PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90
  1. Motor Skipping - Help
  2. Quick battery question.
  3. SERT, best buy??
  4. Installing SERT
  5. 2005 Road King - Throwing Code P0122
  6. FXDXI Nightmare
  7. Need some help here!!!!!!
  8. Anyone have the sequence to reset the IAC?
  9. 1340ST TFI dobeck preformance dfo
  10. fuse blows every time replaced!!!
  11. Removing popping with SERT
  12. strange electrical issue
  13. SERT question
  14. Idiling problem
  15. sudden stalls..
  16. accessory circuit fails when ignition switch is on
  17. Hookers/now what?
  18. Adding acetone to fuel
  19. Shovelhead Bob....Little help here or anybody.
  20. crane hi-4tc
  21. Custom maps for SERT..
  22. EFI flooding issue
  23. lack of power
  24. Round AC Cover on TC?
  25. intermintent misfire
  26. rear wheel speedometer drive reloacation kit
  27. pcIII map for 25 degree injectors and rineharts tds?
  28. sporty random shut off problem
  29. SERT MAP NEEDED!
  30. Voiding the Harley Warranty?
  31. TVII questions
  32. Still popping after SERT and Dyno
  33. Relocating Air-Temperature sensor?
  34. Spark plug wire connector vibrate loose, causes misfires?
  35. 06 Street Glide blowing instrument fuse
  36. SERT - Other Tables?
  37. bike was running but stalled and wont restart?
  38. evo runs bad
  39. evo runs bad
  40. How to do Static timing of engine
  41. Road King ECM Problem
  42. Update after finally installing Terry Components TVII system
  43. i have a headache........need help on decision-PC3 or SERT
  44. Dyno before SERT purchase '06 Heritage Classic
  45. SERT on 06 FLHXI(SE) w/ 50mm TB done at home
  46. Dilemma
  47. $600 For The Key??
  48. '03 Wide Glide Brake Light Sticking
  49. 2006 Dyna: SERT Map Question
  50. Even more PCIII/SERT/Download questions
  51. Error Code 99 Loss of Idle Speed Control
  52. 89 ultra classic
  53. Stock ECM program upgrade
  54. Stage1 Download vs. Stock Map
  55. PCIII Maps
  56. sporty wont start
  57. Action Cycles, TN?
  58. Ignition swtich question
  59. which is the best?
  60. Magnetti Morelli fuel injection
  61. Dead battery
  62. Sert map suggestion?
  63. Changing Slip Ons Question
  64. PCIII where to buy?
  65. spark plugs vibarate loose
  66. anybody switched the pcIII, for sert & 25 injectors with better results
  67. Which injectors do I have??
  68. SERT Calibration # Help...
  69. Hey ShovelheadBob
  70. dash quit working
  71. speedo stopped working
  72. No Spark
  73. No Spark
  74. '02 FXSTI sputtering/backfiring
  75. found a disconn alarm on '96 FLSTC
  76. PCIIIusb on 06 Models
  77. Check Engine Light comes on then goes away?
  78. need dyno/tuner Austin area..
  79. Who sells a 1156 red bulb???
  80. SERT Map Question
  81. Re-Re-Location of Front Turn Lamps
  82. PC III map needed for 2006 dyna
  83. Running Lights are out
  84. SERT data mode
  85. SERT vs HD Download / Dyno?
  86. PCIII Install?
  87. Dyno tuner needed in the N.W.
  88. Red key lamp
  89. Charging system problem
  90. SERT, dynotune, custom map
  91. Mileage w/PCIII USB???
  92. Wrong Flash installed?
  93. Need Help with Digital Tach Install
  94. SERT Map for FLST 06
  95. Looking for SERT map....(please?)
  96. New Dyno Tunner
  97. Where do i start my search? -schematics-
  98. Power Commander/O2 sensor eliminators
  99. My injector identification
  100. Installed V&H, and SERT
  101. cobra FI 2000R
  102. 05 sportster won't start
  103. passing lamps
  104. 06 Classic Alive & Well
  105. When can dielectric grease be used?
  106. SERT in Arizona
  107. Help with SERT data mode
  108. points conversion
  109. E edition of SERT obsolete????
  110. How can I test Crane 'siamese' coil?
  111. Sporty won't crank
  112. Rear Running Lights Getting Hot
  113. 99 FLHTCUI fuel leak
  114. Use this SERT Map for 05 FLSTFI Anniversary w/2 into 1 Exhaust
  115. Alarm
  116. 01 Softail ECM Issue?
  117. SERT tuned? How can I tell?
  118. tssm problems???? HELP ME MECHANIC!!!
  119. 2001 FLH running on one cylinder
  120. '05 Sportster Performance Ignition Module
  121. P1475
  122. timing after lineing up cams
  123. ECM race download 34353-06 is in!!
  124. awsome news on my 06 injectors
  125. Acc fuse good, still no juice....
  126. ignition problem on my Sporster 2003
  127. Security Code
  128. Sert on 06 Sportster problem
  129. 1990 Dyna Sturgis Turn Signal Problems.
