PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. TMAT map for 103 with Andrews 54H?
  2. at home ignition change for 2005 softail?
  3. What cables?
  4. Starter Delima!!
  5. ThunderMax sorrow
  6. 07 dyna can a starter be broken down for plating
  7. Problems setting TPS on 2008 Road Glide / PCIII
  8. Wide band
  9. Dealer Install, 2/1 Super-Trapp exhaust, a/c, and the super-duper
  10. Looking for HP numbers
  11. H.I.D head light bulb
  12. TTS Owner Install Results...
  13. Power Commander V - Its Here
  14. Question on throttle position sensor
  15. Simple PCB III Question
  16. Cobra Fi2000 or TFI??
  17. Tuning dilema.
  18. Help! Engine miss.
  19. PCIII help. Engine light stays on
  20. PCIII+protuner vs supertuner+dyno vs mastertune
  21. TTS Mastertune map?
  22. 2003 Deuce not charging Is there a way to test Regulator/Stator
  23. Ignition advance curve
  24. speedo, tach, engine light, battery light, security light!
  25. need high output stator
  26. Battery issue?
  27. 2006 EGC Radio pre-wired
  28. Poor TMAX MGP? Check your speedo/odo calibration!!!
  29. Battery Tender under Bike Cover?
  30. Regulator
  31. Head/Tail Light Fuse keeps blowing
  32. Follow Up on the good running 2007s
  33. '08 XL1200N, PCIII, popping, and choking at cold start
  34. TTS Price
  35. TTS Mastertune
  36. Installing smart security on 007 ultra?
  37. confused in pa
  38. Alarm Issue??
  39. '09 Street Glide accessory switch connector?
  40. 06 Heritage Blown Ignition Fuse
  41. PC111 Advanced Map
  42. Harley PN 74549-04 Tach/Speedo Indications
  43. timming perfect.
  44. Headlamp out
  45. TTS Questions
  46. Turn Signal Mod
  47. ION Sensing Ignition Subsystem 20007 FXDC - How to Troubleshoot
  48. ECM fuel/electrical? nightmare
  49. Stage 1 Download, Enough?
  50. Help!!
  51. 2006 FXDL speedo/tachissues
  52. Not sure!!
  53. tmax
  54. Need EFI Advice/Recommendation
  55. Need a PC III Map - 103 BB
  56. Need Help - No Start, No Power!
  57. 2007 FXDC w/FuelPak - Ran Fine, Now Pings (Detonation)
  58. Acquiring a Simple SERT Printout
  59. PCIII and battery charging
  60. FLHP: Rewire the passing lamps
  61. 07 ignition module
  62. Anybody know how to tweek the V & H Fuelpak
  63. TTS DataMaster - configuring frames?
  64. Questions on HD Advanced audio poweramp
  65. TTS update?
  66. 01 Dyna turn-signal OEM connector
  67. SERT Back to Stock Stage I
  68. CE Regulator OK??
  69. Is this normal ? If not can't figure it out...
  70. 05 Fatboy--P0502 code--PLZ read furthur
  71. Fi2000R
  72. Maps for SERT
  73. 09 Exhaust and Download
  74. PC III and new bikes
  75. o2 sensors
  76. ThunderMax SmartLink IV problem
  77. Break Out Box
  78. EFI Tuners vs Warranty
  79. What am I missing
  80. PC3 timing
  81. Help! I've got a problem.
  82. Electrical help needed
  83. engine light when going uphill with cruise on
  84. Ultra main harness color codes.
  85. 99 Road King with DTC 35????
  86. 99 Road King with Code 35????
  87. Going to install Xied - question
  88. 1998 Ultra -- no spark
  89. anyone know how to wire a CB mic...
  90. Installing Spyke starter button
  91. What is the correct charging voltage?
  92. Flashing an ECM
  93. PST-100 Battery Tender Tester
  94. EFI Remapping - Options
  95. Starter engages by itself
  96. Dual fire on a Twinkie?
  97. Can a thundermax deal with 103/110 builds?
  98. 07 Heritage Srecurity System Indicator Lamp Stays Lit
  99. What questions should the tuner ask me???
  100. My T-MAx Bike wont start
  101. Brake light help
  102. So, I'm a newbie to HD EFI bikes..
  103. starting and alarm help
  104. efi external fuel pump
  105. Intermittent Start-Power
  106. Power Commander III 2009: When?
  107. ThunderMax Install
  108. 06 Ultra sneezing/coughing out Air Cleaner
  109. Thunder max popping at 1900-2500 rpm
  110. Turn Signal Not Working Correctly
  111. Help with diagnostic codes
  112. Cold start issue after new fuel lines replaced
  113. SE Pro Super Tuner installer in Georgia
  114. stage 1
  115. Ness Big Shot
  116. 07 Street glide wont start
  117. ignition switch
  118. speedo help
  119. Battery Or Regulator Voltage?
  120. Idle Heat
  121. help air intake sensor
  122. pc 3 help
  123. possible charging issues
  124. timing dip at first throttle
  125. PCIII, SE Pro Race Tuner, or ThunderMax?
  126. Difference between '03 and '05 speedos
  127. FuelPak Settings FXDB with Python 2-1 pipes (PN 41705)
  128. 1000 miles before dyno tune on new SG?
