PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90
  1. Power commander-map
  2. When did you do your performance mods?
  3. PCIII, SERT, DFO, ???
  4. 07 SG Electrical
  5. pc111 map needed 07 NT
  6. Change exhaust & Air without tuner
  7. SERT, Which map to use??
  8. Good Dyno Tuner in Maryland
  9. Need a good Florida tuner for SERT
  10. Need Your help w/ elect. issue
  11. low end torque
  12. sert?
  13. Turn Signal Question
  14. Bad Dyno tuner or normal ops???
  15. PC111 Water
  16. POWER COMMANDER OR FUEL PAK
  17. I think stator went out today.
  18. Lighting Question
  19. Bike Starting Misinformation Related To PC111
  20. shift light / tachometer
  21. Looking for a SERT MAP....
  22. Fuel Mileage after SERT
  23. Harley garage door opener prob?
  24. 99 Road King Classic running rough
  25. 2000 Ultra Stator
  26. 07 wont start
  27. HELP IDEL HIGH
  28. H4ST bulb for 07 RKC
  29. fuelpak instructions
  30. ingnition box
  31. Need a good shop\Tuner in MN!
  32. Bigger Fuse?
  33. dumb pc3 ?
  34. New version of sert
  35. 99 Sportster- No spark
  36. Need a SERT map...right place...?
  37. Zippers Thundermax Digital Speedo
  38. Settings for Revtec DFO
  39. new EPA legal PC due out
  40. SERT Tuner in Northern California?
  41. Dyno tune cost?
  42. ingnition coil
  43. PCIII Accelerator Pump feature
  44. Need help, I installed my PCIII today.
  45. HELP ! speedo/tach swap over
  46. 07 Softail Smart Siren II Alarm Setup
  47. Looking for a map for PCIII/ 04 FXDWG
  48. Engine diagnostics: error 35
  49. Problem with sportster
  50. Twin Tuner Fuel Injection Controller by Daytona sensors...
  51. Street Glide SERT MAP
  52. 2001 EG wiring issue
  53. '97 Wide Glide Starter?
  54. code u1016
  55. SERT Question 06 Bob
  56. What is Stage 1 (I searched and got it thanks)
  57. fullsac
  58. SERT or DFI????
  59. V&H Fuel Mgmt question
  60. Turn Signal Button Conversion
  61. Good SERT Tuner in SE Michigan?
  62. RK ECM code
  63. Pipes and tuning
  64. Thunder-Max
  65. used sert
  66. Rush pipes, loss tq., SERT?
  67. SERT map for my 07 BOB
  68. PCIII - map for 02 softail w Santee BOA's
  69. SERT 32124-04B
  70. Crimp pins-male/female
  71. 2006 injectors
  72. dtc code po372
  73. Tuners..........riddle me this!
  74. 07 Train, Bassani Pro streets, k&n and PCIII intalled +problem...
  75. Idle adjustment
  76. cranks but wont start
  77. battery????
  78. Part# for SERT 07 SG
  79. '98 Low Rider headlight problem
  80. 2003 road king wiring color
  81. PCIII MAP Roadking 2001, anyone?
  82. Dynojet O2 sensor eliminators
  83. Another PC III question- '07 Ultra Classic
  84. EFI-Carb
  85. Tuner in the DFW area
  86. MPG with Fuelpack on 07 Touring models?
  87. Spark Plug/Tuner question
  88. Question for Harley Techs Road King Wont Start
  89. low volt code
  90. Good tuner needed.
  91. What is this "Pinging"?
  92. O2 senor eliminator plugs
  93. Filtered Velocity Stacks
  94. Using V-Rod Injectors in a Big Twin
  95. First the Dealer, now the Dyno tuner
  96. Help with soldering wires on front end
  97. tuners
  98. PCIII from Fuelmoto ?'s
  99. stupid clip or spring on RK headlight trim ring
  100. battery percentage
  101. 07 download
  102. Neutral Light
  103. SERT - Thanks
  104. Fuel gauge
  105. vance & hines fuel pack
  106. battery problems
  107. Pinging
  108. Platium Plugs
  109. turn signals
  110. FLHX license plate light problem
  111. Bad Battery?
  112. 07 RKC sert suggestions please...
  113. crane Hi -4
  114. SERT What is it
  115. screaming eagle controler
  116. sert map 07 dyna
  117. Power Commander Question
  118. PCIII / SERT Mission Impossible
  119. Choosing a Voltage Regulator??
  120. HELP ! Will this fit?
  121. K&N or Arlen Ness?
  122. Tach installed - finally!
  123. Anyone have a PCIII map for a Road King with...
  124. Isolator and detachable tour pack Question
  125. Good A/F Ratio?
  126. Any ECM tune kit upon HD Stage1 Dld ?
  127. Looking for a tuner in Cleveland Ohio
  128. 06 Dyna, Set Me Straight!
