PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Popping
  2. 2005 FLHRCI SERT Map
  3. dyno tuners
  4. ignition wiring
  5. power commander V
  6. Plate side mount
  7. Tail Light Flickers
  8. new speedo help
  9. Layback plate and turn signal relocation kit
  10. fuse panel removal
  11. High Voltage
  12. SEST closed loop questions?
  13. i need a wireing diagrams 85 fxst
  14. What PC lll are you guys using ?
  15. Screamin' Eagle EFI Race TUNER - SCREAMIN EAGLE EFI RACE FUELER
  16. Engine light did not show
  17. Garage Door Opener
  18. Electrical Issue
  19. most likely cause for no spark 2004 Deuce w/ Carb.
  20. left control adjustment
  21. I need a PC3 map for my 113 build, anyone?
  22. tuners???? zippers,daytona twintec
  23. I need to richen my bike up
  24. Neutral Light staying on
  25. 2008 Ultra turn signs not working
  26. Spark Plugs
  27. Starter Opinions
  28. spark plug wires
  29. Wont Start
  30. DIY Tuning
  31. 2 different FI systems used by Harley?
  32. speedo/tach combo backlight help...
  33. Tmax Timing
  34. BigD
  35. Having trouble updating firmware
  36. 05 ultra relays
  37. Valve Pocket Question
  38. What was last year for a carb on Ultra Classic?
  39. Turn Signals
  40. Air intake Solenoid Eliminator
  41. Ping in Neutral?
  42. battery probs
  43. Newb Here: 1998 Softtail Custom Electrical/Electronic Issue
  44. Strange - Fuel Guage, Fuel Light Issue
  45. Stereo question
  46. What about Vtune, glens
  47. Starter keeps running, '82 FXR Shovel
  48. Starter MAP file?
  49. SE Phat 10mm plug wires question
  50. dual map
  51. Tuning with PCIII
  52. SERT and low idle
  53. Major issue, please help EFI
  54. Help Troubleshooting Electrical Problem Please?
  55. 2000-FLSTC w/ carb., Where to pull temporary TACH signal...??
  56. Any Reason to Use XIEDs With Thundermax?
  57. EFI set up help needed with SE 113" kit
  58. springer classic pipes on deluxe help
  59. break light...
  60. new pipes really require a power commander?
  61. New cams, map needed
  62. Different FI systems usd on harleys?
  63. Harmon Kardon Problem
  64. Dual lights for brake/running
  65. rookie needs help...engine not cranking
  66. Fire through throttle body
  67. Thundermax Starting Issues
  68. Super tuner web update not working?
  69. TwinScan II
  70. Dyna 2ki Ignition
  71. Blinkers question wiring
  72. TTS question for Glens
  73. FuelMoto, Jamie and the new PC-V
  74. Pcv
  75. Need Help
  76. TTS usb cable
  77. IPOD Wiring
  78. 08 Throttle by Wire Help!!
  79. PCIII usb code 39
  80. xieds
  81. ECM Update for True Duals
  82. Kuryakyn Light - Need help finding "Run" wire
  83. thundermax issue for newbie
  84. Help--SEST or PCIII
  85. DTC P0261 on 06 FLHX
  86. Dyno tune 09 touring with stock pipes
  87. Dyno in 4th or 5th gear
  88. 2001 FXDL L/H and R/H switch harness's
  89. ecm pigtail pins ?
  90. Why adding harware over software solution?
  91. Hooking up my SERT
  92. Pc v
  93. SE Race Tuner Info
  94. Sert
  95. V-tune question
  96. circuit breakers
  97. SE Super Tuner Data Log
  98. No brake light...please help!
  99. horn inputs - polarity?
  100. EFI to carb swap?
  101. TTS starter Map
  102. Popping on Decceleration
  103. Cost of Stage 1 Reflash ECM
  104. 12V or magneto?
  105. VDC Batteryminder
  106. RPM Rev Limiter...??
  107. New power commander 5
  108. Disarming Alarm? '06 Street Bob
  109. The 2009 RK fuel pump doesn't turn on
  110. Installed HD HID headlight kit-it works-won't start
  111. brake in map
  112. SE ignition module
  113. 98 EVO Jackshaft Problem
  114. Battery losing juice
  115. Spark plug help?
  116. 05 Classic NO FIRE ??
  117. SE Race Tuner
  118. New Super Tuner and 09 Ultra
  119. CB Radio Install questions
  120. Tmax and Auto Tune.
  121. 09 FLHX throttle failier
  122. Battery charger light won't stay red
  123. GPS instal...
  124. Which EFI do I have? Idle question?
  125. LC1 wideband ??
  126. This Is a I need thread
  127. ThunderMax has a software upgrade 2008-1-7
  128. Electical issues H/L S/L T/L ABS Passing/L
  129. 1985 FLHT Spark Problem
  130. PCIII error code 39 coming up! Need advise
  131. PCIII vs. SE Race Tuner
  132. High Air Flow and fuel delivery question?
  133. EFI Tuning / Reversion / Camshaft Dilution?
  134. tts step by step
  135. TTS Tuner: available in Canada ?
  136. Option,s for 2005 efi fuel upgrade
  137. 04 softail low fuel light.
