacing, new adventure
  146. Im fu%$&ing stumped
  147. 1.5" Handlebar Mount for Power Vision
  148. ECM dead
  149. 2002 RKC-EFI Misses once hot
  150. Down and out in the Laconia Hills
  151. Ignition switch
  152. Cleaning fuel injectors
  153. Pulsestar plugs???
  154. 99 Fatboy Stalls after start up
  155. To head or not to head?
  156. WD40 and no ignition - help needed
  157. For those running the 1407 MAP on fuel pack tuners.
  158. Tuner - 2001 flhtcui
  159. idle on 14 fatboy
  160. Dyna FL ViED 10 pictures please!
  161. fuel filter cross reference
  162. Do I need to change fuel injector??
  163. Shout out:Dynojet PC-V
  164. Dead miss on idle w/110
  165. Engine misfire
  166. engine missimg no load
  167. injector diag
  168. 03 deuce Fuel Inj Sputtering Coughing low RPMS
  169. Timing and ticking
  170. Ignition issue
  171. Causes of long cranking
  172. Low Rider S problem
  173. 1999 Sportster 1200 / No Spark
  174. Help with dtc P0641
  175. 1998 FLHRCI 95th Anniversary fuel pump HELP!!! PLEASE!!
  176. a couple more questions
  177. 2007 ultra classic running on one cylinder
  178. codes , check engine light
  179. Sorry Idle Lope w/MM Ignition and SS 510
  180. XR1200 firing issue
  181. 2005 Fatboy sudden problem
  182. 2007 Softail Won't Start
  183. TPS Replacement Suggestions...
  184. intermittant stalling at idle
  185. Is my starter dying?
  186. Engine just stops
  187. 2001 Road King stalling at idle
  188. Finally riding again.
  189. 2010 883 Iron Battery dead, won't start with jump
  190. O2 sensor
  191. Leaking Fuel Lines - xPOST TOURING
  192. Sputtering when starting from a stop
  193. Can anyone tell me what ignition this is
  194. Thinking of changing my afr from 14.0 to 13.8 to run cooler, will it help?
  195. 2012 Sportster Custom Ignition Issues
  196. 2016 FXDB Idleing at 2300 all the time
  197. Surge slightly off of idle!
  198. fuel injected or carburated
  199. Dtc p0134 and p0154
  200. 86 fxr won't start
  201. Top End Motor Lay Down
  202. Relocating Softail Slim FLS ECM
  203. Power vision auto tune display change?
  204. Screamin' eagle performance parts
  205. '05 Springer Classic running like crap at 50 mph
  206. Injector Pigtail Part Number
  207. Ignition sensor pickup 96 fatboy
  208. Throttle problem Freewheeler 2016
  209. replacement fuel pump
  210. Looking for a PV map for 107 Head Quarters
  211. lowest AFR at idle
  212. Put on bars with internal wires and it won't start now
  213. Won't stay running
  214. 2012 Street Glide ECM Module
  215. 09 Ultra no front cylinder when <60F ambient
  216. New to HD with an all stock 07 FXDC
  217. O2 Eliminators
  218. Runs out of Fuel
  219. Need sportster help bad!
  220. Where are my SESTP recordings going?
  221. Air Cleaner for 2016 103HO
  222. Running Way Too Lean... suddenly?!?!?
  223. Sputtering and misfiring on a whim
  224. Stuck. Bike Won't Start.
  225. 2009 Sportster fuelpak problems
  226. do i need to retune?
  227. Help! Front left signal out, back left blinks normal then fast
  228. Can anyone please explain to me...
  229. Active Exhaust
  230. 77 ironhead starting trouble
  231. 2014 Breakout ECM Schematic?
  232. Cant install Powervision?
  233. Posi tap - wiring size - 08 touring
  234. Tuner choices
  235. A/C Choices
  236. 2000 harley ultra no spark
  237. starter button won't crank motor
  238. HDF Dyno and Tuner Shop Locator
  239. Andrews 48 cams
  240. O2 eliminators
  241. SE 58mm Throttle Body Thundermax Map Tuning Help
  242. Removing ignition again
  243. Idle surging on new build with SE race tuner
  244. 48 CEL and sputtering
  245. ignition coil bubbling
  246. New to me 13' FLTRX loaded map
  247. 107 rebuild spark no fuel
  248. Dyna low rider . HELP HELP HELP!
  249. Need a quick review of what I did - PV/SE110
  250. Optimum AFR
