PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. can SERT be change to accept a different ECM
  2. Stage 1 Race Download vs Stage 1 Legal
  3. How to dial in a HD Race Fueler?
  4. Help Needed, removing 07 Heritage Oil Vent Tube
  5. BEWARE! 07 Softail Engine Fire Risk
  6. need "spark plug lessons"...
  7. stock air and rush slip ons will it run to lean
  8. HD stage 1 vs canned map
  9. VOltage Regulator - Low Battery
  10. cruise control dead
  11. 07 ecm same for lowrider and glide?
  12. Broke My Fuel Line!
  13. Where to find the hot lead for GPS
  14. 1981 Ironhead Wiring Question: Blinkers
  15. 2007 SERT with O2 Sensors
  16. PC III mounting question
  17. Battery idiot
  18. Hello???
  19. Dyno Tune in San Diego
  20. Checking PCIII map
  21. Is anybody using Ness Big Shot
  22. HELP!!!!!
  23. Whats the MAP???
  24. O2 Removal Help
  25. Stage 1 download again
  26. erratic high idle
  27. What HD is telling me about stage1 upgrade
  28. Download or SERT?
  29. Twin Tec or Dynatek
  30. fuel pack, V&H Ovals, arlen ness big sucker
  31. PCIII software problems?
  32. single fire problem! HELP PLEASE!!!!
  33. Uhhh Someone please help
  34. ignition condenser prank
  35. S&S IST Ignition..Anyone know anything?
  36. ThunderMax problem. HELP!!!!!
  37. Need help guys
  38. Question about self mapping a PCIII on '06 dyna
  39. Timing question..
  40. Ignition UpGrade Question?
  41. Is 03 EFI T/B Sensors compatable to 06 EFI T/B Sensors?
  42. Timing Lights
  43. Thundermax TMAT at 100% throttle
  44. Thundermax Auto-tune??
  45. Battery Issue
  46. 2007 O2 Sensor Connecters?
  47. Frozen Plugs
  48. Just put 95 incher together, won't start
  49. ECM resets to original spec
  50. crane h1-4 problem?
  51. 2000 springer, loses electrical and dies
  52. HELP WITH 6TH GEAR LIGHT
  53. 2008vs 2007
  54. STarter troubles
  55. SERT Tutorial?
  56. Engine Timing
  57. sick 97 flhr-i
  58. P1358 Intermittent Secondary - What's that mean?
  59. The 4ยบ Sneaky Speed Secret???
  60. wires getting hot
  61. Recall calibration vs SERT Tuning
  62. acc. light relay?
  63. Speedo and odometer Turns off.
  64. Nice intro to EFI basics and updrades...
  65. Learned something, thought I'd share
  66. What are they worth!
  67. power card
  68. Brake light stays lit
  69. Spark Plugs, Coils...just need a little help
  70. need help bike wont run 07 nightster
  71. Stage 1 Race Download
  72. CDI or Ingnition Coil?
  73. sert data tuning help please
  74. sert map for 2007 fxstb with big radius pipes?
  75. won't start
  76. dealers think they are gods
  77. installed usbpc111 2 questions
  78. error code after fitting k/n
  79. EFI conversion
  80. plug hanging from side of seat?
  81. REGULATOR TEST?
  82. 2005 Heritage Shut Down
  83. Instruments and P&A fuses keep blowing
  84. Tach problem
  85. Electrical test questions....
  86. speedo/tach combo problem
  87. PCIII @ 280.00, SERT like 350.00 and....
  88. New Kid to this forum
  89. front turn signal problems
  90. SERT seminal moment
  91. 2004 FLH Wiring Harness/Alarm Problem
  92. SERT map request
  93. 1980 FLH - starting / ignition circuit
  94. Trade a Rinehart duals SERT map for a Fatcat Map anyone?
  95. Spedo & Odomotor do not work
  96. hi-beam lamp
  97. pc 111 /k/n causing error code
  98. PC III Firmware Update
  99. K&N Air filter and EFI mapping
  100. SERT Data mode items???
  101. SE Race Fueler or TFI ?
  102. Engine/speedo cuts out when I hit bump for 1/2 second then is fine until another one comes!
  103. setting idle on 07 sg
  104. help quick advice on mounting PCIII
  105. Need Stock 02 sensor for 07
  106. pc111,hd download,stage 1??????
  107. Tmax on a 0 mile brand new 08?
  108. SERT, PC or Fuel Pack
  109. Power Commander with '07 96 cu in motor
  110. Wildthing and Thundermax
  111. 06 Ultra hesitation/pop/stall
  112. oldschool fishtails on 06 FLHTCI
  113. POPPING CIRCUIT BREAKER 93 fxdwg
  114. Wiring Haress Problem
  115. New Map for T-Max
  116. Best way to tune after V&H Bigshots/Hypercharger install?
  117. starter clunck while turning over
  118. ECM
  119. SERT Data Recordings
  120. Battery
  121. 07 RoadKing VE tables?????
