- TMAX 4.5 firmware update
- Tmax Tuning Question
- PC III for 08 models
- TVII How to's
- HELP! MAJOR Prob!!!
- thundermax
- PC III
- Carb to EFI Conversion - Does anyone make a complete kit?
- Turn signal wires
- TMAX-Didn't pull ECM fuse before disconnecting battery-?
- Stock Ignition Maps
- SERT Tune/Dyno cost
- Speedo sensor
- Help. Engine check light turns on twice.
- Help - Bike starts runs a few seconds and dies
- SERT tuning
- T-Max wont quit detonating
- 95" upgrade has engine light on - need advice
- TSM Question
- Turn Signal Wire Harness
- lost spark on o1 Ultra
- What does it mean??
- Need PC3 Map
- Shovel Eletrical problem
- FOG LIGHTS INSTALL - MOTO LIGHTS ??
- sert help
- wiring question on 07 fatboy
- Intermittent starter grinding on 07 WG
- '98 Dyna wiring question - idiot asking!
- Looking for a good Dyno SERT tuner in south florida
- putting OEM air cleaner back on
- converting txt to mt5
- popping on decel....07 Deluxe SERT
- Electrical/Starting issue
- Speedo and 6th gear ind. light won't work
- 113" & VOES?
- will fuelpack stop 'popping'
- Run with mods?
- Techillusions?????????????
- Work Light
- Main circuit breaker location?
- electrical drain
- PC III map for 2005 Ultra
- Speedo on 02 Sporty
- a two-fold question
- fuel tank float
- Power Commander Porking
- Tmax
- Which map
- Break out box
- Fuel Storage mix vs. EFI ??
- Anyway to check rpm's with a multimeter?
- PCIII Installed on a Nightster
- What about HD Stage 1 Flash?
- MAP sensor function
- Do I need Dyno Tuning?
- Any diagnostic tools for 95-98 MM efi?
- Starts and runs fine but for only six miles. Any advice??????
- sert question
- Electrical problem on 07 SG
- homemade fuel light
- Which Fuse?
- Which Thundermax to Order
- ecm
- Road Tech Radio sound problem ON/OFF/ON/OFF
- starter problem
- Code P0505
- LED fuel gage proble-help please
- accelleration
- Cooler Spark Plugs
- Battery Drain
- Volume Control
- Terminal Velocity
- Headers glowing!!??
- sert cal file needed
- More Sert Questions
- SERT vs PCIII
- Any info on these 02 enrichers??
- Battery fluid low(spilled)
- Tmax tuner
- help i'm stumped
- 2007 Ultra battery problems?
- TwinScanII's for $150??
- o2 sensor question
- Do I really need stage 2 download
- pro one turn signal bar
- no power
- What's the difference in HD tachs?
- TMAX installer for hire in SoCal?
- Tmax 4.5 firmware
- Where can you buy the socket / reflector for Bullet Turn signals??
- VOLT GAGE QUESTION.
- TECHNO RESEARCH RACE TUNER QUESTION
- Sensor Connections
- Engine light
- Need A PCIII map
- My mileage stinks....
- stage 1 removal?
- Electrical Component Supplier??
- Rear LED signal problem
- 98 RK Engine Temp Sensor Install
- molex crimp tool??
- Exhaust, TMAX, and A/C Install Sequence ?
- autotuner w/o sensors
- TMAT Still Amazes Me
- V&H fuel pak problems? Or HD ECM?
- PC III Firmware Question
- 2008 Throttle By Wire
- Wiring help
- Can I get a flash for this?
- security light problems
- my last sert cable question(hopefully)
- aerowinder
- sert issue: win xp restart during flah, HELP PLEASE
- sert cable question
- tuners in so. jersey
- Looking for Dyno in Houston or Dallas
- O2 eliminators on tuners
- Perse tail light problems
- NOT CHARGING
- Internal throttle on EFI?????
- Fuelpak installed... couple of questions
- Ignition Problem ???????????
- Gas Milage the Same with RT?
- Damn Lying Volt gauge !
