PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Update: FIXED w/o H-D Tool! was: Ignition switch alignment tool???
  2. simple timing question...i hope
  3. 2003 Heritage Fuse problem
  4. Tuning Question
  5. INJECTORS....
  6. Ignition timing
  7. EFI Woes!!!! To Tune or........
  8. Question about SERT
  9. 1981 shovel troubles - electrical ignition
  10. Regulator install help...
  11. Replacing the Stator
  12. looking for tuner in mid west
  13. Will disconnecting the battery
  14. alarm pager batt life
  15. Red "key" light on the dash?
  16. Another PCIII Question.
  17. Looking for builder/tuner in the South.
  18. Colder Plugs ?
  19. Technical question...
  20. PCIII Timing etc ?s
  21. Best Tuner for 07 SG?
  22. Tachometer set up for 07 Fatboy
  23. Tracking down a short
  24. PC III USB EX - The EPA has won
  25. SERT Connectivity issue
  26. ignition ground
  27. DOES FUEL PAK "RESET" IF REMOVED?
  28. Can someone explain what happened?
  29. Might be a stupid SERT question, but...
  30. Need TMax install help in Nashville
  31. RPM vs MPH Values for 2007 softail
  32. V&H Fuel-Pac
  33. Shovelhead Timing
  34. Tail light problems
  35. map comparison
  36. SERT experts wanted
  37. Strange starting
  38. Screamin Eagle race tuner or Thundermax ?
  39. Firmware Update for a PC III USB
  40. PcIII map request
  41. PCIII LEANS OUT A BIKE
  42. PCIII 05 FXDWG
  43. running lights and break lights
  44. Speedo /turn signal issues!
  45. Voltage Regulator Relocation
  46. 99 FLHTPI WONT START PROBLEM
  47. Electrical Short? FLSTN
  48. Molex Electrical connectors
  49. Brake light out and warranty question
  50. Head Quarter's Tuner
  51. 01 Ultra ck engine lamp
  52. PCIII solution? Long:
  53. Dynojet kit installation
  54. 1995 FXD will not start....one click.....
  55. Fuelpak numbers
  56. Desired AFR at cruise
  57. SEII or Stock exhaust map?
  58. Stage I upgrade question
  59. PClll or PClll ?
  60. 2003 Electra Glide Classic - no idle ....
  61. Dead bike, new battery??
  62. Guess I'm one of the lucky ones (PCIII)
  63. FLHT 2002 carb, electrical problem?
  64. Anyone ever go form a SERT to a PCIII?
  65. Tuner/Mechanic in Cincinnati/Northern KY?
  66. PC III question
  67. Checking for intake leak....
  68. Stalling 1995 Electra Glide Classic.
  69. Speedo problems- '02 EG std
  70. Radio fuse keeps blowing
  71. Power Commander III USB Accel Pump ?
  72. Need a Bit O' Tuning Help
  73. Alternator output
  74. 99 Ultra Classic...just shuts down while driving
  75. rear cylinder leaner?
  76. K&N 3909 - oil drip
  77. Modded SERT map for 07FXST
  78. Battery draining...
  79. Good Tuner In WI or MN?
  80. running rich at idle
  81. Colorado Springs Tuner
  82. Thundermax on '07 Sportster?
  83. How Do I get at the PCII on my 03 Serk
  84. idle air control chatter with engine and key off
  85. Front plug missing?
  86. Can I get my tune OUT of my ECM with a SERT?
  87. Newbie Exhaust Question
  88. SERT Data Mode Question?
  89. Help on Security System Please
  90. 88 sportster 883 won't start
  91. Starter, Any Ideas?
  92. 03 SERK w/750mi , Stage I & PCII Should I update to PCIII?
  93. EFI Timing tables
  94. could someone identify this please
  95. Did I mess my 2007 Sportster up...already?
  96. 60GB iPod Video & iPod Nanos
  97. Bad Ignition Switch?
  98. TMAX What AFR for best cruise mpg
  99. 03 Heritage stutters
  100. Passing Lamp Relay Failure?
  101. Turn signal problems... HELP!
  102. Central IL shop for SERT tuning?
  103. Yep! Bad Crane ignition!
  104. Brake Light not working
  105. No juice at ingnition switch
  106. Starter, Voltage Regulator, Battery????
  107. PCIII throttle position question
  108. spark plugs vs. knock sensor
  109. Bassani PC III Maps for 01 RK
  110. 07 tach wiring
  111. CORRECT STEPS TO TAKE - NEWBIE
  112. Wiring connector unpick tool
  113. PC111 TRUE or FALSE
  114. looking for feedback on TMAX w auto tuner
  115. breakin map for new build
  116. PCIII expectations?
  117. FUELPAK INSTALL ON 07 ULTRA???
  118. Still have misfire problem.
  119. Running lights wont come on anymore
  120. PC III EX
  121. PCIII 0%THROTTLE
  122. 03 FXDL
  123. PC3 USB Maps?
  124. 8 degree or 25 degree injectors.
