PDA
View Full Version : Ignition/Tuner/ECM/Fuel Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Ignition switch relocated- concerns
  2. blowing 15A ECM fuse 07 night train
  3. Compare different maps with same upgrades
  4. 2014 Street Glide Special Sputters and dies while riding
  5. Fatboy harley 2003
  6. Fuel Issues...need some help
  7. DynoJet Power Commander Trade In
  8. Got my New AutoTune Today....
  9. Thundermax tuner IL or WI
  10. dyno tune
  11. Looking for good Dyno tuner to tune with PowerVision in western PA ?
  12. Is This Enough PowerVision Data?
  13. Weird starting issue
  14. Need some help, dont know if this the right forum but???
  15. 2015 Dyna+Security System+Fuelpak3 = Engine Light On?
  16. Idle issue on ’04 FLHTPI twin cam 88
  17. power Vision with Auto tune pro.Guru's needed
  18. top speed only 100MPH
  19. Fatboy 2003
  20. xied question
  21. PV AutoTune Pro Problem
  22. Killing Spark Plugs
  23. No throttle when slowing and only half throttle under power
  24. 07 Dyna Super Glide FXD Air Cleaner Question
  25. Installed A PCV,, Now Bike wont start!
  26. EFI engine light
  27. MGS Exhaust- Performance Package (2011 Street Glide 103)
  28. Power Vision Map Needed
  29. Bike got rained on couple of weeks back
  30. PC 3 tune 99flhtci needed
  31. fuel pak questions
  32. Missing tables on PV tune, a problem?
  33. 2012 FXSB 103ci - Need help with P/N's for larger 4.9/5.3 injectors or 50mm SE TB kit
  34. Re-tune after battery work?
  35. How to remove strainer from gas tank
  36. Starter Delay
  37. Ignition upgrade for '06 FLHT Carb
  38. Linux and SuperTuner Software?
  39. 2012 Stock FLHX Won't Immediately Restart
  40. Electronic Question
  41. New Pro Pipe, now we have stuttering.
  42. New pipes & now a little rough off idle
  43. new TSSM learn on 09 fwcw/c help please
  44. va.hog
  45. TTS + Mods...First Start??
  46. In search of Long island member who can tune a Thundermax
  47. 2009 Superglide Custom Intermittent Vibration and getting worse!
  48. little help please
  49. Improper PV programming, an issue?
  50. Got the SEPST dialed in on my Fat Boy!
  51. open or closed loop for 2015 street bob
  52. My pc3 goin bad? Or did it go bad
  53. 2012 electra glide limited
  54. missfire, back-fire, stall's and clouds of smoke
  55. Arlen Ness Twin Sucker
  56. ingition switch help
  57. need a pcv map please
  58. I need a calibration file
  59. Power vision tuning questions
  60. Trouble starting but runs great: What gives?
  61. Fuel pump continues to prime
  62. stage 1 download cost
  63. Very first issue on my 06 softail classic 34k
  64. Help! SEPST question. Can I use this canned map for bike?
  65. 99softail won't crank!
  66. PV, bike wants to stall out. will not idle
  67. Ignition changeover Choices 97 Dyna
  68. power vision or something else?
  69. Fly by wire throttle
  70. Tuner
  71. Power Vision Map Request
  72. FP3 Mounting Location
  73. SERT wont connect to computer.
  74. Best Tuner of 2015 Street glide?
  75. MPG mysteries
  76. do i need to tune?
  77. V & H FP3 VERSUS Cobra Fi 2000 Powrpro
  78. Need map for pc5
  79. speed sensor to ecm
  80. backfiring, jerking forward, stalling, speedo jumpimg
  81. Add Better Mileage to the Stage One List
  82. No power to coil
  83. 2014 Limited, stuck ignition after reinstall
  84. Brand new Bike won't start!!!
  85. Help identify the problem
  86. need some direction
  87. TTS Error
  88. ignition issue ?
  89. 2006 street glide issue
  90. Screaming Eagle 32136a race fueler tuner deceleration popping
  91. Turning Autotune off.
  92. TW-222 and Thundermax
  93. 2009 injectors not delivering
  94. X wired the fueler
  95. Can the PV2 be used to adjust idle
  96. Engine stall when pulling clutch in --- FIXED
  97. 2007 street glide
  98. ECM code storing
  99. newly installed vied
  100. My FuelMoto 107" Just Dyno'd
  101. 08 Ultra Classic won't accelorate
  102. No start help!
  103. TTS tuning a 2015
  104. Is there a connection?
  105. EFI to carb
  106. Flat throttle (no snap)
  107. PCV and slow starting
  108. Why Auto Tune FP3
  109. SEPST price
  110. Can somone look at my log? - Knock problem
  111. 98 Ultra coil power loss
  112. Fuel Moto Micro Tuner Question
  113. Non start Fatboy
  114. Power vision auto tune
  115. In need of a map
  116. PCV and Ignition
  117. Fuel spewing from cracked continuous vent line!
  118. Tuner fp3?
  119. Power Vision tuner training question
  120. 74 shovelhead timing window help?
