- 1988 switch head on dresser
- signal brake switch
- speedo sensor location?
- Just received PCV, why was this map pre-programmed by vendor?
- 2012 softail fuel moto micro tuner tpi connection help
- Ironhead single fire ignition problems
- ecu tc 88 and se 203
- AFR data logger
- Brake light blowing out
- Road King starter
- simple ignition ?
- Engine wont crank
- oxygen sensor question
- electra glide electrical question..
- B1135 accelorometer failure
- Ignition Problems...HELP!!!
- DTT ignition on carbed bike
- Help!! Crazy gremlins!
- Road King FLHP police / fire
- 1997 Harley ecu flash stage two
- 2013 FLHX Cruise Control Problem and missing Grab Strap/mount bolts.
- ign timing
- Moroso Ultra 40 Wires !
- Key FOB Battery Replacement
- Really Interesting Relay Challenge!
- Low to Mid RPM setting for 06 Dyna Low Rider using Scremin Eagle Race Fueler
- Tuning a new build
- PC III USB Map Request- 06 DYNA
- P0118 symptom not the cause
- starters,
- Cobra FI2000r Question
- Power Comander 5 and Auto Tune?
- Electrical problem
- Passing CO's for emissions
- 91 softail keeps fouling plugs
- HD Illuminated mirrors Help!!!
- Map for PC III USB Power commander
- No Brake Lights
- How to retrieve security pin 01 FXDL /Key FOB has button
- slm deuce
- Turns but won't start, no spark until battery is fully charged
- RK having issues
- New stator vs old 07 stator
- Calculating MPG with Power Vision?
- 1999 fxdl trouble
- Power vision acr's off
- 2007 heritage siren
- Engine Vibration and Noise on 2013 Road King UPDATE
- O2 sensor ckt
- Dyno Tuning - Bristol Virginia Area
- Sportster electronics problem
- 2010 Sportster Wiring Help Needed!
- Custom Spark Plug Wires?
- Battery smoke
- Rocker Owners Rear LED's Question
- Fuel Pressure testing
- Original MPG
- LED Turn signals
- Should I dyno or just use a preloaded map?
- Power Vision map for Andrews 48 cams?
- Flī72
- power comander V on a n ultra classic
- Warm engine starting issues
- ratz down under
- 2001 Dyna, gauges help
- Tail light w/integrated turn signals
- 2009 FXDB Electrical problem
- Fine tuning Cobra fi2000r for a 2001 FLHTCUI
- Fine tuning Cobra fi2000r on 2001 FLHTCUI
- Power vision mount question
- Back to Stock
- sportster 48 stalls and rough idle
- Electrical/efi question
- Spark dissapears
- 2000 softail electrical issues!
- FLHX Turn Signal issue
- Tuning for cams quesion
- I Want to Convert an EFI to Carb
- Need help picking a SEPST calibration
- Early efi to carb conversion
- Testing Spark Plug Wires?
- Substitute head temp sensor for EVO Road King
- Help with Ignition maps for Daytona Twin Tec TC88
- spark plugs and popping
- Replaceing ecm
- Denver Area Tuner
- rear cylinder misfire
- Dual points or single on '62 pan
- Won a PCV with Dyno time for $200.00
- Faulty Injectors
- which tuner to buy?
- 2006 HD Ultra - shutsoff when stopping at times
- Handlebar Switch Kit
- EFI mystery
- Where Does the Power Vision Save the Stock Tune on Your PC?
- major issue
- Direct Link...time for new?
- Oil Issue
- Funky voltage panel gauge
- 4RCustoms eBay store
- Ignition vs. Cams
- Intermittent backfire problem
- ignition and fuel pump issues
- Ground Problem?
- No power on Sportster
- Working on popping
- Taillight/turn signals wiring question
- sest map
- Wiring problem on new CVO fender
- Thunder Heart Wiring Harness
- What do u think oof this tune, A/F
- HELP me please
- Idle climbs to 4k rpms after washing the bike.
- Starter Issue or Stator going Bad??
- Smart Siren II 68352-06 Sportster can I use in my 12 Road King?
- Power Vision autotune basic questions
- Sreamin'Eagle EFI Tuner
- SW Pennsylvania Tuner Who Can Work With TTS, Any Recommendation?