  122. 92 Sportster coughing and backfiring
  123. setting the timing
  124. What happens
  125. PCIII on a 07 FXDWG Great
  126. No fire on 04 Low Rider
  127. 07 FLHT problems
  128. 03 Ultra Alternator/Voltage regulator/Wiring
  129. Crane Ignition
  130. Security System question
  131. Back fire
  132. '93 electraglide voltage problem??
  133. Vance and Hines powerpak question.
  134. ECM has bad calibration or os
  135. Do I need re-programming?
  136. ThunderMax and Baker DD6 speedo calibration
  137. PCIII Tuning, Map Share?
  138. wondering
  139. dyno run for stage 1 download
  140. Thunder Max Overkill?
  141. SERT question
  142. vance and hines fuel pak vs pclll
  143. lost electrical but still runs update, this is a good one
  144. Thundermax after dealer maintainance?
  145. PCIII on a 2008 FLSTC?
  146. HELP! DCC Fairing installation on a Road King
  147. Fuelpak & cycle shack
  148. New owner of a used PCIII. Need help.
  149. PCIII, V&H BBS NO A/C
  150. Temporary fix for Decel Popping
  151. Thundermax software and firmware updates...
  152. SERT Map to Revert to Factory Settings
  153. Left Turn Signal stopped blinking !
  154. Starter problem
  155. cranking fuel table and warm-up enrichment table
  156. stator replacement
  157. Ignition switch
  158. wireing schematic for microphone/headset
  159. 2006 Softail Wireing Diagram
  160. Need ? answered
  161. Newbies 2nd, speedo and turn signal issue
  162. brake lite, turn signal n horn don't work
  163. error code 44
  164. Diagnose this 1200 video!
  165. Fuel pump not running
  166. No power to power plug
  167. Blinker & Odometer do not work
  168. HD Factory security system problem
  169. Sert Experiment
  170. Horn getting hot?????
  171. PCIII map question
  172. 07 Roadglide w/ Fuelpak/Thunderheader Concern
  173. Kuryakyn fuel injection controller or PClll
  174. FXD Headlight question
  175. Good Tuner?
  176. SERT
  177. dash problems
  178. Adjusting the Idle on Delphi EFI
  179. 25% gain in mpg
  180. T-Max, ANBS & Supertrapp 2:1
  181. XL1200C Speed Sensor
  182. Thundermax Autotune Install - Help please
  183. 06 back fires
  184. Anyone running a Fuel Moto map similar to my setup???
  185. ironhead ignition problem, help needed
  186. Price of a Remap
  187. Hard Starting
  188. Starter Hesitation When Cold
  189. PCIII
  190. Stage 1 or not Stage 1, that is the question
  191. Stage 1
  192. EFI Help
  193. V&H Slipons/FuelPak/SE AC Upgrade Results
  194. Voltage Regulator?
  195. Error Codes ?
  196. ThunderMax / Rush slipon Map ?
  197. PCIII, home built a/c & exhaust #'s
  198. 07FLSTC sert map
  199. driveability problem
  200. DFO,Slipons and Decel Pop
  201. Battery stranded me today....need advice on replacement
  202. Stage 1 Kit 2003 FXSTI
  203. Security System?
  204. WILL THEY FIT WITH EACH OTHER!!!????
  205. New 28 degree injector question.
  206. 07 Night Train Won't Start
  207. 1987 softail
  208. Stage I... COMPLETE
  209. Problems /w 04 Electra Glide
  210. Cannot get fire
  211. PCIII problem - dtc?
  212. module/coil test procedure?
  213. spark advance settings using sert
  214. MPG W/Cruise Control?
  215. Wiring Harness for a 1980 HD
  216. 50/100W headlight O.K to run
  217. pcIII electrical chirp
  218. T-Max knock sensors?
  219. Thundermax Upgraded Firm/Software?
  220. Looking for post that had a throttle gauge in it
  221. No electrics on Softail std 2002 (carb)
  222. Getting dyno tuned by the dealer
  223. Fuel Management & Stock Bike
  224. How do you run a dyno test?
  225. radio on street glide
  226. Exhausts and Stage 1 SE (Deuce 2004)
  227. Doc 1 is back in town
  228. SERT Knock Sensors??????
  229. starting
  230. Sporty misfire
  231. Got my SERT, and Stg I intake. Installing Saturday. Questions
  232. HD Garage opener Install- Void Warranty?
  233. Screaming hot positive terminal???
  234. Screaming hot positive terminal???
  235. Battery keeps dying...?
  236. Stage 1 results....Is this acceptable?
  237. missing ecm node
  238. Check engine light stays on too long?
  239. 2001 Road Glide heaadlight adjustment
  240. Adjusting CLB and AFR tables
  241. FOB Won't Marry To TSSM
  242. EFI and a dead battery
  243. Boogey Light question
  244. Torque vs. Horsepower via Stage I,II,SERT
  245. Security System
  246. Headlight Keeps Blowing
  247. Can this cause a decel pop?
  248. brake light stays on (help)
  249. MAP Sensor
  250. Turn signal issue