  121. Spark Plug Wire Routing??
  122. Does FP3 show HP and TQ?
  123. Low fuel range light on with full tank of fuel
  124. Ghost Knock? Turn off Knock sensing?
  125. Abit of a story on ignition issues and some feedback please
  126. dyno or not to dyno
  127. Which tuners retain the stock O2 sensors
  128. Calibration File for 2008 FLSTF
  129. Ultra cutting out
  130. EFI Race Tuner
  131. cfr mufflers
  132. thundermax question
  133. How to tell if ECM is set stock
  134. 99 FXDWG Engine light
  135. Diagnostic code- 61004 and PN???
  136. PCV map
  137. Please Help: Gas dripping non-stop
  138. Air Flow questions for Rushmores - do we need more for a stage one?
  139. PCV installed now delayed start
  140. 1996 Tour Glide/MM EFI tuning questions
  141. RCXcellerator tuner for MM EFI
  142. Stage 1 worth the cost?
  143. Efi Tuner advise
  144. Need advice: PCV killed mileage from 40+ to 32!
  145. 02 sensors and fuel additives or octane boosters
  146. Bike stalls on cold starts
  147. TTS file conversion
  148. Screaming Eagle Pro Tuner
  149. no start--no power to fuel pump fuse
  150. Fuelpak
  151. 113 cubic" and TMAX 112 issues
  152. Carb Problem?
  153. 07 Fatboy won't start
  154. 2007 sportster 1200 popping through the exhaust
  155. Tuned and Poor Mileage
  156. Do I need stage 1 download??
  157. 2010 fxdwg throttle body size?
  158. Stage IV PRO MAP REQUEST
  159. FP3 and Trike 2014
  160. PV-1 and Triglide
  161. Is SERT dead?
  162. I need a base map for Thundermax
  163. 98 Sportster Starter/Starter Relay/Power issue
  164. Recurring DTC U1016 2007 Street Bob
  165. Ultra sometimes stalls and low idle intermittent
  166. HD download tuning questions
  167. Need Help brokedown in Mexico
  168. just bought a new bike and need advice
  169. 2014 touring superchip vigilante ez
  170. Engine Temp Sensor
  171. New ignition for 2011 FatBoy Lo
  172. Can you over AutoTune?
  173. SESTP problems
  174. Bike surges
  175. Reoccuring problem, very expensive...
  176. To auto tune or not to auto tune?
  177. police road king ??
  178. 2003 Electra Glide EFI engine sputter, misfire, chugging
  179. motor factory ignition settings & diagram
  180. FP3 questions
  181. Thundermax/Reduce TBW Sense?
  182. Screamin Eagle Super Tuner Pro, wont record?
  183. bike has not been started for 5 years
  184. La Dog needs Power Vision help.
  185. Ignition/Coil Question
  186. New Member introduction...
  187. No spark when cold
  188. Vance and Hines FP-3 experts. Need help
  189. Heated 02 sensors?
  190. Raw fuel smell
  191. Se203 map
  192. Got the stage one done.
  193. popping
  194. spraying in fuel tank
  195. ECM question
  196. PV2 Autotune - Scale or Cap?
  197. Electra 2003 FLHTP Engine neutral running failure
  198. Dyno tune vs auto tune- pros and cons
  199. TMAX and Virtual Machines...
  200. SE Heavy Breather - Retune?
  201. 09 street glide power commander issue
  202. PCV dead?
  203. new handlebars...no throttle
  204. '04 Road King going back to oem exhaust
  205. Poor mileage with Stage 1 and PCV
  206. 1999 ElectraGlide Standard TwinCam
  207. Tuner/Bike marriage...
  208. DK Customs 587 AC Install Issue
  209. lo rng warning will not turn off
  210. Tts tuning help
  211. Powervision Fuel Guage accuracy
  212. Loading a Power Commander Map
  213. what does it all mean ?
  214. Fuel ajustment? If baffle are removed
  215. Fuel ajustment? If baffles are removed
  216. Terry Components TV3 or the Vance and Hines Fuel Pak
  217. Are Screamin Eagle ignition modules plug and play?? Any idiot lights get triggered?
  218. Installing a TSSM
  219. Fat Bob Front O2 Sensor Plug
  220. Need advise
  221. backfiring
  222. '15 ECM logging?
  223. Code Help
  224. Stage 1 and spark plugs
  225. PV2 Autotune during break in on Breakout
  226. What is TSSM?
  227. Stage 1 in the works with Power Vision
  228. Part number 03 TC Screamin Eagle Race Ignition???
  229. Acceleration/deceleration
  230. Thoughts on FP3 and PV2 for a stage 1
  231. Power Vision Screen Cracked
  232. Tuner for 04 FXSTI
  233. Power Vision 1 with Windows Vista
  234. No luck on Dyna'so forum....any help here?
  235. Power Commander V FuelMoto
  236. Powervision question
  237. Too lean
  238. SE air cleaner
  239. Fuelpak fp3 / throttle progressivity
  240. No ignition power after H/U install
  241. Decreased mpg?
  242. Compu-fire 21860 SUPER SPORT RACE
  243. Tuner??
  244. Bike cutting out & and idle jumping up to 1500 rpm
  245. Free Roadking
  246. New PCV owner, Map question
  247. More air????
  248. Cobra Power Pro/Python Predator/SE Tuner
  249. SERT Files
  250. 2008 ROad King issue