  125. Radio Troubles 2004 EG
  126. Disabling the security system?
  127. Crane HI-4 ignition wire mashed
  128. Thundervolt spark plug wires
  129. Battery drain electrical wierdness
  130. Dyno tune
  131. ECM connector plug for SERT ??
  132. oil in air cleaner?
  133. Lights out?!?!?!
  134. SERT? for 07 Ultra
  135. Engine Light
  136. Which is best for stock?
  137. SERT-ping ? or not ?
  138. Intermittent misfire
  139. turn signal problem, please help
  140. Dyno Complete..Surprised by SE A/C increase
  141. Off to dyno...what to expect
  142. SERT disc ???
  143. Thundermax and detonation issue?
  144. Help! Ignition module problem?re, dual coil, Crane HI-4 ignition.
  145. New Battery Issues
  146. Many Questions on Adjustable Map Ignition
  147. Turn Signal Relocation Kits for Dyna Wide Glide FXDWG3
  148. Ignition Modules
  149. Bootloader problem - SERT
  150. #78 start place w/new SE AC on 07FLSTF?
  151. efi tuning
  152. auto turn signal shut off wont work?
  153. Hard Starting with Fuelpak,SERT,PCIII?
  154. HELP!!! Need SERT tables for FLHTCUSE2 W/ RHTDs & SE A/C
  155. '02 Deuce Turns Over But Doesn't Fire Up
  156. engine quits intermittently
  157. ignition switch part # 04 FLHTC
  158. SERT Manual
  159. O2 Sensor placement?
  160. Blown Main Fuse
  161. Headlight Fuse Blows
  162. Won't start--good battery
  163. 96 Road king stalling
  164. Thundermax dyno
  165. white spark plugs
  166. DTC help
  167. terry problem?
  168. Great customer service by DYNATEK
  169. blinkers
  170. Parts??
  171. check engine
  172. 2007 Sporster Low Fuel Indicator
  173. fxst dash lights?
  174. Electrical interference (GPS - Autocom)
  175. V&H Fuelpak & Pinging Question
  176. back fire on down shifting, pop,burbull,pop
  177. Thunder Max = Check Engine
  178. crane single fire coil part #83005
  179. Keep loosing low beam
  180. PCIII Maps - Differ. between 25° and 8° injectors
  181. Map for My Lowrider
  182. Question about fuel pump
  183. Thundermax issues...looking for help
  184. SE Race Ignition
  185. TMAX Map Help
  186. decel Poping after remap
  187. Throttle Position Sensor
  188. revxtend help needed
  189. will not start
  190. suggestions for PCIII map
  191. SERT Maps
  192. 82 FLH
  193. PCIII vs TFI
  194. Switching my 99 MM FI
  195. PC III info
  196. tssm - left turn signals stopped working
  197. ThunderMax is the greatest!
  198. (SOLD) Screamin Eagle Race Tuner For Sale
  199. SERT fine tunning confusion, help needed
  200. Harley electrical connectors: AMP, Deutsch, Molex
  201. ANY ONE KNOW HOW TO TEST the TSM/TSSM On an 03 Dyna Fxdl lowryder?
  202. thundermax troubles???
  203. Code issues TSM/TSSM
  204. Cough, power loss, dies @ highway speeds
  205. any wego II users?
  206. replacing vss
  207. PCIII Throttle Hesitation on '06 Models - try this!!!!
  208. just Quit!
  209. wiring diagram?
  210. need pcIII map
  211. Re-wire handlebars & add lighting
  212. Battery Charging
  213. my 2 cents about a p.c. 3 or any of turners on the market
  214. internal throttle
  215. Race Tuner vs. Twin Tec
  216. HELP PROBLEM WITH KURYAKYN LED FRONT TURN SIGNAL
  217. LED Light Kits?
  218. TFI/DFO placement
  219. code p0122 please help translate
  220. Help please with turn signal, horn, brake light problem
  221. Fuel Pump Issues???
  222. Newbie in need of help!
  223. V&H Big shot duals & pcIII
  224. Dyno done on my super glide
  225. pc3 sucks on the 07
  226. download race cartridge 1550 for 2003 FXSTI
  227. air/fuel meter
  228. SPEEDO
  229. pcIII and my 07 Roadking
  230. TMAT Map for D&D with Quite Baffle?
  231. crane single fire coil
  232. Heated Grips - Bad Product
  233. Race tuner
  234. Right turn signal problem
  235. Bike just quits? UPDATE AGAIN
  236. SERT Question
  237. Good shop for a SERT and/or PCIII in Dallas area??
  238. 3 Phase Charging System??
  239. 07 Ultra Classic heat and remap
  240. 1997 FLHRI
  241. AGM battery vented
  242. Detailed Procedure to Adjust Throttle & Idle Cables on EFI Bike
  243. Treminal Velocity II - fantastic!
  244. New "J" Version
  245. Charging System Failure
  246. Fuel Pak install on 07 Fatboy
  247. PC III USB AND HOT PIPES??
  248. WHAT Is a Sert ?
  249. BT801 Equalizer Question
  250. I need a switch to match the one for the odometer