- TMAX
- efi retune?
- fuel pak, PCIII, SERT...
- 07 street glide - knocking pinging noises
- Which SERT MAP
- Stuck
- Adding Blue Tooth to Ultra Classic
- turn signals
- voltage reg
- speedo got a mind of its own!!
- Extra turn signals
- Anyone have a shop manual - '05 FXDCI?
- SERT Cable Pinout?
- Starter clatters
- SERT and DYNO Completed - Are My Results OK?
- Tachometer Repair?
- pcIIIex help?????
- Circuit Breaker Noise
- Jump starting from a car???
- error code
- Tach wire on 07 RKClassic
- how much diffrance is the map after inst.37h cams?
- no spark
- Tmax Question
- Part # for 1998 FLT cyl head temp sensor?
- New Sert software 4.7.7 comparison
- Tuning Question
- SERT and True duals question....
- Rear turn signal relocation
- 1999 Road king Classic added tour pac
- 2006 Ultra Classic pigtail?
- Changing the battery
- Question about PCIII install
- Battery Tender Woes - Result... Dead Bike
- gas mileage with PC 3
- How do you get the timing right on the money
- Brake Lights
- 08 ECMs NEW TUNING METHOD 0$
- pop goes the battery
- Loading modified map
- warning light
- Motorcycle Electrical Book
- alternator wiring
- Hard starting Wide Glide
- Cobra Fi2000R. Rear cylinder running problem!
- SERT wont read
- Factory fitted alarm
- '98 Evo options with PCIII Thundermax
- Revtech DFO tuner - Opinions/experience
- 08 circuit braker
- brake light/ turn signal module question
- Headquarters 6100 v Twin Tec
- '98 FLHRCI efi conversion from MM to Delphi
- 1996 heritage wont start
- 2003 FLHRCI IDLE Question
- '98 RK Engine Stays At High Throttle
- PCIII map for 05 Ultra
- sert question
- thundermax for 2008?
- Bike Will Not Start Please Help
- Sert software 4.7.6 question
- PC3 W/SERT cal?
- Need help with PCIII-USB map
- lights dimming
- Matching ECM and TSSM
- Replaced ECM Bike Won't Start
- 2008 softail SERT downloads?
- Starter/Solenoid
- pipes on efi
- Tmax SmartLink Software
- power or race
- better way to mount PC III
- Race Tuner 13.1 Fuel Ratio
- RECALL of some SE Ignition Modules?
- Head Quarter Pro Tuner info.........
- LED TAIL LIGHTS
- lost power on rear cyl
- Battery re: Winter Storage (07 Ultra)
- Daytona Sensor Twin Scan Tuning
- hard starting
- Which SERT Software to Purchase
- sert first time download help please
- Security Light Trouble...
- What will influence ECM to Richen the A/F Ratio
- Scanalyzer
- HD and Panacea
- Is This True?
- Start switch wiring
- ABS Light On
- Battery Questions
- 2008 softail standard
- SERT cables
- SE Plug Wires - Inteference with ECU??
- What else could make a bike run hot?
- Terminal Velocity VS Thundermax
- Taillights
- Stage 1 Download vs SERT
- what stator to buy
- Trouble code
- ECM Opinions Please
- Power Commander assistance please??
- wiring to spare on fuse block??
- Oh SERT gurus, a question for the masters
- Open loop / closed loop
- SERT Questions
- no start, no spark?
- Stock AFR
- Tried search, no help, Charging system?
- New SE Race Tuner Part #
- SERT Cal file 159 changed to 176
- ThunderMax Setup Question
- Dyno tune necessary?
- Wiring from Handlebar throught Riser and bottom bolt.
- Nightrider O2 Sensor Enrichment Device
- IAT Values
- Run What u Brung
- Simple Wiring Tips needed
- 08 SERT data files?
- What happend?
- SE 32719-01B Ignition modual
- Name of Twin Scan II Experts
- running lights keep blowing fuse?
- p1010 dtc?
- Tach wiring
- 02 Road King fuelly with stumble
