- ThunderMax not working in closed loop
- SERT Map for Rineharts
- Question on Stage One downloads in 06 bikes.
- Race Tuner Error
- What would happen if PClll failed?
- CONDENSATION IN GAUGES
- 08 ultra: security siren mod
- eliminator on 2008 kick stand
- t-max software
- accelerator pump/ ignition for pc3
- Which SERT do I get?
- Advice on Performance Ignition Systems
- Sparkplug choice
- 2003 Delphi Problem
- heat sensor
- need help
- Posting Datalogs
- stage 1 muff..stage 1 air..can you??
- power commander map question
- I have a question.....
- O2 sensor DTC P0131 & P151...need help
- how to set thundermax timming
- Vista and Sert Question
- Racing Tuner
- Length of plug wires?
- conflicting advice on STAGE I
- Dakota Digital Speedo install
- PC III on Rocker
- Brake light stopped working
- Yet more SERT questions ??!!
- Direct Link Software
- sert on a 103 tc
- PCIII Wide Band Controller with O2 sensors!
- King tour pak wrap around light unit
- Where can I Download SERT maps?
- 01 Sporty 1200S Charging Problem
- I need advice
- Smart Security Install question
- Super SERT manual
- Stock ECM calibration 2008 SERK-same as SERT calibration?
- SERT NIGHTMARE
- Has this happened to you???
- 96 FLHTCI ECM upgrade:
- '07 FLHRS SERT Mapping Questions: Hard starts, Surging and Soft Throttle
- Neutral/6th Gear/Security light intermittant
- Volunteers - 07-08 SERT map for your pleasure
- New Super SERT - pics
- 1989 solenoid gremlin
- help with horn not working
- Amp gauge has 3 wire... Do I need to ground
- PC III problems at altitude
- PClll questions??
- electrical problem - ignition switch?
- SERT tuning constants for CVO FI
- Turn signals.
- SE Sportster Ignition Install?
- Downloading process Stage 1
- Please Help HD smart security system
- spark plug wires with braided out cores
- Just bought SERT and price dropped???
- Question about download?
- speedometer trip meter changes when bike is turned off
- 07 Roadglide positive fuel pump wire advice and desc needed
- Too many choices, ECM tuner
- 74 Sporty point's question
- Pinging with SERT & Dyno
- Has anyone had any issues with thock 02 narrow bands.
- Turn signal wire repair help needed
- Neutral Light out
- Signal lights
- Batterynot charging on 2k7 fxdwg inj
- Stage 1 down loads for 07?
- How to adjust 99-01 TPS?
- Battery ????
- PCIII use with O2 sensors?
- Mikuni Carb help
- Clicking sound when attempting to start Sportster
- K&N
- PCIII Maps with K&N RK 3909
- S.E.R.T. Question
- any help with a map
- Where's the fuse box???
- speedometer sensor question
- Up and Running
- speedo
- Cruise control help on an '05 RK Classis
- How to wire custom chrome handlebar controls
- Fender tip light
- Signal Problem
- second generation fuel injection??
- NEW TACHOMETER
- Initializing Tmax
- pcIII: i need map for: 883+...
- fuel consumption issue
- PCIII to SERT
- Spark plug wires??
- status of SERT Pro shipping?
- For you guys debating SERT vs PCIII
- SE EFI Super Tuner
- Which map to use on 95" build
- T-Max & dead battery
- Canned SERT map for my Fatboy
- Power Commander
- Bike Surges
- Regulator ?
- Screaming Eagle Race Fueler
- DAZED and CONFUSED
- looking for post on coils
- PCIII Tuning
- vendor recommendations (starter)
- 02 sensors & Nightrider IED's ????
- new bike question/ good choice ??
- Panacea Taillight
- Nostalgic Face Speedo stays on??
- Daytona twin tec tcfi 3
- Dyna misfire
- Need a New Battery for Deuce, any suggestions??
- NEED SERT MAP
- PC III "no map loaded?"
- Race Tuners,power commanders, etc
- SERT: Mission Accomplished...
- Can sert raise your rev limiter?
