- Loss of Electrical on the highway
- Battery Tender
- PC-V with Autotune question
- flhtp wiring diagram
- how can I know if previous owner had ecm flashed
- buying a used PCV, any issues to look for?
- Serious Problems
- help with map for power commander
- 01 Ultra Classic Code Retrevial
- o6 ultra classic wont start
- 08 Touring Idle Speed Adjustment??
- bike acts like its being stolden
- PCV Autotune And 6th Gear Light
- I Have a Problem....HELP!
- 2002 UltraClassic voltage drops above 2K
- no spark on 07 dyna lowrider
- throttle-by-wire limp mode
- New Stator-Won't Charge
- 198 Fat Boy Circuit Breakers
- fuel injection
- fuel injector issue
- VSS Vehicle speed sensor
- R turn signal staying on...all the time even w ignition off???
- PCIII-Map request
- 95 Sporty 1200 Electrical Issue
- Heritage Tailight Wiring
- E3.36 Spark Plugs??
- New and Confused?????
- Question for charging system experts !!!
- O2 sensor question
- What to expect from the Dyno
- need help with tts o2
- life span for unused battery
- SEST tuning questions
- Switch Housing on a 2007 Dyna WG - Electrial ?
- Speedo
- 2001 flhtcui wont stay running
- TTS Master Tune
- IAC gremlin
- '00 FLSTC front turn signal SNAFU
- 89 fltuc electrical issue
- 2003 Deuce EFI - Throttle pre startup normal?
- 99 Softail Speedo quit...
- It is like riding NEW scooter
- new pipes, air cleaner. anything else i need?
- Ultra Classic Electrical Problem
- Starter & Headlights quit working
- Massive disaster, help needed!
- 2000 Electra Glide cutting out
- 2000 Fat Boy...no spark
- Stage Definitions for Dummies
- What have I got here?
- thundermax O2 problem
- Dyno Tune Shop
- 25mpg after tune
- '02 Radio cut out....easy fix
- TTS rookie question
- Which tuner?
- Help
- no start
- Charging system problem ?
- PC III Map with HD ECM Download?
- Help setting computer for data runs
- Low fuel light
- Electrical noise ?
- Need help intermintent trouble
- no spark on front jug poss ecm ???
- Spark Plug Wires
- Power Commander IIIUSB Problems, HELP!!
- Cruise Control Problems
- ECM Download Question
- Help me fix this circuit please.
- lost power on my 103
- Digital Technician changes made after SEPST Map saved?
- jump starting an Electra Glide
- Strange electrical problem
- SEST Question
- Timing
- starter problems
- starting issue on a 1988 flhs. need options
- TTS mastertune question
- Pc111 question
- spark plug gap
- Splicing in Red turn signals to be on
- Tell me how im doing (Dyno sheet)
- Front Turn Signals Flash When Engine is Revved
- am/fm radio problem
- ECM removal
- Fly By Wire Throttle Failures
- That annoying little yellow engine light
- Bike Stalling After At Lights
- Looking for some suggestions to diagnosis an electrical problem
- Experiences using SEST Pro and Smart Tune
- Power Commander V on a Cross Bones
- Need an Indy in Seattle
- Map help, SERT (Not sest) 08 TBW wod 6-6 96" stock heads
- p0152 fault code
- Front cyl. has me baffled
- 06 Street Bob Turn Signals
- Reliable tuner in S.W. Ontario
- 03 Backfiring out both ends
- bike back fires, then dies coming to a stop
- 2007 street glide flhx !!WONT START!!
- Dakota Digital help
- still have issues need your help
- ve values
- Removing a fuel tank top plate on 2009 FLHR
- Power Commander ?
- SE Ignition Module Wiring
- Accel Mega Fire questions - Timing and VOES
- 07-sportster fi-2000modulesettings
- newbie needs help (long read)
- Main Thermal Breaker Question......
- SEST or TTS Mastertune
- Ignition status light
- Sert map
- pc3
- No spark. ECM?
- Why no how to on the SEST?
- New member
- code retrieval
- Opinions on Direct Link Tuning?
- dealer download/timing?