  129. Turn Signal/Security System Problem
  130. LED auto lights ,household bulbs ...
  131. Pciii ?
  132. DTC's
  133. Fuel Pressure Adapter
  134. starter: Gear Gnashing
  135. Voltage Drop
  136. Gerbing temp controller
  137. DC to AC inverter
  138. fuel pump module on an 07 touring
  139. Diagnostic Error Codes 03 Road King???
  140. Spot lights hooked up to ACC switch?
  141. Pc iii
  142. SE Pro Super Tuner help!
  143. pro's & con's of electric pick up?!
  144. Idle trouble
  145. Blown Fuse ACC 08 FLHX
  146. Air fuel meter, any experience ?
  147. Remapping a 117" for an exhaust change
  148. super tuner maps
  149. I need advice
  150. '07 Ultra Classic won't start
  151. Direst link from TechnoResearch?
  152. o2 Sensor question
  153. Low Fuel Indicator Always on
  154. AFR Table SERT
  155. I need your opions on this !!
  156. fuel injection module help please !!!!!
  157. SE Pro Super Tuner...question.
  158. disarming security
  159. Harley plugs in fuel injected 2001 Heritage
  160. Accessory Switch Connection
  161. Throttle bar postion
  162. TFI or Cobra?
  163. Erratic Stator Output?
  164. Key sticking in ignition switch
  165. sweeping guages 09FLHX
  166. sweeping guages 09 FLHX
  167. 1995 Ultra Classic
  168. Need help with fuel pump
  169. PC III questions/advice
  170. pcIII 9v power adapter
  171. SERT Questions
  172. Do you have the Fuelpak #'s for
  173. PCIII usb Throttle Response Stutter
  174. 2008 FLHR Dying While Riding Dwn the Road
  175. Signal, brake, horn fuse blowing during acceleration.....any ideas?
  176. Warm-up engine sneeze
  177. S/e race fueler
  178. sert and stock pipes
  179. PCIII map for break-in.
  180. Rivco EFI module
  181. valet mode
  182. Strange problem with Bike
  183. SE Race Tuner (SERT)
  184. Poor gas Milage with T-max...
  185. SERT Problems
  186. What cable from SERT to USB?
  187. turn signal issue 05 softail
  188. Push Starting an EFI bike
  189. looking for data on a 74516-86 regulator
  190. PCIII and power
  191. Missing at Idle/low rpm
  192. Electrical problem?
  193. rev limiters on what year bikes and aftermarket ones?
  194. Daytona Twin Tec
  195. Turn Signals Not Working
  196. 03 Classic Dying
  197. Need help with a speedometer.
  198. Speedometer not returning to "O mph".
  199. spedometer
  200. Battery Question
  201. Coil problems
  202. 1998 Ultra Speedometer Q
  203. Lazy O2 Sensor
  204. Do I need to re map?
  205. Need new battery
  206. decel popping
  207. 05 FLHTCI engine pinging after gear drive install
  208. How the MoCo should have let the Rider control EITMS on the fly
  209. vied ?
  210. HELP! Error code PO505
  211. 03 Ultra Shuts Down
  212. light white smoke from the front cylinder?
  213. twinscan/sert setup
  214. Left turn signal
  215. Loose magnets on rotor of FLHTCUI
  216. Sert removal
  217. Headlight blowouts
  218. EFI Cold start-idle problems
  219. can't find "bank angle sensor" on 03 RoadGlide
  220. Is this a AGM battery?
  221. Will this work?
  222. voltage regulator
  223. ignition switch removal
  224. need help with sert super tuner
  225. dash question speedo/tach
  226. SERT fueling problems
  227. screamin eagle race tuner
  228. TTS Tuner vs. Thunder-Max
  229. To rich or to lean how can you tell?
  230. Is my amp draining my battery?
  231. Need 4.62 SERT software
  232. King Tour Pak Directional Lights
  233. 2008 Fuel Gauge Issues
  234. Sepst
  235. Bike won't start???
  236. Run switch short on 97 Sportster..maybe?
  237. FuelPak - tweak for popping?
  238. Dyno in Mesa AZ
  239. 08 Power Commander Use on 09 Bike
  240. 2009 Street Glide stage 1
  241. 07 Deluxe just quits
  242. Bad coil?
  243. Help, bike kills itself
  244. Fuel gauge problem
  245. SEST-Is there any map for my Bike?
  246. Rev tech
  247. Confused about Fuel Paks
  248. Head lamp problem
  249. Fuel Pressure Regulator diagnosis??
  250. 08 Electra Glide sputter and dies
