PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90
  1. BT801 Equalizer Question
  2. I need a switch to match the one for the odometer
  3. Revtech DFO & O2 sensors?
  4. SERT Tuning Experts - Up for the challenge
  5. thundermax question
  6. Ultima Single Fire Ignition Kit # 53-61
  7. Throttle and Idle adjustmen.
  8. Garmin GPS Zumo 550 Dyna Wiring to Main Circuit Breaker
  9. Thundermax, anyone do a monitored run?
  10. Brake/Cruise Control Problem
  11. Charging/Stator Problems on my Ultra
  12. Need Map
  13. New Thundermax MAPS dated 5-1-07
  14. alarm light on dash
  15. Newbie Battery?
  16. ignition module??
  17. Stupid Question #138
  18. SPARK PLUG CONDITION
  19. fuel inj to carb mod
  20. Fuel pump noise?
  21. ThunderMax Initialze Help..
  22. Thundermax AT Dealer's cluelesss!
  23. How to display VIN of Married ECM without Bike in SERT
  24. 2003 F.I. Road King problems
  25. OEM vs. Mikuni Carb
  26. another starter problem"click"click"click"
  27. fuel injector cleaner
  28. brake-turn signal module
  29. Need your advice, please...
  30. Running problem after washing
  31. TFI Question
  32. Break in sert
  33. TFI for 07 RKClassic
  34. When to SERT on new 07? Opinions?
  35. Thundermax u1016 code
  36. tach and gas gauge
  37. FLHTCUI Turn Signal time
  38. Wiring in an electrical switch on Street Glide
  39. Fuel manager for lean condition
  40. results of dyno
  41. Speedo not working
  42. Setting the timing on 2006 Road King
  43. LED gas gauge
  44. bike died again.....
  45. light goes out after fuel pumpengine light
  46. What grease? For planetary gears in a starter I'm rebuilding...
  47. map help
  48. SERT Dialing in the last bit of decel pop
  49. I need an information ...
  50. electrical problem
  51. Wiring problem.
  52. Plug Reading: Opinions Please
  53. Question About TMAT?
  54. OK, now really confused
  55. Gutting My Stock H-d Turn Signals For Powdercoating
  56. New Bike, Need a Tune
  57. Rear Cyl Mapping
  58. pc3 harness routing question on 07 flh.how do you make it fit?
  59. MAIN HARNESS
  60. pc3 on 07 sg
  61. HELP! Need 107"break in map SERT 3.5
  62. s.glide fender light ?
  63. New Smart Siren...not working
  64. melting wires!!!!
  65. still need to dyno a canned sert map
  66. Bike won't start
  67. PCIII Map for 2007 Sportster
  68. TMAX Install So. Me or NH
  69. PCIII Map Request '07 RKC
  70. SERT Help Desparately Needed
  71. Charging Problem
  72. Does SERT allow map download from stock bike?
  73. How does the V & H Fuel Pak Override the O2 Sensors?
  74. MAIN HARNESS 07 Ultra
  75. Thundermax install questions
  76. Charging System Question 05 Sportster
  77. thundermax
  78. SERT data mode
  79. Guidance on choosing new EFI 4 S&S 124ci
  80. fuel mixture tuning w/ Colortune???
  81. fuel map suggestion
  82. help me
  83. Passing Lamp Install
  84. Stalls on hard right turn
  85. 03 ultra classic just quits running HELP
  86. Check engine light-need help
  87. Ultra Classic Radio
  88. Way to adjust/get rid of self-canceling turn signals?
  89. Need a PCIII Map Suggestion
  90. 1986 FLTC electrical problem - circuit breaker?
  91. HD Security Alarm With Pagers
  92. 2004 softail programmer?
  93. Help with 07 RKC pinging
  94. DFO Revtec
  95. LED keeps blowing light fuse
  96. Skull collection LED fuel Gauge
  97. POWER COMMANDER MAP
  98. best thundermax price?
  99. dialing in a Crane Hi-4tc on 01 FLHT
  100. race fueler install?
  101. Left turn signal ghost
  102. Cruise won't set on Ultra
  103. A little Help? - Error Code 21 left output failure
  104. speedometer, turn signal cancelation
  105. Electrical Problems...help!?
  106. No Cruise, and Brake lights on constantly
  107. 99 Road King FI Troubleshooting Help?
  108. Is E.F.I. really all its cracked up to be ??
  109. Thundermax ?
  110. Crane Hi4-TC settings
  111. DTC codes for the 2007 dynas
  112. S.E. Stage 1 Upgrade
  113. SERT Tech Line.
  114. Help:Spark Plug WIRE-Discoloration
  115. What Causes Coughing
  116. 02 Softail DTC guide?
