- Engine light on w/scream eagle ignition kit
- runaway starter
- popping bulbs on my 07 fxstc
- optimizing TMax for best mpg
- Good tuner in Ga '09 Roadglide
- PC3 - O2 Eliminators - take out O2, run a bung plug?
- Electrical Problem
- Which EFI Do You Guys Recommend For This Setup?
- Which EFI Kit?
- HD Security System with Thundermax
- PCIII map for V&H true duals - anyone?
- Race Tuner ?
- 05 EFI Wheezing and Hard Starting
- Harley 883 Sportster
- 86 FLT spark plug suggestions
- High Flow Injector Fitting
- '09 Touring ECM
- dynojet PCiii software won't run - says no Windows
- 06 Dyna BAGGING OUT!!!!!!!!!!!!!!!!!!!!!!!!
- Stealer not recommending a race tuner? Opinions please
- stage 1 question
- Need help!!! Need advice how to fix!!
- ECM Light After Start
- Looking for a map pc III usb 2000' ultra
- DTT Tuning Question
- Anyone in N Alabama or S. Tennessee running a T-max
- tried them all pc3, sert, Tmax. ?race fueler?
- problems with 08 softail custom
- empty fuel light on but tank is full
- GPS Hardwiring question
- Battery load test ?
- ECM Tuning Software
- LED License Plate Bolts
- Arlen Ness headlight bulb
- Electra Glide Classic Hesitates on Takeoff
- PC III for 08 Ultra
- Cams only or S&S heads or both ?
- Any fuel management options for 09s yet?
- 96 to 103 kit
- Hear a bell ring after I start my bike
- Question about Harley-Davidson SEŽ Pro Super Tuner Cable Kit 32184-08
- ecm does not accept programming
- I'm Gonna Be at Fuel Injection Palooza
- 02 electrical gremlins
- Flat acceleration spot at 3400 rpm
- poor acceleration
- Engine Code Help Needed
- `06 FLHRS carburated to fuel injected??
- Hard Start Long Crank 2008 RK
- 91 heritage electrical ghosts
- 2005 Heritage battery problem
- controls
- PC III numbers on Map's
- what protocol for data port?
- TMax Sofware upgrade now available.
- Everything you ever wanted to know about fuel injection
- rear tail and running lights out
- o8 electra glide classic speedo installation
- bike will not idle
- Neutral Light Switch
- compression releasers easy install?
- SERT MAPS AND DESCRIPTIONS ONLY please
- Smoked Ignition Module
- Tach jumping around
- 2000 Sportster Power Outage...
- need sert map for 08 ultra... help
- Heated grip install
- 07 Dyna EFI troubles
- 99 FXSTS Alarm
- 04 Speedo/Tach ECM Databus
- 2 Stupid Zumo questions installed on the Street Glide
- after market ignitions and speedometer
- Speedo & Odometer cutting out when hitting bumps
- shutdown
- Ignition on Carb Conversion
- 2007 softail pinging.
- S.E. Race fueler
- Removing the ECM
- 08 RK Speedo/Tack Install Questions
- Battery Pager Vs Rechargable Pager
- Tach revs to 2000rpm only
- Continuing PCIII problems
- Harley screamin eagle pro efi super tuner
- Remove hand control connector pins 08' SG
- Tmax Initializing
- 4 position switch question
- do I need to dyno tune
- Need help with PCII
- 2007 night train pinging
- no more push button problems
- help from technocrats
- Would like to see tuner poll
- Harley-Davidson Security System Smart Siren II
- NRs IED & XIED question
- Oil in injection module
- odometer/gas/rpm needle jammed on v-rod
- rbabos: Deceleration popping results.
- PCIII + ECM Flashes?
- TMax and 07 security system - won't start
- High idle issue again!!!!
- dyna ignition replacement
- Headlight Blowing Fuses
- Need help wiring in this thing please
- What is the right map for my 08 Bob? - SEST
- Dyna S
- Battery
- ECM auto adjust to Stage 1 changes?
- New Member - Starting Problem
- fuel pack Heeeeeeeeeeeeeeeelp!!!!!!!!!!!!
- Power commander III dont like the wet
- Kurakyn Panacea Lights
- Tying into the Alarm System
- new SERT Pro
- Stage 1 With V&H Slip-on Do I need to map?
- Homemade IED/XIED's I got questions...
