PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Screamin' Eagle SE Pro Super Tuner
  2. 1999 EVO Ignition upgrades
  3. SERT tuner in Central IL?
  4. Audio Volume Switch
  5. M/F 3 wire connector
  6. running light's
  7. Idle Air Control problems
  8. fuel pack
  9. Big problems...
  10. '05 Carb Fatboy--Codes P-0501 & P-0502
  11. Blackout
  12. Sert to PCIII
  13. need help downloading 477
  14. P0113 code on 04 ultra
  15. K&N filter kit and remapping?
  16. SERT VE Question
  17. Adapting vintage speedometer to new bike
  18. Battery Tender Jr. F--
  19. Ran out of gas, bike won't start back up
  20. 08 Radio Issue...Had This???
  21. generators
  22. Electrical Shutdown
  23. 01 road king
  24. ecm question
  25. 1999 1200S will not start again
  26. Pinging and clackin at 2500 to 3500 rpm
  27. Why the bad MPG
  28. Remove Ignition/light switch
  29. Hesitation at full throttle
  30. PCIII map for '07 w/TW6-6, slip-ons, A/C?
  31. Fuel Pump doesn't start
  32. 1984 FXRT turn signals - is this a problem or normal?
  33. Stage 1 -Flash or fuel tuner for 96"
  34. Fuel leak
  35. Pciii
  36. weak Horn
  37. Good race tuner
  38. Xied removal
  39. Electrical Guru's Needed
  40. Please help with Blown Fuse
  41. Supplemental 12v Power Point wiring?
  42. Thunder Max problems!
  43. Tuning '08 RK
  44. Idle too high after running ??
  45. HD Race Tuner vs. V&H FuelPak?
  46. SE Pro EFI Super Tuner question...
  47. SERT map request
  48. SERT for 04 Heritage
  49. How to change 09 harley exhaust with o2
  50. Sporadically Losing spark while riding
  51. rbabos: editing fuel map pages
  52. LED Fuel Gauge
  53. pc111 in rainstorm
  54. 98' Evo EFI won't start when cold
  55. Speedometer/Tachometer year fit question
  56. PC3 on Dyna + Khrome Werks HP 3" + K&N
  57. quickest and easiest way to get power to the bar
  58. ECM "Erased"?
  59. question for 08 owners with PC 111
  60. electra glide 2001
  61. Hot start Surge 06 Bob
  62. 08 FLHR, V&H Ovals, PCIII, SE Intake-The experiment!
  63. fuel pump
  64. MM ignition Idle speed control acuactor
  65. TTS Tuner (User experiences)
  66. Accessory plug on Road KIng
  67. stage 1 upgrade question
  68. 01 Road King Police Bike just quits
  69. TTS Master Tune
  70. Help with PClll error code
  71. A Deserved Thanks
  72. Ignition switch
  73. From stage 1 to factory ?
  74. TTS Data Master
  75. Left Blinker Problems Please Help
  76. 08 owners beware FBW and Induction Modules
  77. ignition timing question
  78. using a USB to Serial Port Adapter
  79. PClll how to switch maps?
  80. No power to starter switch
  81. Did I hurt my motor
  82. Power Commander accelerator pump upgrade
  83. bike won't start. 07 street bob
  84. TTS vs SERT?
  85. Sarge needs some plug/tuneup help..
  86. Using Powercommander maps from Softail for Dyna
  87. AFR Closed Loop Bias Table
  88. Steve Cole Calculating VE
  89. Heres a Strange One for ya
  90. check engine light 08 sg
  91. Electrical probs, not charging?
  92. Chicago area tuner
  93. Tfi
  94. tmax auto tuner
  95. Need help getting PCIII map leaner
  96. Need Help with Directionals on 92 Dyna
  97. Help for a SERT map
  98. Tmax Hot Start
  99. AFR Question
  100. speedo cal with Thundermax w/auto tune?
  101. xied
  102. ? for Doc1
  103. HD security system
  104. Kuryakan LED Taillight Issue - Security
  105. Tuner software version
  106. Looking for a PCIII map
  107. Stumbling Road King
  108. Help with Tuners, Noob Question
  109. Turn singals
  110. Dual Gauge Speedo/Tach combo gone wrong
  111. Tuner confusion..........
  112. Help opening a dbd file from sert tuner cd
  113. Anybody use se ignition module on twin cam?
  114. Dim headlight
  115. Witch screaming eagle p/n ignition module for 99 fxdwg??
  116. SERT to Power Commander
  117. 03 RoadKing won't start - ECM bad??
  118. Accesory plug on roadking
  119. Crane Electronic Ignition
  120. SERT files
  121. 1985 FLT short?
