- 1979 FXS Low Rider
- 81 fxb tank decals
- Possible Purchase
- Shovel reference manual
- 82 fxr
- Oil pump PITA
- Exhaust for S&S 96” sidewinder
- Look What Followed Me Home Today
- Ultima troubles
- Starter switch
- What Are the Best FLH OEM Style Shocks?
- 412 Sifton Cam
- My old Shovelhead
- 1979 low rider speedo cable
- '81 FXWG Loose Brake Calipers
- Classic shovelhead
- Shovelhead paint
- Solo seat on an 1984 FLH
- Rebuilt 80" Shovel motor
- FX brake pedal rubber
- Sumping workaround for long layovers…
- Shovel pics
- Bending a shovelhead kicker
- '76 FXE sumping TOO much. Starter struggling...
- Advice from fellow brits about shovels
- I need help with the clutch.
- Rod adjustment
- Seeking some advice before I ever need it about using my jump pack…
- 74 Barn Find
- Kicker arm
- Battery cover
- Keihin carburetor
- S&S super e throttle plate question
- Pushrod Replacements
- what happen to choppers
- Oil circulation problem?
- Breather gear diameter
- Arrgghh! Gas tank cracked, leaks
- Liberator Fairing - need some help
- Factory Kickstart on an Electra Glide FLH?
- Rear Brake
- Newer Style Battery in 78 FLH ??
- '77 FLH w/ '74 Shovelhead
- shovel primary leaks, convert to BDL belt?
- Bolts under buddy seat
- 1979 1200 FXS Speedometer Question
- Rubber plug
- Newly Aquired 1981 shovlehead FLH looking to do bar swap
- early vs late model flh 1983
- Shovel FLH Fairing/ Windshield
- 1982 FXB Question(s)
- Transmission rebuild dilemma
- Saddlebags for 1973 shove
- battery
- Cowpie to Ratchet
- Harley Exhaust Question 1980-1982
- gaskets
- Shovelhead J Breaks
- Starter housing gear size?
- test the alternator and voltage regulator?
- clutch hub
- 39mm and 35mm front ends
- Read my plugs 74 FLH
- 82 FXWG trans help
- Ultima 6 speed in a 5 speed
- 68 shovelhead valve key
- Pre '81 Factory build sheets.
- It's done for now
- Shovelhead leaking from breather
- Starter would not disengage...
- shovel
- Tranny Problem!
- Shovelhead sound
- Success Removing a Stubborn Crankcase Oil Screen Plug
- Tons of maintenance this year, now it won't start.
- Bulb for Superior im71r12v
- How much should I sell my 1979 flh police special for?
- 76 FXE carb questions...
- FLH Rear Brake Master Cylinder Cover & Highway Bar Fitment
- Keihin carborator jets
- clutch
- 74 FLH back together
- 1981 FXS Project
- 1977 shovelhead forward controls- drag specialties issue
- Crash Bars for my '81 Wide Glide?
- Fuel capacity and consumption 1979 FLH
- Horn location '82 FLHS
- Shox for my 78 fxe
- Oil tank breather
- Hinged fender on a FLH
- Verifying a Police Special
- 75 FXE battery tray mount bolt
- Parts questions
- oil
- New pipes for 75 fxe
- what Magazine this add in !? 1977 Low Rider !!
- Rear Caliper Setup
- Check ball cap screw
- Turn the Page
- FLH Project Consideration
- Identifying charging system
- S&s shorty vs ultima r1
- 71-72 superglide horn bracket
- Need some pics of original FLH parts
- No Left-Side Blinkers
- Brake Pads
- 81 fxe shovelhead won't start just clicks
- CV carb acceleration nozzle issue
- Anyone Using PennGrade 1 “Classic" Gear Oil (GL-4)?
- Inner primary question
- Need Advice on Working on a Flood Machine !
- Transmission ID
- starter relay upgrade question
- Shovelhead engine removal question
- Battery for 83 FXDG??
- Frame VIN vs Engine VIN
- Stripped the plug hole...
- Shovelhead Bead-Blasting and Cerakote
- Meet Dolly, my 1975 FLH Custom
- s&s carb
- My Parts Orders Never End.....
- Help With Open Primaries
- Ignition wows coil or condenser
- 79 80"
- 83 Wide Glide Restoration
- Oh boy !
