PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. 95" dynojet 3 usb SE-203 cam
  2. Fuel pump diagnosis
  3. Adding more fuel with PowerVision
  4. Plugs
  5. 2017 FLHXS Ignition and fork lock issue
  6. 2005 883 w/ carb
  7. 2006 street glide fuel problem
  8. Looking for Eng Temp Sensor
  9. Power Vision instant mileage indication problem
  10. Help please. No engine start EG FLHTC UC EFI
  11. 2008 Sportster 1200N bad ECM??
  12. Best tuner and ease to use for your buck !
  13. ‘08 Ultra Classic White Smoke Left Exhaust
  14. Massive price increase for Powervision tuner...gulp
  15. tune question
  16. TTS or power vison
  17. Lowrider ST tuning advice
  18. Does this sound like bad timing? (video)
  19. What is different about FLSTCI?
  20. Keep getting error code - PO151
  21. No spark, no fun.. help
  22. 2002 UC EFI Race Tuner
  23. 2008 FXDSE2 start issue.
  24. Turquoise cells after SEPST Smart Tune, the never ending story
  25. Recover vci
  26. Orange screaming eagle pro tuner download
  27. PV on M8 Softail - Temp gauge issue
  28. Rebuilt my starter and having issue
  29. Plug wire resistence
  30. fxlrs thunder max tuning
  31. Getting Error Code and PN I Cannot Find a Description for.
  32. Need help
  33. Need help
  34. Tuner selection
  35. Septs is in closed loop mode
  36. Target tune module mounting on an M8 softail
  37. Cobra Fi200 installed
  38. 06 Street Bob won't start
  39. Security System Question.
  40. Power Commander V
  41. Throttle control module
  42. 1997 flhri
  43. Not happy with PowerVision Target tune
  44. Can I recopy data to Harley speedo/tach combo if I never installed it on the bike?
  45. Pv Auto tune showing negative numbers
  46. are all tuner companies dishonest?
  47. PC-V on 07 Sportster
  48. Power vision tune causing p0031 code?
  49. FP3 tuner install
  50. Target tune installed
  51. What tune would you run?
  52. Good tuner in Massachusetts
  53. Harley died
  54. Custom electrical wiring diagrams.
  55. 110 Cr-575
  56. PowerVison Wideband Question
  57. Which SE SuperTuner map for 96ci w/ stage 1 filter and true dual Reinharts?
  58. Powervision with SE Smart Tune Pro
  59. Viewing logs
  60. Changing 18mm o2 sensor to 12mm
  61. left gas cap problem
  62. Fuel disconnect stuck sgs
  63. 2002 Road Glide Injector Cleaning
  64. 90' fxr 120r in need of some help
  65. Dyno Tune with exhaust leak
  66. 2004 Roadking Custom, no fuel to injectors
  67. Fuel pump priming issue
  68. Locked security system options
  69. Complete power loss while riding...?
  70. Opinions on my FP3 Tune
  71. SEPST Tuning Question...2 base maps
  72. 2001 Fatboy No spark
  73. Power Commander V
  74. Opinions on Vance & Hines Fuel Pack 3
  75. Ignition module
  76. Need help with choosing V&H FP3 map ( Harley XG 500 street 2015)500)
  77. Need help SEPST
  78. ECU flash
  79. Daytona twin tec
  80. Change of head pipes: Is a change in downloaded dealer map required to SE Street Tuner ?
  81. 2009 FLHP Tuning Issues
  82. Ecm
  83. SE110 Race kit tuning and heat questions
  84. What size injectors are these?
  85. SE performance ignition module gives engine light/injector warning code on carbed bike
  86. New big bore kit cranks but won’t start
  87. Codes after I put slip ons on last riding season
  88. sportster no lights , or gages just dead.
  89. Ultima Ignition Reprogramming Help
  90. Mixed messages about rinehart slip ons & tune needed on 22 M8...or not?
  91. PowerVision screen replacement
  92. 62 psi fuel pressure regulator
  93. Power Vision Tune, Gas or E10?
  94. Need tunner help !
  95. No spark
  96. Tricking the SEPST?
  97. Tuner advice
  98. Broken Injector
  99. Starting issue
  100. Code B1006 error - regularor?
  101. Gas coming out of air filter? + Bike dies/starting issues
  102. bigger injectors??
