- 2/4 plug compression release
- front banana caliper 82 FLH
- POS V-Twin Dual piston rear banana (pics)- what a DRAG
- petrol fumes
- Help: 76 fxe seized clutch hub
- 76 FXE SHOWA Fork Damper Screw Reassembly ?
- Starter relay experiment
- got it dialed in pretty good - hand shift is nice - pull hard
- Electronic single fire ignition issue
- black silver and gold - advance curves and idle over
- Black oily goo on front rotor
- 81 fxdwg
- Spark plug recommendations
- Shovel & Evo Rocker Arms - Same Thing?
- Clutch issue
- 1977 FXE cam question
- My new 66 FLH
- Doing the right thing
- some basic, basic questions and thoughts
- 75 FLH Project
- Hydraulic tappet adjustment on a '77 FXE
- Timing mark on a '77 FXE
- This Classic Shovelhead Chopper is Classy as Hell
- Generator shovel front fork upgrade
- 4 speed fourth gear seal spacer
- 74 FXE front terminal board location
- S&S billet oil pump leak question
- Shovelhead handle bar question
- CAM for Stock 80" with Solid lifters
- Brakes
- 76 FXE Front Fork Removal & Reseal
- 76 FXE Wheel Bearing replacment ?
- Spark plugs
- Rear Cyl Miss Firing
- 75 FlH Project
- squirtin oil from seam
- Chain length
- 76 FXE Shovelhead Questions
- Shovelhead trans oil migration.
- new ignition switch
- Oil cooler on a '77 FXE question
- Horseshoe oil tanks?
- Can you put 1980 FXWG Lowers on FLH Tubes?
- Generator question
- how to test dyna s ignition on a harley davidson
- Noisy Primary when HOT
- Best shovelhead repair manual?
- 77 fxe drain oil
- True or False About a 74 being stroked
- Clutch hub 1981 flh shovel head
- No oil Pressure on rocker box gauge when warm
- 1077 FXE Question
- 73 Tins and front end fit 83 or 84?
- Steering dampner question
- 1982 fxr
- Just plain ole reliable....
- 72 shovel runs sputters, backfires, dies
- Timing plug thread size
- 1978 FX Foot Shifter Shaft Seals
- 1949 Shovelhead Project
- Did a service on my shovel
- 1976 FLH wheel
- Carb or ?
- Pushrod Tubes filled with oil
- Flywheel timing marks
- Son wants a Shovel
- Flywheel id# ???
- Loud whine in primary
- shovel piston symmetry pics
- 1980 FLT clutch
- Cracked and welded 79 shovelhead case question
- Shovelhead shock question
- 79 Sportster Tire Advice Needed
- Opinions on lifter upgrade
- 75 FXE - Where's The Signal Flasher
- shovelhed problem _ electrical or fuel?
- Prestolite starter rebuild tips
- Helppp!!! Oilseal issue
- 1972 FLH handlebar bushing...Will 73 bushing work?
- Shovelhead pulling right
- How bad is this base gasket leak?
- Shock-ing Question
- 1975 FXE Voltage Regulator Replacement
- Wet primary clutch plate question
- 71' Dashboard
- Thanks!! Figured out starter!
- 72 FX Compensator nut torque
- help with billet 41MM tree set - pics
- Watch this two minute video and tell me if I’m right or wrong
- Shovelhead "barn finds"
- Would Super Glide FX be a good candidate for a first classic HD?
- Shovelhead charging question!
- 78 Shovel puked out the breather
- BDL Belt Drive Confusion
- Primary Fluid
- 1966 jiffy stand spring
- Correct Idle Setting
- Starter not working
- hand shift build - rotary top
- .055 shim - behind rotor?
- crank seal NO GO - cant install - new one on me 78 FXE
- Shovelhead hesitation issue ... need advice
- replaced bendix gear and rebuilt starter but won’t engage
- 1983 Harley FXSB Roadster
- New member from NY looking for help rebuilding '81 FXS!
- Custom Wiring Diagram
- Best spark plugs
- Under seat frame and oil tank cover
- Rear cylinder plug fouled as f....
- 76 FLH Forks
- Whinnig noise
- Leaking or weeping? Smoking or choking?
- Andrews cam end play
- 41MM fork options - should I re-machine these
- 82 FLH wiring questions
- Rear Brake Master Cylinder
- Battery Drain
- Shock Covers
- New shovel build some crazy stuff going on
- Thank you HD Forum members
- Electrical system dies
- FLH stem nut - how to adjust pre-load inner/outer nut
- timing teaser
- rotary top in a mid-70's - clutch perch - pics
- Looking Back
- crankshaft oil lipseal
- What is this part for?