- Southern California Repair Shops and Parts Sources?
- Rear axle nut torque 75 superglide
- New Shovelhead Owner
- Rear rocker box gasket blew...
- Shorter battery for 78 FXE with wraparound tank?
- Header Mounting Hardware
- Cam Question
- FLH Shovelhead ground
- Timing plug hole stripped
- shovelhead idraulic tappets trouble
- Pie Slice Front Brake Bleeder Valve
- Need chain guard bolt sizes for 1981 FXEF Super Glide / Fat Bob
- Oil Bags For Rigids
- TwiZted Biker
- 1976 FLH confort seat options
- rear brake caliper
- Inner primary torque values
- Chain Drive Recommendations
- Swing arm width
- PISTONS Drag Specialities
- 35 degrees, major shrinkage but worth it
- Solenoid burn up
- Where to get the Red Intake Manifold Bands?
- Low speed popping and lurching
- Fork
- Shovelhead head gaskets
- Find a part
- Breather Gear
- s&s b carb
- Any tips on attaching button caps to handlebar switches?
- Shovelhead starter solenoid problem
- 1980 FXWG Shovel timing help please
- 72-81 front master cylinder size?
- Rebuilding Rear Shocks 79 FXEF
- Shovelhead fork oil not passing properly
- Isolated primary
- coil cover
- Whats it worth?
- Exhaust stud broke
- Tank Emblem
- 1970 FLH Tranny top
- 73 FLH is this normal piston wear?
- Comfort Flex seat question on 74 FLH
- Shovel head parts
- Ignition System Recommendations
- Need a solid guide on 80 fxs
- oil pump gasket
- Plastic Breather Gear
- In A Moment Of Weakness
- 61 pan/shovel
- Milling Primary Cases
- Engine- parts color
- Evo 5 Speed in a Shovel
- "Chasing The Dream" Re-loaded 1983 FXDG !
- My new to me 55/66 Pan-Shovel
- Oil filter
- high comp starter?
- Delete
- ...Blown head gasket, or oil line leak?
- Ignition on the blink.
- New Parts for 78 FXE
- pan shovel
- Shovelhead Ham Can air cleaner on Twin cam
- which pistons?
- S&s no longer warrant their engines
- Stumped with wiring. Wire getting hot.
- Harley rims
- Looking for neck (frame) protectors
- Battery cable terminal sizes
- Tank question
- Yay for Lucas Oil!
- points, ignition questions
- posting pictures
- best shovelhead gaskets
- Ignition coil busted?
- Torque Specs
- 11 digit AMF VIN
- Wheel spacers.
- cast wheel end play
- Clutch Push Rod Length Question
- Has anyone tried this?
- 1981 fxb sturgis
- Struggling to get new build running (kick only)
- What valve seals do you have on your shovelheads?
- 1981 FXB For Sale
- 80 FLH insight please.
- Cone/witch hat throw out bearing hits kickstarter gear
- Shovelhead Electra Glide with Sportster seat
- Wagner Master Cylinder issue
- hey forty bikes at the bar and I'm the only shovelhead.
- Shock hardware
- Headlamp upgrade
- 76 FLH Lifters
- 82 FXR Cam question 3B996
- 1980 FXB Sturgis
- Tube or Tubless on cast wheels
- Oil Sumping woes.
- Left engine case surprise - help!
- First Shovel! 1980 FXS
- Akront 3.5" Rear Rim Clearance Issues
- Height difference, normal?
- Electrical Question
- 74" top end freshen up and cam
- 21" under FXE narrow glide fender?
- Are spoke angles same ?
- 18" rear 9 spoke wheel on 83 FXR
- alt rotor?
- Transmission bearing support/spacers issue
- Internal fork stop kit?
- 1983 FLH Keihn Screaming Eagle carb parts
- 1982 FLH mirrors
- 1978 Electraglide Maintenance
- Spark plug wires
- New Years Day Ride
- Shovel porn
- Shaker floorboards FLH
- Evolution of a Shovelhead - Picture Essay
- Ray's Magic Tranny Spacer
- different dash swap. brackets the same?
- 1972 Shovelhead Oil Pump Binding
- Exhaust stud snapped off...
- 77 FLH for sale near me.
- Shovelhead belt primary (internal)
- Fly wheels
