PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Engine cuts out
  2. WTF T-Max
  3. Turn signal code ?
  4. Dyno cost
  5. Thundermax Map - BigSucker - Rush Slipons
  6. turn signal and cruise control problems
  7. My speedo reads twice the speed it should
  8. Heat Mgmt & Oil Temp
  9. Another Spark Knock / Pinging Question
  10. Trouble codes
  11. Do I have a Power Commander?!
  12. 1980 shovelhead
  13. Accessory Power Installation Heritage
  14. Idling speed 2000 FLHTCUI (magnetti marelli)
  15. Road King won't start
  16. 07 superglide wont start when its hot
  17. Aftermarket regulators - any good?
  18. Revtech?
  19. brake lights always on
  20. Cant get rid of popping PC-v and rush pipes
  21. No Left Turn Signal
  22. 1986 FXRS turn signal electrical, timing related
  23. I need help engine rev trouble
  24. Charging system help
  25. My electrical system is possessed by the devil
  26. Starting problems
  27. Revtech Digital fuel box
  28. Help I need your input!!!
  29. SEST map for an 04 ultra w/HQ 113"
  30. bike won't start!
  31. Breather bolt angle
  32. bright switch blows fuse
  33. Race Tuner Stock Map without Tune
  34. Who knows the SEST well for some input?
  35. Manual security?
  36. power commander V and autotune
  37. ignition fuse keeps blowing
  38. Generator Bad?
  39. Help with warm idle adjustment
  40. Help with Super Tuner Software Tool Bar
  41. Harley-Davidson Battery Install or Replace article
  42. 07 Ultra Classic
  43. Vance & Hines Fuel Pak
  44. V Tune with tts
  45. SE Pro Super Tuner and Maps
  46. key fob programing help me
  47. What pipes are you running on your softail with TTS Mastertune?
  48. Question about error codes
  49. Yet another Decel Pop question...
  50. Tuner/Battery
  51. Question about pc3
  52. Cutting out
  53. Installing a radio on an 08 fatboy
  54. Wont keep running
  55. Bad Battery??
  56. Another Security System Issue
  57. Need a little help finding a map for the PC.
  58. another TSM Problem
  59. 07 Nightster Screamin Eagle Pro Super Tuner
  60. EFI o8 bagger-thundercones
  61. Slip-on exhaust
  62. rear running light wire
  63. Electrical problems riding in rain
  64. Stage 1 download with pciii
  65. Diag Code: P052 Battery Voltage Low EFI
  66. Diag Code: P0562 Battery Voltage Low EFI
  67. high idle on new SE 58mm TB
  68. directionals flashing on start up
  69. 93 ultra dash out bike runs/headlight on
  70. gas mileage suffering?
  71. problem staying running
  72. Any 09's Pinging
  73. Fuel pressure light problem..
  74. No Speakers after downshift
  75. RPM'S surge from 1100 to 2100 on SG
  76. 03 Ultra Voltage Regulator PLEASE HELP
  77. need help quickly on PCIII
  78. xm satellite radio for road glide
  79. Error codes on '99 RK
  80. Will 07 TB work in place of 06 Dyna TB?
  81. Popping fuses -- need advice
  82. PC3 question
  83. Beaten a dead horse Xieds yet again
  84. Gas light
  85. One week to holliday and bike wount start
  86. I need assistance with 05 road king police electrical
  87. pc2
  88. Spinning Starter
  89. Does SERT come with all the SE Kit base maps?
  90. EFI tuner
  91. Burned up electronic ignition
  92. Exhaust question
  93. headlight and passing bulb #s
  94. Repair Manual
  95. dyna igniton timing?
  96. TPS signal from where?
  97. 2000 FXST fuel problem (carbed)