  130. Firing on one cylinder,
  131. Couple of quick questions
  132. Indianapolis Harley Northside
  133. Rough Running 06 FLSTCUI
  134. Total lLoss
  135. Power Commander vs. Daytona Twin Tec
  136. Help with DTC for 2006 Ultra
  137. H2O in the ECM connectors
  138. Injector pulse width vs.temperature
  139. Clarifying "06 Classic died"
  140. O6 Classic Went Dead
  141. Anyone running a Fuelpak with 25* injectors
  142. voltage regularor??
  143. 1998 FSXTC Starting issue
  144. SERT -- Auto re-set?
  145. V & H FuelPak
  146. 05 Road Glide running badly
  147. SERT Help
  148. 05 rk tach to 01 heritage
  149. TFI,DFO or Power Comander
  150. DFO
  151. Still pops on decel - help please
  152. O2 Sensor Testing
  153. PCIII Tech in St. Louis Area?
  154. timing
  155. trun signals
  156. 02 FXSTI Intermittent High Idle
  157. I think I have a problem.........
  158. Left directional not working
  159. Instrument panel stopped working except spedo
  160. Engine missing
  161. Engine missing
  162. Headlight issues
  163. PCIII Help
  164. 2006 dyna lowrider engine check light
  165. Erratic Speedo, 2000 EG Police Bike
  166. Coil Problem? Crane Cam Single-Fire Ignition Module
  167. 2005 Anniversary Fatboy Dyno runs
  168. Wont start and keep charge
  169. Missing VTD Password??
  170. '06 Dyna Tail light
  171. How do you do this?
  172. 2005 Screaming Eagle V-Rod w/HD Tuner
  173. SERT Question Please Help!!!!!
  174. occasional missing, popping: 98 carb'd motor
  175. No Speed0, Brake lights, Turn signals
  176. turn signal fault
  177. Advice on 06 Deluxe SERT
  178. 2006 8 deg vs 25 deg injectors
  179. Rush slip-ons remapping??
  180. single fire vs dual fire
  181. bosch plugs
  182. shovelheadbob
  183. Download for Stage 2 Slip-ons
  184. sert disc
  185. Misfiring and popping when cold.
  186. Identify HD Race fueler, not sure which I have??
  187. Should I have remapped when...
  188. what happens when you jumpstart your bike from your car?
  189. D F O
  190. Alright, I got one for you experienced gearheads
  191. PC III 'Accellerator Pump" Feature?
  192. WTF, why is she still pinging
  193. SERT-V&H PIPES-K&N What File??
  194. Lizard Light Installation
  195. PCIII, SE AC, Custom Pipes
  196. Injector change out
  197. Aftermarket ignition ?
  198. battery dies/did test on regulator/stator
  199. S/E ignition module
  200. Air Cleaner cover-need your thoughts on this.
  201. ironhead isn't charging
  202. Injector replacement
  203. Stage 1 Download Sucks!!
  204. Power Commander History?
  205. Complete Electrical Shutdown
  206. spark plugs help
  207. Stage 1 ?
  208. Turn signal wire removal... HELP, PLEASE!
  209. Berserk Knock Sensor
  210. EFI Race Fueler
  211. Trying to get ahold of Dynojet
  212. Accelerator Pump Utility PCIII
  213. How do I find out what "Flash" is in my FLHXI?
  214. 93 Sportster wont start
  215. Left turn signal
  216. What in the hell is this thing for?
  217. Ready to buy a PC III
  218. 'o6 Heritage Classic backfire
  219. Need Help: '03 FLSTCI Won't Idle When Hot
  220. Power Commander
  221. SERT what one?
  222. Techlusion TFI or Vance Hines Fuel Pak ?
  223. O2 Sensor for Terry Components TVII
  224. I got my PC 111 yesterday
  225. spirit54 to turbo54 PC 2
  226. Help With TCFI II Fuel Injection Controller
  227. '05 heritage flstci
  228. problem with speedo,odo, turn signals
  229. Stock pipes and Stage 1
  230. starter relay
  231. bike dies while riding
  232. Trouble Code?
  233. engine misses when headlight is turned on
  234. 2006 FLHTCI SE A/C and 2into1's
  235. Roadking Front Lighting will not work
  236. PCIII question. Need Help!
  237. Twin Scan 88+/WEGO good stuff
  238. Siren for security system installation
  239. Throttle Position Sensor Bad??
  240. Techlusion advice
  241. Left turn signal activates by itself
  242. rev limiter malfunction
  243. Roadster Electrical Question
  244. Dynateck F.I. Controller
  245. Fuel Management Installation
  246. HD Fueler part number, which one??
  247. TSM Key Fob
  248. wireing up new harness from v-twin
  249. Hey there, hope ya can help
  250. voltmeter question