- Dual plug heads to single plug heads
- Cruise Control not working
- Take a look at this SERT Map
- EFI and Baffles
- sert usb info needed
- Switching bikes? can u switch with same sert
- sert communication problem
- Passing lights question
- HDI or DOM wire???
- Fuel Pak?
- Looking for Tmax firmware
- Taller bars with fly-by-wire
- Harley Davidson Race Tuner File Choice
- Fuse Box
- Setting Throttle Position
- Need a SERT map for 08 sportster
- 05 Road King SERT - Need two maps
- ENGINE DIES AFTER A FEW SECONDS
- Anti theft system turned on
- Disconnecting battery with PCIII
- Battery Tender junior
- Idles too fast
- SERT Question...
- Found it!!!!!!!
- Simple 02 sensor question
- SE Download on "06 Ultra
- Head Quarters Pro Tuner or Dyno
- SERT - MAP Choice Help
- Intercoms?
- Adding A Tach
- Just got my PCIII now what?
- Indicator Fuse popping '07
- Solar charger ?
- AIM article questions
- fly by wire throttle issues
- SERT v477 link
- engine light , ecm code
- Newbie throttle questions
- License Plate Light Wiring
- SERF for 08 Ultra?
- Install of Aftermarket Single Wire Turn Signals
- Ignition Timing Question
- Help with "Accessory" wiring. (2007 Ultra)
- hard start after PCIII rt
- My Brand New Terminal Velocity II arrived today....NOT
- Looking for Good Dyno Shop
- SUPER Race Tuner...
- Timing Adjustment
- PC III 08 Sportster problem
- Dead battery, new bike
- Am I crazy
- Lost head and tail light at once????
- '99 Heritage signals wont flash
- cobra fuel mangement
- Starter for WG
- Re-Using Ignition Sensor Rubber Connector Plug, '88 Sporty
- Map for sert
- Just ordered my PCIII !
- BORING OUT MAGNETI MARELLI EFI
- Tailight issue
- fuel injection wiring
- tach signal question
- SERT for 08 FLSTC
- ecm
- Poppin' Problem
- Security Light Coming on
- Running lean using V&H Fuel Pak.
- Hogtunes Amp and Speaker issues
- H-D ECM Download
- help, im braking!!
- 96 Fuel Injection
- cold start
- Next SERT will not have CD
- pc111usb tuning question
- 06 Dyna... unsure of Map for PCIII race tuner
- Hesitation, Skip, Hicup
- Anything i need to do or check....
- need a ECM for a 99 FLHTCI
- PCIII problem on '08 Touring
- Rear Stoplight Switch
- Direct Link
- 01 FXDWG: Speedo Broke and Lights flash 6 times
- PC III ?
- another thundermax question
- What rev of SERT will work with 07 96'ers
- PC3 issues.
- T Max with 124
- SERT MAP Versions - need latest map
- Just Clicks
- Dobeck TFI Installed on '08 UC
- GMR 107 the way to go by the looks of it.
- 4 pin -Accessory plug???
- Erratic Engine Light
- SERT question(s)
- Stereo Volume Control Problems..
- Chain or gear drive cams??
- TMax high rev on startup - fixed
- 2008 XL 883 Sportster PCIII Map
- Power commander install on a used machine
- Installed my PCIII tonight
- Hunting/Surging problems 2008 Heritage Classic
- Tachometer
- Vance & Hines Fuel Pack
- Battery Dying Affect Security System & Fuelpak?
- Pinging - Need a new timing map
- Average lifespan of a starter?
- Harley Download Question
- just quits?
- Thundermax poll
- breaker issues?
- p1510...p2138
- brake light
- EFI TO CARB
- Replace 8 Degree Injectors or Not?
- T-Max Basic Settings and Tuning
- Engine stalling at different time.
- kickstart with dyna2000 (dynatek)?
- Decel Popping with map change with SERT.
- Getting "BUS ER" when installin road zeppelin
- Virgina Race Tuner and Dyno
- front speakers not working
- big city thunder baffles
- ign map for carbed dyna
- Lighting question
- Electrical issues
- harley cone shaped air cleaners
- ECU/ECM Mapping and Tuning
- Tmax Experts