- vance and hines fuel pac help
- 04 Fatboy Problems
- No indicators above tickover speed
- need '99 bank angle sensor signal spec
- charging problem
- pipes and air filter kit no tune
- Where is the HD factory alarm system harness??
- 07 FXDB H-D Security Sytem Install Question
- Removing tail light bulb
- Was exspecting better mileage
- new Vista computer
- Howard Hog Horn install Help me!!!!!
- Radio not powering up now
- Stage 1 or PC3? Also PC3 maps...
- 2008 Sert
- more push button problems
- Calibration Number for stock 08 Dyna FXD
- HELP PLEASE...99 Magneti ECM Trouble...! ! !
- True dual problems with T-Max?
- New Wires?
- Charging confusion questions
- 2006 deluxe brake light doesnt work properly
- dtc #16
- Kurakyn Panacea Lights (Deluxe Softail)
- Intermitant start problem
- Warm start problems/Enricher is possessed
- 04 Fat Boy Meltdown
- Help-Switch problem
- Custom Speedo faces
- tts procedure
- points/plugs
- '07 soft tail idle problems
- Speedometer cuts out with Radio volume senor
- Bad day #2
- Would like input........so I can get a grip on situation !!
- Headlamp pin thing
- push button problems
- 77 sportster 1000 starting problem with video
- new
- LED flashers
- 04 ultra radio volume increase when clutch pulled in.
- wilhelm
- my speedometer is F'ed up!!! HELP
- Can a PC111 Fry the stock ECM?
- Bike getting power but won't start
- Front cylinder plug fouled
- Bad Day!
- popping out the exhaust
- electrical gremlin
- Negative acceleration
- tts tuner dealers
- Ignition Sensor Plate????
- quick question on race tuner
- Relocating or Cover for FXR wiring harness
- se pro race tuner 2008 flhtci
- Electrical Problem after new stereo
- Another Tach question
- Spark problems
- 30 amps horn on a FLHRCI?
- warning lights came on then ...
- softail speedometer/odometer quit
- Where can I mount my horn?
- Help!
- wierd starter problem
- Balancing throttle bodies?
- Voltmeter Dances while traficator blinks
- Another Tach Question
- spot light replacement
- Is this problem caused by my ignition module?
- Pciii or super sert?
- Fuel pak Help
- 08 Nightster Air/Fuel issues
- 4 ways flash 6 times when ignition is turned on?
- Lengthen pig tail on SE ignition module.
- PCIII on 2001 RK question. Help?
- Turn signal connectors 07 FLHRS
- Problems starting
- Need PCIII Map 09 Nightster....
- Help! Diagnostic code b1007
- "Master Reset"
- just cuts off no power
- Diagnostic Codes
- Speedometer wiring question
- Smart Siren II
- No electricity to bike
- Is the battery bad or is it an electrical problem?
- Low pressure return fuel line or check valve leaking
- Motor noise in speakers?
- Spark Plug Questionfor 07 streetglide
- Tachometer needle jumping (HELP!!)
- pc111 and o2 sensors
- Well, how smart are you, really?
- Warm Idle Adjustment Delphi EFI?
- ECM Connector
- Yet another load equalizer question
- HD Stage 1 Download
- tuners
- 04 RK - Starts on its own
- Daytona Sensors
- Screamin' Eagle SE Pro Super Tuner
- 1999 EVO Ignition upgrades
- SERT tuner in Central IL?
- Audio Volume Switch
- M/F 3 wire connector
- running light's
- Idle Air Control problems
- fuel pack
- Big problems...
- '05 Carb Fatboy--Codes P-0501 & P-0502
- Blackout
- Sert to PCIII
- need help downloading 477
- P0113 code on 04 ultra
- K&N filter kit and remapping?
- SERT VE Question
- Adapting vintage speedometer to new bike
- Battery Tender Jr. F--
- Ran out of gas, bike won't start back up
- 08 Radio Issue...Had This???
- generators
- Electrical Shutdown
- 01 road king
- ecm question
- 1999 1200S will not start again
- Pinging and clackin at 2500 to 3500 rpm
- Why the bad MPG
- Remove Ignition/light switch
- Hesitation at full throttle
- PCIII map for '07 w/TW6-6, slip-ons, A/C?
- Fuel Pump doesn't start
- 1984 FXRT turn signals - is this a problem or normal?
- Stage 1 -Flash or fuel tuner for 96"
- Fuel leak