  98. PCIII Map
  99. Install of Smart Alarm in 08 ultra. Help plz
  100. Help! Need a tach to time my bike.
  101. Harman radio
  102. Hearing the starter gring as my bike starts.
  103. Laptop for TTS Mastertune
  104. Bike shaking
  105. speedo and tach quit on 07 ultra
  106. VERY poor gas mileage - and popping TMAX
  107. HELP!! Blowing headlight fuse
  108. "Check Engine Light" codes
  109. Clarification on dyno tunes
  110. Charging problem 06 Ultra
  111. Request : SERT map for Magneti-Marelli
  112. enabling cruise control on '09 street glide
  113. 03 Ultra loses electrical power
  114. 99 Road King High Idle
  115. Brake relay faulty???
  116. FLHTPI Screaming Eagle performance package
  117. Harman Kardon in a 05 ElectraGlide?
  118. CB Adapters - P/N's needed
  119. Radio on 07 Ultra
  120. Terminal Velocity II Install - Check Engine Light Magnetti Marelli
  121. vance and hines monster ovals
  122. rocker and arlen ness big shot
  123. Negative battery connections
  124. fuelpak, Ridemaxx, or Cobra Fi2000
  125. TTS Help
  126. battery dead
  127. Dealer "Fixed" My Intermittent Check Engine Light
  128. Max Fuse short
  129. Odometer Problem
  130. having touble with my turn signal, it does not blink
  131. timing issue
  132. Help with Ness bigshot
  133. Intermittent engine shut off
  134. SERT and 02 sensors
  135. Weird issue with Electropod
  136. Cruise Control on 05 Deluxe?
  137. Road King NO brake lights, NO directionals!!!!
  138. Dual bulb headlamp issues
  139. Code B1007? Help Plz
  140. 08 Fat Bob Charging System Nightmare
  141. Fuel Pak Install (nightster)
  142. 81 Sportster clicks but no start
  143. Help with Headlight Wiring!!
  144. Speed Sensor question(aftermaket)
  145. Wiring
  146. Turn signal inop and BUS ER with microtach
  147. help with tssm code(for disarming)
  148. ECM locked? What is this?
  149. idle
  150. 75 Ironhead solenoid problems
  151. Radio '86 FLT
  152. Speedo Fails WOW test?
  153. SE Pro Super Tuner: Can you download MAP from ECM?
  154. FXE Electrical Problem
  155. 32127-03 vs 32127-03A
  156. Need a map for 09 Ultra
  157. Strange deal..
  158. Timming gears
  159. 06 Heritage Softail Security(help!!!)
  160. Tuning Help
  161. ignition switch on a street bob is loose
  162. 03 RK Classic Electrical Problem - Help!
  163. amplifier disable wire
  164. turn signals
  165. Best tuner for Tri Glide
  166. Thundermax base map
  167. Starter Problem. Help!
  168. Switch housing removal
  169. wiring LED license plate bolts into harness
  170. PC3 Map Help
  171. 1.4kw to 1.7kw starter in FLT
  172. SE Race Fueler Problem
  173. Program used to tune motors, and fuel injectors
  174. 97 FXSTC tachometer wiring info needed
  175. Code P0374
  176. Help! Map for 103 build
  177. Headlight Question
  178. Coil Mounting
  179. Weird shutoff and restart problem
  180. HELP! Alarm will not "ARM"
  181. Power Commander V on the way
  182. points convershion
  183. Won't run when lights are on! Solutions?
  184. ignition switch problem?
  185. Security System
  186. too lean or too rich
  187. Circuit Breaker trips when bike gets hot
  188. Reserve Fuel Light
  189. speedo quit and bike runs bad
  190. Auxilary Light Wiring
  191. SEST canned map
  192. Getting a good TTS vtune, school me cause I cant seem to do it!
  193. Electrical Trouble - need help
  194. Hard Starting problem when warm
  195. Need some help with a PCIII today.
  196. bad stator plug
  197. 03 Sporster NO SPARK
  198. LED light wiring...
  199. Sporty Electrical problem
  200. Alarm question.......
  201. Voltage regulator bad?
  202. codes p1003 u1300
  203. Air cleaner upgrade
  204. Electrical Issues
  205. Bike died, now nothing!
  206. Do 2008+ Touring Bikes Have IAC's (Idle Air Control)??
  207. PCIII Fixed My Ills
  208. rear turn sinal not working-'07 dyna
  209. Low Beam Not Working
  210. Another ecm problem
  211. Pc iiii help
  212. 2006 FLHTCUI Radio - No Sound
  213. think about different efi fuel management
  214. Newbie trying to figure out this ecm stuff
  215. 2009 electra glide with Rush 2"
  216. SERT Adjustments for New Exhaust Pipes
  217. PC V install question
  218. Alternator
  219. Need help retrieving codes on 03 rk
  220. Frustating Electical Issue, Help Appreciated
  221. turn signal works but wont blink?
  222. Turn Indicator Bulb Won't Turn Off
  223. adding O2 sensors
  224. Overheated coil, misfire rear cylinder - help!
  225. ThunderMax for '08-up Touring, What's up?
  226. looking for a tts map
  227. need pcIIIusb help
  228. Need Help
  229. Wire heat shield
  230. fuel range function MIA
  231. PC III problems
  232. HELP! Electrical issues...lighting
  233. '04 Road King Exhaust/EFI Question
  234. Local Dealers will not do the Stage 1 download?
  235. Need Map 105HK028.XXX.MT2 for the SE Race Tuner
  236. Pc3
  237. EFI Engine Heat Management on 2006 Heritage?
  238. Tmax/TTS
  239. Best Battery ??????
  240. TTS for Stage 1
  241. 07 screamin eagle has a intermittent miss
  242. Battery/Charge Question
  243. Bike Hesitates, sputters, and coughs as accelerating
  244. VRod Stalls
  245. Bike is stalling when turning and riding
  246. '98 Fat boy electrical problems.
  247. Posting for a friend
  248. 94 sportster 1200 xl no spark kindo of long need help!!
  249. 73 Ironhead won't start everytime
  250. V&H fuelpak insight