  122. Novice questions on electrical problem
  123. SERT or not?
  124. 1999 wide glide fuel gauge
  125. security lite came on
  126. 2003 FLH pipes glowing red HELP
  127. Suggestions for Tuning TMAT
  128. 2000 Road King EFI/fuel management question
  129. key fob, does it do anything?
  130. neutral light
  131. [Deleted]
  132. '03 missing bad - diagnostic codes?
  133. no speedo tach blinks horn?
  134. ICM
  135. techlusion install question
  136. Fast Idle on an 06 Street Glide?
  137. Need Part Numbers for Stator and Starter
  138. Security siren connector
  139. EFI 101
  140. Help cannot find part
  141. ENGINE LITE ON
  142. super sert cables
  143. SERT Tuning 1
  144. Left on the side of the road
  145. 98 1200 No Spark
  146. Crank Pos. sensor
  147. Blowing Fuses
  148. Turn Signal
  149. Weird FLHR electrical problems
  150. 2002 EG Classic headlight bulb?
  151. Fuelpak and sidecover issue
  152. 02 question
  153. Coil
  154. SEST 202TD002.dt0 File
  155. Spewing gas out overflow
  156. Timing knock sensor help
  157. Tuning Centers
  158. Fuel Pak, PCIII, SERT
  159. terminal veocity III for 08 touring
  160. Charging System
  161. thunder max efi & autotune module
  162. Both turn signals on left side!
  163. New turn signals acting strange
  164. HELP, ELECTRICAL ISSUE
  165. Calibration File for 07 FLHTCUI - SE Air - Rinehart True Duals
  166. HELP SPEEDO WIRING
  167. Turn Signal Security Module
  168. Throttle Body Size
  169. fuel pump question
  170. dead battery - I smeel a rat
  171. Speedo V/S Tmax
  172. Turn signals don't work
  173. Sputtering 07 Street Glide
  174. Eng. light comes on / engine speeds up & down
  175. Dimming headlight
  176. New closed loop section in sert?
  177. Reprograming/Mapping a Thundermax
  178. test
  179. Engin Idle Temperature Management System
  180. For Those Of You Doing "Remote Mapping"
  181. Failure on the Speed/Tach combo Unit
  182. 91 FXR charging problems
  183. P0108 code
  184. No spark will not start
  185. sert install. dyno
  186. new pipe and air cleaner and PCIII usb bike dies
  187. 1972 FLH Circuit Breakers
  188. terry components fuel optimizer
  189. Lighting Problem
  190. Tach wireing Help!
  191. Charging question???
  192. intermittent power / no power - '96 flstc
  193. Wire Colors and Positions in connector 28B
  194. o2 Bung Thread
  195. delete
  196. Advantages/Disadvantages with Closed loop ECM
  197. Aftermarket or HD EFI Controller
  198. Engine Diagnostic light
  199. battery light
  200. Coil??
  201. site problems
  202. site problems
  203. using a USB to Serial Port adapter
  204. problems with site
  205. popping/bacfiring
  206. Panacea lighting
  207. Stage 1 - Blue Flames Spitting
  208. Horns
  209. 08 cruise shuts off when it shouldnt
  210. Changes between 07' and 08' ECM ???
  211. PCIII USB Maps for 2003 Touring
  212. Piss, fart, spit and ping
  213. Missing, popping, and backfiring
  214. Starting Problem
  215. Bike dies at stoplights
  216. Bike cutting out
  217. to dino or not
  218. turn signals no longer canceling
  219. SEST Connection to Bike for First Time
  220. Canned SEST Map vs Stage 1 Flash
  221. fuelpac ver 12
  222. New 08 Nighter dead electrical sometimes - and what's this blinking key icon??
  223. 01 softail ECM codes
  224. Battery Connection Woe's
  225. sert
  226. backfire in intake
  227. PCIII and rain
  228. laptop for SESRT?
  229. 1981 Sportster Electrical Problem
  230. Formotion Power Pod
  231. Speedo probs
  232. Check Engine light
  233. What am I doing when I hold the odo reset and turn the ignition on?
  234. 07 ultra died
  235. anyone replace the ck. eng. bulb ?
  236. map sensor question
  237. 07 Wide Glide - Turn Signal and Neutral Light Issue
  238. Help need a map for my fuel pack
  239. fuel pak
  240. Changing signals on 03 Deuce to a signal bar, What are the three wires in the factory front signals?
  241. ECM pin hole size HELP
  242. Main fuse or circuit breaker
  243. Self-Cancelling Turn Signal Modules
  244. Error on Loading Map in PCIII
  245. Nothing electrical works
  246. sert connection
  247. dyno tuning
  248. American Micro Fuel Device (AMFD) - anybody have one?
  249. so the EX will use the 02 sensors in the three modes you list on the link:
  250. Question regarding 95 c.i. kit and the ECM