  138. TTS Mastertune Information
  139. Radio Shack alarm for 09?
  140. TTS Map for Stock 2009
  141. PC3 maps other than Dynojet's?
  142. 97 Springer Electrical ?
  143. crane fireball ignition
  144. pc111usb ignition timing map
  145. Injector ?
  146. Electrical question on a 92 Ultra Classic
  147. Fuel Moto PCIII maps
  148. 80 inch Shovel, stage 1? also, Prog. Ignition
  149. LC-1 WBO2 sensor
  150. Lizard lights control
  151. Difference in Pro Super Tuner Part No's
  152. Symptoms of a bad starter
  153. Dyna Speedometer
  154. Fuel Gauge trouble
  155. Need some help tuning...or do I have a misfire??
  156. Need fitment help!!
  157. O2 sensor part number ?
  158. Battery Question
  159. Turn key to ignition and NOTHIN"!!!
  160. Power commander V Idle adjust?
  161. Newest SERT
  162. Tuners and Builders - A question on Dyno Charts
  163. Headlight Issue After Washing Bike
  164. Who's using a HQ Pro tuner
  165. Which fuel tuner??
  166. turn signal question
  167. Springer Won't Start, Just Clicks--Help!
  168. turn signal stoped working
  169. Power Commander Quick Shifter
  170. Ignition relocation question need info
  171. Braided cables
  172. Dynojet PC-V or TTS MaterTune
  173. American iron letters ?? tune not needed?
  174. no start
  175. NGK Iridium plugs and Ion Sensing system
  176. Need Help tuning a PCIII on a 2007 FLHTC
  177. SEST v1 update
  178. 2000 Road King Classic need some advice
  179. a good multimeter?
  180. Fatboy06 PC111 Map
  181. Super Sert Tuners
  182. Rev-Tech Stealth DFO v Cobra F12000
  183. Using Power Commander is Rear Cylinder #1 or #2 for fuel trim?
  184. Flashing Lights?
  185. Reno H D
  186. Intermittent problem
  187. Braided Fuel Fupply Line.
  188. Pro tuner questions
  189. No electrics when ignition switch is turned to "ignition" position.
  190. TTS Info
  191. inop turn signals
  192. TTS Update Sticky?
  193. DynaJet's new PC V?
  194. Tmax map for 103
  195. thundermax base map
  196. TTS Master Tune question
  197. 2005 Ultra audio schematic needed
  198. 2003 Fat Boy EFI Running Issues
  199. 2003 Fat Boy EFI Running Issues
  200. HQ 113 and Tmax
  201. Error Code 31
  202. When do you change injectors
  203. HD layback license turn signal relocation kit
  204. 05 dyna power commander
  205. TTS MasterTune speedometer adjustment
  206. 02 Softtail
  207. PCIII or SEST?
  208. VTuning at various temps???
  209. Method to clear a fault code?
  210. fuel pump
  211. 2000 Road King EFI dies after 30 sec-no spark
  212. Help the dummy with SERT.
  213. Blinker system
  214. Radio problem on '87 FLHTC
  215. Need help understanding the cause of knock
  216. Data Link Connector
  217. Horn Fuse
  218. Blinker Problem
  219. HDs New Super Tuner
  220. No Spark! Sort of? 1966 Electraglide
  221. Which tuner??????
  222. TTS Warm-Up Enrichment
  223. TTS Warm-Up Enrichment
  224. Harley Davidson MP-3 Player
  225. Road King EFI Help
  226. anyone with a wideband AFR guage?
  227. Looking for a map??
  228. Mapping Differences?
  229. Advance curve question
  230. Pc v
  231. do I need a Fuel Management Controller?
  232. Bootloader Problems?
  233. Tuning option
  234. Bad Gas or Did Tune Change
  235. Mounting Circuit Breakers
  236. Anyone help me?
  237. Super Tuner Version Question 09 Ultra
  238. New wire old plug
  239. Well I searched to no avail....
  240. Ignition Switch Problems???
  241. Best place to buy Thundermax w/ Auto Tune?
  242. Spark Plug Gap setting 03 ElectraGile
  243. FI Remapping for 2009 Ultra
  244. Using TSII/Wego w/TTS Mastertune?
  245. Hesitation when accelerating
  246. 08 roadster 1200 idles high
  247. Need a good reliable PCIII Dyno technician - South Florida
  248. ied & xied's
  249. TTS mastertune speedo calibration for 09 ultra
  250. 2009 PC-V verses the new ThunderMax