  117. Dyno Tune Questions
  118. What Map Are You Using
  119. Dyno tune
  120. head light on high beam trips breaker
  121. Need a PCIII Map
  122. Left Blinker Problem
  123. Problems wiring adjure beacon signals
  124. Just About Had It w/This F'ing SERT
  125. Weird noise on startup?
  126. PCIII Tuning for MPG
  127. Road King electrical problem
  128. dealer ecm flash
  129. Problems after swapping out switch covers....
  130. Speedometer Jumpin Beans
  131. NO SPARK!....
  132. sert,power commander,power pack,big shot
  133. Blown fuses
  134. Only front cylinder will fire
  135. my SERT , pipes and Stage 1 A/C have shipped
  136. misfire and/or backfire on Deceleration
  137. DFO Revtch
  138. 03 Road glide cruise control issue, help
  139. You Thundemax guys suck...
  140. SERT Tuning
  141. Need PCIII Map For 98" D&D 2-1 Fatcat
  142. connector mounted behind air cleaner
  143. ignition info please
  144. SERT map #55 needed
  145. Thundermax Pointrack Function?
  146. Need Suggestion For Tweaking My SERT
  147. Surging at Idle
  148. oil temp. gauge
  149. For Shovelhead_Bob
  150. CAUTION:2007TUNING & AFTERMARKET SPARKPLUG WIRES
  151. ECM Calibration Upgrade (903) for Stage 1
  152. hi all
  153. aftermarket alarm
  154. Stuck Turn signal button
  155. Arlen Ness Big Shot Adjustable Fuel Injection Tuner
  156. cv carb help
  157. SERT vs WARRANTY
  158. Scorpio security system
  159. vance& hines fuel pack dyno # same as sert
  160. coils
  161. LCD problem with Odometer
  162. PC III Question
  163. Another 8 vs 25 injector ?
  164. Help w/fuel pump
  165. Thundermax-- WOW!
  166. Where's the plug for the switch housings?
  167. Trip meter reset problem..help!
  168. Crane HI-4 ign.
  169. Turn signals stay on but won't flash.
  170. Dyno numbers stock 06 Street Bob
  171. GREAT PCIII Dyno Guy in Dallas
  172. Strange electrical fault on VR
  173. new guy
  174. Electrical Problem possibly simple
  175. Need quidance on richness
  176. stage 1
  177. front signal relocate question...
  178. 2006 FXST
  179. Zanottis has Thundermax?
  180. Kuryakyn LED Controller Vs. Cruise Control
  181. Help with signal problem
  182. dyno torque & hp question
  183. From Carb to FI
  184. low fuel indicator light
  185. Fuelpak or power commander?????
  186. What SE ignition do I have?
  187. Thundermax %100 compatibility
  188. Wire Crimp tool
  189. Terminal Velocity2 opinions?
  190. What's the SERT Bootloader?
  191. Thunderheart vs Ultima wiring harness
  192. Installed PCIIIusb..still not right!
  193. fuel management
  194. O2 eliminator where i can buy it online ?
  195. INFO ABOUT pin-out HD audio system
  196. New SERT question
  197. New Headlight (Wiring ?'s)
  198. Where do I spray the WD-40 ?
  199. performace upgrades
  200. HELP-"07" EFI sportster here...can I just use a Harley Download without a PCIII
  201. TMAT on '05 RK
  202. SERT Race Tuner ( F ) Problems
  203. 03 EFI night train neg wire help
  204. Should I charge my Battery
  205. Can't Wait!
  206. ThunderMax + AutoTune On Un-Altered Engine
  207. Whats the empty plug underneath my seat?
  208. Anyone with Drag (straight) pipes & PCIII?
  209. Serial Port to USB. Important question
  210. ECM problems-Power Commander Installed
  211. stock carb
  212. Voes and S&S IST
  213. well I bit the bullet and made my order for the SERT
  214. Neutral Switch Location?
  215. Dyno-jet vs HD trained Dyno Technician??
  216. Need help w/passing lamp / high beam mod
  217. I need You !
  218. Cannot have any answer from Zippers about my Thundermax AT ...
  219. blinker prblems on my 92
  220. 03 security alarm password
  221. Which PC111 to buy?
  222. PCIII usb cable...leave plugged in??
  223. spark plug wires
  224. Help with LED run/turn/brake problem
  225. PC3 Button How To?
  226. New Headlight (Wiring Question)
  227. Fuel injection conversion
  228. Need an '06 SG SERT Map
  229. coil
  230. Extension Harness?
  231. Heres an aggravating no spark gremlin..
  232. Terminal Velocity II
  233. High Perf. Ignition Module
  234. 07 SERT Part Numbers?
  235. 75 FLH shuts down after its hot
  236. Electrical problem
  237. No Speedo after Mods..
  238. HDs money saving wiring change
  239. SERT set up. Need help
  240. Pinging problem 95in. 2006 e-glide
  241. FLHX cigarette lighter fuse
  242. speed sensor
  243. fuse box
  244. Jamie @ Fuel Moto
  245. Rev Limiter Question
  246. Thundermax and V&H Big shot duals?
  247. Thunder-Max Updates
  248. Just back from the dyno tuning
  249. tourpak and hard bag qustions????
  250. High Beam indicater