- Starter & spark issue - HELP NEEDED
- SEPRT map for '11 Dyna with Thunderheader
- 2 dtc codes on power vision
- Need Help. Codes for 2006 Sportster 1200XL Low
- Speedo "quits" and Radio volume dies out
- Power commander install?
- Throttle Body Air Control Problem
- Bike will not Start
- Stutter problem...help
- BUS ER code on FLHX Street Glide
- need some help with ignition installation
- Power vision map for 117 build
- Low humm from headlight
- Hard wired brake lights
- PC-v or coil??!!
- 1999 dyna with no spark
- FLHTCU Auxiliary Lamp inop
- 2012 Softail / Dyna Calibration file
- Bike won't start..please help!
- Power vision with lots of decel pop even after revising map.
- 03 Fatboy stalls out when downshifting
- SERT 32107-01c
- LED Driving lights
- Where does this wire connect to?? 2012 limited
- Help , throwing codes , and need help
- No spark for few minutes
- Wiring Help
- pinging!!!!!!!!!!!
- Fuel management
- 04 ultra power commander problem
- Diagnostic Trouble Codes for 08 FXSTC
- Tail Light Stopped Functioning
- battey not charging
- 05' TC88 Carb engine mods, ECM necessary?
- 07 sportster will not start, sometimes
- PC V 2013 roadking 02 sensor question
- Need help running issues
- New Cams and now popping and hesitation....
- Nothing on start
- starter relay diagram? anyone understand?
- Wire diameter
- Help on coil test
- ecm changes
- New speedometer/tachometer
- Daytona Twin Tec tuning
- Low Compression!!
- PC V Map, Help Wanted
- wont start
- J T & S Performance dynotune????
- Mail in ECU for flash?
- SEPST question
- Generator light
- picked up a problem when it fell off the jack
- 99 Low Rider No Spark
- won't start
- Shovelhead won't start...electrical?
- Elect. issues after battery change/PCV installation
- Speedometer Trouble
- Mastertune question
- power commander tuning help please
- Help- handlebar wiring
- wheres the starter relay on 2011 soft tail
- Mystery Toggle Switch
- PCV w/ auto tune question
- Need a New Tuner
- coils?
- turn signals
- I want to slow my idle down.. can I ?
- Iowa Tuners
- Battery Draining?
- FOB problems
- Headlight with alarm activation
- Need Headlight and Trim
- Longer PV-1 cable
- Cam position sensor bypass
- PV and Zumo 660/665 owners
- PV fuel monitor
- hdlan question
- Help, snipped wire??
- Upgrading Hand Controls
- starter relay click nothing else
- automatic or manual compression release
- ECM, PV and Exhaust note (sound)
- EVO Ingnition Question
- A new engine vibration
- Another Power Vision question...
- Power Vision (PV MISSING CUSTOM TUNE)
- No Spark on 2010 SE ultra
- wire my tack
- pc111 06 dyna fit 2010 dyna
- dynamic compression 10.05:1
- Need help with PV tuning
- ECM codes 12, 14, 41, and 42
- Super Tuner vs SE Performance Tuner
- Harley-screamin-eagle-32421-85a-race-ignition-module
- Over charging/leaking battery
- Thundermax question
- tts map
- ngk iridium for 103
- Road King running HOT
- just ordered
- speedo id help
- My head hurts!!
- 2013 SEStreet Tuner 41000008B
- 2010 RG Starting Problems
- Thundermax - problem - need help
- Any input on Cobra Fi2000 Powrpro w/cvt
- What is VE??
- 03 88 won't start
- ViED vrs XiED which one?
- rpm range
- Brake Light Inop Heeeeelp Please!
- new speed o and tack combo.....
- Battery and alarm issue
- twin tech 88 settings for 662-2 cams
- Battery Question
- Power Vision requirements
- need 01 electra glide 06 street glide pin out digrams
- wire puzzle
- 07 RG cranks but won't run when hot
- Another SE Pro Tuner question?
- Tuning advice
- ? open loop closed loop
- 08 Street Gide Stage 1 Base Map
- New Battery, bad kill switch
- got power, but rear blinkers and tail light being persnickety
- Switching electric start back to a kick only 1970 xlch
- Battery Going ???
- o2 sensor
- Having to jump my SG to get it started.