  103. Lights and set up using a SBC
  104. 1998 Super Glide
  105. 2021 Road Glide Special w/ RDRS and TTS
  106. FXDL 2006 a bit sluggish when hot
  107. Dyna SC Tune Adjustments
  108. No fuel to the cylinders 2008 efi sportster
  109. Removing An ECM Will Wipe Out The Mileage On A Speedo?
  110. Brnefits if I remove cats ? Already have stage 1
  111. 04 electra glide faring delete
  112. driving me nuts
  113. Cams, I know, I know!!🙄
  114. fuel injector connector
  115. Stage 2 - Power vs Torque
  116. B2113 Code
  117. What tuner?
  118. Tuner for a 21’ Street Bob - UK
  119. Ignition Timing Question
  120. Dynojet Target Tune install questions
  121. Snap-on scan tool connecting to HD
  122. All cells at 14.6 (2019 Fat Bob)
  123. Why would you need to adjust timing?
  124. Old orange screaming eagle tuner trouble
  125. Screaming Eagle Spark Plug Heat Range?
  126. tuner in hanover pa. area
  127. Fuel line issue on a Springer Softail
  128. 120 build TTS Mastertune
  129. Selecting IVO in TTS
  130. Help building a FUEL injection setup for '01/'02 FLTR: Long way around a short trip
  131. Occasional Hot Start Issues
  132. Trouble code?
  133. Strange Dyno curve, possible ignition coil
  134. Hyperformance (King of Cubes)in Pleasant Hill Iowa
  135. This us why I prefer a TTS over the PV
  136. 2006 FLSTNI not running properly
  137. Stock Gear Values
  138. Power Vision on 2 of my bikes simultaneously
  139. Tune knocked out gear display
  140. Tuning and Exhaust
  141. How to use the choke properly.
  142. Who has TTS Mastertune in stock?
  143. Which tuner / dyno for 2004 FI twin cam no 02 sensors
  144. power commander 5
  145. im dissapointed
  146. Powervision with Target tune
  147. Throttle by wire
  148. Installing smart security
  149. dyno tuner
  150. fuel pack
  151. 2006 softail standard ignition contol module question....
  152. Preserve map
  153. Carb problem 🙄
  154. M8 build horsepower and torque issues
  155. CEL WITHOUT code...
  156. Not a newbie but question is...
  157. 2003 Roadking CVO runs for 5 seconds then stalls
  158. Tuner that works with mac
  159. High idle after cam install in 107"
  160. PE aka power enrichment mode dead in 2021 Power Vision?
  161. 1974 XLH 1OOO dead, please help
  162. 2016 Softail (FB) will not start 1 week later
  163. Sert
  164. Thunder max tips/suggestions
  165. crank no start
  166. EGT difference question
  167. M8 timing - advice?
  168. Stuck ignition
  169. 04 road king ecu locked
  170. 2015 street 750
  171. Power vision tuner question
  172. Starter problem?
  173. Removing bottom cover of air cleaner cover
  174. Fuel Pump Squealing
  175. How to view PV logs?
  176. Fuel Pressure?
  177. Target Tune with rebuilt engine.
  178. Those who seen it all (No Start)
  179. 2009 street glide wont rev past 3k
  180. Auto tune
  181. SE Smart Tune Pro questions
  182. After tune higher idle
  183. Looking for some help in troubleshooting
  184. M8 pinging might not be detonation?
  185. Vinerr During Tune 21 Street Bob
  186. We got a leaker!
  187. 2000 Ultra Classic won’t start.
  188. Electric or mechanical fuel pump 05 Sportster
  189. 2000 Electraglide Clear check engine light
  190. 1979 sportster ignition replacement
  191. New release of 50 state tunes for 2021 bikes
  192. '11 Super Glide Hot Start Issue
  193. Power Commander 3 causing code.
  194. 02 Heritage Springer popping /backfires st throttle body
  195. PV with Target Tune,
  196. M&M Tuner
  197. static timing M8 107
  198. PV Autotune Issues
  199. Intermittent problem with 2012 FLSTN Deluxe
  200. Can Fuel Injected...
  201. Cheapest way into Windows 8 or 10 to download PV tunes and send datalogs?
  202. How's my 2021 PV autotune look?
  203. Tuner Question
  204. Thundermax doesn't link up to PC
  205. Tuning question ?
  206. Spark Plug recommendations?
  207. Idle spark control settings
  208. Any point in tuning a stock M8?
  209. 1997 Heritage Softail - No spark on one cylinder after riding a bit
  210. Ignition Module / backfire issue - 03' Sportster
  211. Coils and ignition module upgrade on 883 Evo sportster-1994
  212. emission test . PV plus Target Tune
  213. Dyno tuning all the same?
  214. EFI sportster running rough when hot
  215. Fuel Pack 3 to Thundermax ECM
  216. Ignition switch cover
  217. Crank no start
  218. ECM Part numbers (have they all been superseded by 32534-11)
  219. Throttle Body question
  220. How much cross over is there between models (fuel injectors)
  221. Carb tank on efi "chopper" dyna?
  222. Idle up to 3K and No Throttle Response, Some Trouble Codes
  223. 2001 SPORTSTER 883 HUGGER no spark/dies when hot but lights still work
  224. Dynojet / Engine Codes P0132 & P0152
  225. Bad ignition switch?
  226. What is this part?
  227. Crossbones fuel pump not priming
  228. Retrieving CEL codes on 98 Road King FI
  229. Can not hear fuel pump prime, but bike runs fine
  230. Have power but motor dies at 14.5 volts
  231. Weird smell after plugs/wires install
  232. 2015 XL1200X Sportster 48 12,000 miles on bike
  233. Could my starter be bad
  234. Internal ignition module burning up and my 88 FXR
  235. Dyna starts for 2 second then dies
  236. Wont start hot...
  237. My bike is starting strong then just dies
  238. limp mode
  239. Dyno tuning vs tuner brands.
  240. Fuel Injector Problem?
  241. Hot start poor idle/misfire
  242. injector size?
  243. Stage 1 tuning question.
  244. Fuel pump priming, leaking in tank video 2015 Iron 883
  245. 2002 Ultra Ignition Coil Replacement
  246. FLHX Won't Start
  247. FP3 for 2021 softails
  248. 1985 FLHT Hard Starting
  249. Vancouver, Canada area tuners?
  250. FP3 - ECM comms failure