  129. Will TFI installed by dealer void warranty
  130. My Dyno Results Graph
  131. 07 intake wire.....what is it?
  132. 02 bias tables on SERT
  133. tc88 ignition modules
  134. Flush Mount Fuel Guage
  135. AFR for Gas Mileage?
  136. Another Power Commander ??
  137. PCIII Map Suggestion
  138. thundermax auto tuna installation
  139. race tuner or dfo/????
  140. Left Turn Signal Problems
  141. panhead not charging
  142. Tuner in the Dakotas
  143. ThunderMax--Terminal Velocity O2 Sensor
  144. Can't shut Alarm off
  145. Thunder Max
  146. EFI RACE FUELER 2006 CALIBRATION
  147. Highbeams and Spotlights...
  148. SERT tuning help
  149. PCIII Install
  150. 02 RK Battery Life
  151. ignition/starting ?
  152. New Techlusion Gen. III module
  153. No Soap with Tach
  154. Power Commander
  155. fresh battery is crucial
  156. Why not a RevTech DFO?
  157. SERT tuner in NC.
  158. Looking for a EFI SERT? Look here!
  159. 07 Dyno results question ..
  160. battery question
  161. Python pipes
  162. 98 roadking help
  163. New owner needs advise: 02 Classic but no keys or fob
  164. can EFI fuel injection convert to carburetor?
  165. looking for tuner in the Midwest...
  166. On my way to the tuner
  167. BS or not???
  168. PCIII Map 06 FLSTI - Heritage
  169. Do I HAVE to have it dyno'd?
  170. ADJUSTING IDLE FOR MAGNETTI-MARELLI (MM) EFI
  171. Dynojet won't answer my questions...
  172. "red accessory adapter terminal"???
  173. Laptop and PC111 ??????
  174. brake light wont come on !!!!!!!
  175. Battery discharge woes
  176. crimping fuel gauge pins
  177. Your advice on installing and seting up PCIII.
  178. At a loss with PC3!
  179. Connecting to fuse box
  180. Exhaust gaskets
  181. Starting problem
  182. Break lights and running lights always on?
  183. Race tuner wont communicate
  184. Need a PC III USB Map for the following:
  185. SERT?
  186. Arkansas Dyno Tuner
  187. PCIII USB INSTALL
  188. Accessory power outlet?
  189. would pc-lll help?
  190. EGT Gauge
  191. Electrical Question!!!!
  192. New Dakota Digital speedo/tach install
  193. Tuning?
  194. PC III - Stock or Screaming Eagle A/C
  195. 06' RK Custom missing or mis-firing problem
  196. Voltage Regulator Connection
  197. Rinehart PC and Big Sucker Tuning issue
  198. 02 sensor eliminators
  199. SERT is here so I have a question
  200. Dyno Tuning Question
  201. stock bike with power commander?
  202. lights
  203. How difficult is it?
  204. How Long to Dyno Bike
  205. pc111 usb info
  206. 02 Sensor un plug
  207. Good reading
  208. PC111 Map for 06
  209. Big Bore and TW26G Cams - SERT MAP
  210. load eq and rn/st/tn
  211. BUYER BEWARE
  212. Regulator question
  213. Question on PClll 07 Heritage Classic
  214. 07 Street Bob Dyno Numbers
  215. PC III question/harley download
  216. PCIII USB Port Plug?
  217. CD Problem
  218. Not starting after wash
  219. Wiring extensions for Ape's
  220. Goin' Fishing - bet I catch a whale!!!
  221. PC3 Correct me if I'm wrong
  222. Questions to ask a tuner
  223. PC111
  224. SERT help please
  225. 1550 KIT
  226. Any good tuners in SE Texas or S. Louisiana?
  227. Rookie Question
  228. Power Inverter on bagger
  229. Another PCIII question
  230. Air Wing Horn Cover
  231. Circuit Protection cycling
  232. Can this set-up be dyno'd??
  233. popping on decel
  234. Harder starting after adding baffles,when warm
  235. PCIII with Stock Pipes & Punched Baffle
  236. Fuel Gauge Electronics
  237. Screaming Eagle Race Fueler - Info needed
  238. Low Votlage Codes
  239. Idle speed 3k-4k rpm at times
  240. Adaptive Learning? on an 07
  241. Are problems caused by Vance and hines Fuelpak
  242. Tricky Starting
  243. power loss 5th gear 06 flhtci
  244. intermittent engine miss
  245. SERT on stocker
  246. Daytona Twin Tec ECM & WEGO2 Upgrade
  247. did the power commander on my 07, love it
  248. turn signals blink fast some times
  249. Replacement rear signals-where to instal?
  250. No spark