- changing running to brake lights...need help
- New TSM, no security indicator
- What do the Closed Loop Values = ?
- Advice needed - '05 Dyna w/ T-Max A/T
- 1990 flhtcu power and grounds check
- low rpm/speed surge normal?
- Trouble with new bike
- Using PCV With Softail Custom, Can't Use Seat Strap?
- 2002 road king
- 2001 FLSTC quits at random
- 77 superglide valve noise
- Why Run Bike In Closed Loop???
- A/N Big Shot Tuner for '09 King?
- tts cable question
- Tts q?
- What's going on with the ignition?
- 2010 ROad King and SERT Connection not Recognized
- need pcv help
- 97 Road King Electrics
- 87 fxr electrical battery problem
- Vehicle Speed Sensor ?
- Brake light not firing - 07 Night Train
- Fast idle on 2000 1550fi?-temp switch
- Fuel Injection pump removal
- Tail Light Question? Help!
- Rough idle after installing PC V
- lean surge after engine heats up for an hr.
- In Need Of A Map Unitl Breakin Period Is Over.
- Need a whole ignition switch
- coil testing
- What has been used to tune by bike?
- dash lights acting funny, fuse issue
- Can't find a tail light!
- 113" build with 58mm tb
- PC V Popping... Considering DynoJet AutoTune???
- Strange factory alarm problem
- Open Loop vs Closed Loop
- don't want to get caught in the heat!
- Turn signal module
- Evap question.
- Accessory Switch
- 2004 FLHTCUI is missing
- What are common causes for the starter to click then fire?
- Throttle Position Sensor
- Asking for help with an odd turn signal gremlin
- Turnsignal Will Not Work :/
- 05 Ultra Would not come back on.. Help Please!!
- Need Help running funny
- Brake Light/ Relay Issue
- PC-V or Thundermax?
- h@ly $h1t
- HD headset
- Sert 32109-08a
- 06 FXSTBI won't start after assembly
- Horn Dead
- General electrical question
- 86 Sportster won't start, possibly ignition related
- No spark
- Old Horn
- Trouble with maping
- I need help to figure this out.
- Won't start
- Turn signals don't work.
- leak at quick disconnect
- tts question
- 10 HP for $250?
- Could really use some expert help with mini speedo
- 2003 road King Charging Issues
- MasterTune TTS wont install
- Engine Tempature Control System
- TTS - AFR Enrichment to remove Decel Pop
- sert 32107-02d
- MM EFI Upgrade
- Electronic gauges flicker now....
- Starter jackshaft sticking at oil seal
- Power Commander or Fuelpak
- HELP!! PCV issues/questions
- Starting electrical anomalies
- Red Key light on after I switched out front running lights to LEDs
- Netbooks with tuner ?
- My first TTS Run..
- 87 electra glide, front brake lamp switch problems, loss of front running lights????
- FLHTCUI work order invoice explanation
- 09 Sporty-Will a PC-V Fit under my Mustang Vintage Solo seat?
- My Direct-Link dyno tuning results are in.
- starting issue
- hit the button...not even a groan....
- Starter Solenoid
- Data loging on '08 Touring model?
- Magneto pros and cons
- leaking inj EFI
- Bike is DOA
- SE or PC? whats your choice?
- Fuel Type
- street glide map?
- cruise control without factory speedometer
- pc3 issues
- Idle and Decel Backfire
- Tuner Questions
- no power
- Charging System Voltage - Typical
- Tuners
- Sportster Speedo
- brake light power wire?
- Hi beam goes out
- help with remapping
- TBW Thundermax with auto tune
- My Wide Glide just dies!!! Why???
- Need map for SE-203 & 88"
- 2006 Fuel Injection Service Bulletin
- 05 Ultra loss of Gauges and fender lights
- SERT Maps for Download?
- Backfires then starts
- Bad Voltage Regulator only?
- Harley Carb SERT
- Will Changing to a 30 T Pulley require a Remap
- 1999 FLHT, Self canceling turn signals
- At Witt's End
- Throttle pos reset in PCIII?
- PCIII map without timing?
- Thundermax issues
- TSSM question
- rg 08
- Question for Jamie at Fuel Moto
- Please help