- Look what followed me home!
- 79 shovelhead flh top speed
- 11517 Terminal block wiring
- Tire pressure recommendation
- 71 FLH Shovelhead
- 1979 FXE Rear Caliper Problem
- Just joined. Smokes a lot after restarting.
- Need Advice Please
- Shovelhead rebuild
- Are these solid or hydraulic lifters?
- 72 FLH starter sometimes not engaging
- Do I look funny on my shovelhead?
- 72 FLH...what’s this throttle cable clamp mount to?
- shimming the motor to the frame
- i could use some help with electric start kits
- Rebuilt engine need electrical help
- 1981 FXS Shovelhead?
- Luggage rack question
- 72 flh speedo with tach wiring?
- Will these mirror be right?
- Need opinion on a shovelhead.
- 1979 Electra Glide Shovelhead comfort flex
- Charging 'amps' explained?
- New to the Shovelhead
- What kind of starter relay on 73 FLH?
- Clutch Hub Stud Issue
- hydraulic lifter adjustment / valvetrain noise?
- Mousetrap/clutch spring question
- Toggle switch
- Any Good Shovelhead Mechanics in Houston TX?
- 1973 FLH 4-speed noise.
- solids to hydraulics: pushrods suggestions
- Coating My Jugs
- 1983 FLT 6100 miles!!!
- Tranny help.
- Black '75 FXE Engine Case
- Broken Ankle
- Rear Master Cylinder plunger stuck
- Smoking after new topend
- synthetic oil
- What Gives....?
- Tire Recommendations
- Shovel won’t start
- Safety wired lug bolts.
- Super Glide Boat Tail or not???
- 77' Flh dash wiring
- 86 fxrs
- 1980 flt primary issues....a plenty
- Forward controls/floor boards
- Stocking up the Toolbox...
- what model and yr is my shoveled
- Rocker boxes.
- Blacked Out Chrome....
- help with cables
- Combined speedometer-tachometer
- Hey, from Baltimore, MD
- Interchange questions
- shovelhead flywheel ID?
- windshield
- ultima oil pump 73-91 big twin
- S&S Shovelhead
- 81 Low Rider front cylinder running hot
- Neutral Switch Location
- Chain Oiler On A '75 FXE?
- 1980 shovel
- 83 Fxr starter problem.
- Anyone running the stock 2-into-1?
- 1970 FLH - handle bar mount torque
- kicker stuck at 12
- Harley 4-speed Transmission Rebuild Service?
- stinkin aftermarket oil pump - ball seat not machined
- Leaky Bolt
- High Beam Indicator Bulb Removal
- Fueling Lifters
- Yard Sale Cam
- 10" rotor on a newer 21" wideglide wheel for FLH
- 1982 FLH top engine bracket
- new member FLT questions
- Oil out the breather
- Mixing oils in the transmission good or bad idea?
- 1974 flh help
- tubeless tyres
- Clean-up on butchered fender
- Head Gasket Maybe?
- Shovelhead Motor Removal
- Need help on starter solenoid
- Roadside exhaust fix
- correct sparkplug and gap too suit Crane HI-4 Dual Fire ignition on a Shovelhead
- Top End Upgrades For A '74 Cube Shovel
- Oil Seep At Cylinder Base
- Showa Forks, No Damper Spring?
- TRW Pistons with 45" T-slot pins - 3/32" rings
- Lifelong dream. got myself a shovel!
- Shovelhead Kicker Grind
- String Damper?
- Brackets for overload spring on Pogo seat?
- Correct Part Number for 1972 FLH Mufflers
- How do I remove headlight nacelle on 1984 FLH
- 1978 FXE Exhaust and Muffler
- Valve Guide OD and sizing
- Next problem: Carburetor
- 1983 FXDG Shorty Exhaust
- Building a shovel chop.. need some advice
- Might need a memory jog here...
- 1983 FXDG vin# sticker
- Shocks - Any Magic?
- Pushrod Tubes - early or late?
- Sato Marine Cycle's 1968 Shovelhead
- One Dead Shovelhead
- Research For a Book
- 1981 Heritage Edition
- knucklehead rear panhead front shovelhead cone bottom
- Delkron Lower Sump Cases
- Gas tank leak, Repair of the leak repair
- Bore Size of front master cyl 1980 FXS
- more pics of my shovel head project
- ‘76 FLH Won’t Idle
- Any Pics and Thoughts On Older Mac Brand Exhausts?
- POS hand controls
